Range of a given OxyAce tip
Old January 25th 09, 03:48 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Range of a given OxyAce tip
We know general instructions for chosing a tip, setting pressures,
lighting the torch and setting the Acetylene so that the flame is just
about to leave the tip. Then we add O2 until we get a flame with just
a little feather. Written instruction seems to stop there.
However, we know one can adjust the torch for a larger or smaller
neutral flame, so each tip has a range of useful flame sizes.
At the low end the torch makes no noise; one opens the torch and you
go thru a hissing sound, to the roar of a jet engine.
No one seems to discuss how to determine the upper end of this range.
Can someone discuss how to determine the upper range of a given tip
size? - Mike
Old January 25th 09, 04:15 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
"Michael Horowitz" wrote in message
news
size? - Mike
One consideration is gas velocity.
Operating tips in their upper range can help disperse the weld, and
especially brazing puddle. Sometimes this is desired, sometimes it's not.
Old January 26th 09, 03:30 AM posted to rec.aviation.homebuilt
Brian Whatcott
news
size? - Mike
Yep, that's the way I see it too.
If you want more heat you turn up the gases. When the tip exit speed is
greater than the flame speed, you're done.
Brian W
Old January 26th 09, 04:03 AM posted to rec.aviation.homebuilt
Bob Murray
"Brian Whatcott" wrote in message
Brian W
Kent White www.tinmantech.com has an excellent essay on setting up torches;
start at max and adjust from there.
Bob
Need a little more range for your 304S jet? Marc Ramsey[_2_] Soaring 1 July 22nd 07 01:39 PM
F4U-5 ferry range [email protected] Naval Aviation 2 January 31st 06 04:02 AM
Long range Wx Paul kgyy Piloting 4 December 31st 04 04:25 PM
What is the range of the B-1B? user Military Aviation 10 December 24th 03 04:15 AM
Fuel Range Toks Desalu Home Built 2 November 14th 03 12:51 PM
