trailerable canard
Old January 25th 09, 05:37 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
Default trailerable canard
Of the various 3-4 place canards derived from Burt Rutan's original,
(cosy, velocity, ...) are there any with wings easily folded/detached
for trailering?
I'd like to consider acquiring one, but hangarage is very unavailable
round here, so the bird would have to live on a trailer when not flying.
TIA,
Old January 26th 09, 11:46 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sun, 25 Jan 2009 17:37:40 +0000, jan olieslagers
for trailering?
TIA,
there was an Eagle X that was setup to be trailerable. it is a 3 wing
thing with similar problems to canards.
their method was to split the fuselage so that the canard and mains
remained untouched and the tailcone pulled off. it was mounted
sideways on the trailer.
....there is more than one way....
Stealth Pilot
Old January 26th 09, 10:25 PM posted to rec.aviation.homebuilt
abripl[_2_]
None of the Rutan type derivatives are easily trailerable. They
require removing the main wings and wiring (3 bolts each wing) and the
resultant strake/canard width is near 12 feet wide. It is possible to
make a trailer jig that would set it up at a slant - see
http://www.abri.net/sq2000/travel12.jpg for a four place canard. You
could leave it tied down at the airport when anticipating frequent
flights and then towed home when not. But it is not very fast loading
it.
On Jan 25, 11:37 am, jan olieslagers
for trailering?
TIA,
Old January 27th 09, 12:41 AM posted to rec.aviation.homebuilt
abripl[_2_]
Shucks... If you don't mind a two seater and wait a little bit you can
drive a canard home to your garage: http://www.terrafugia.com/
for trailering?
TIA,
Old January 27th 09, 12:53 AM posted to rec.aviation.homebuilt
vaughn
"abripl" wrote in message
Sure! Believe that one and I have some waterfront property in the middle
of Florida to sell you.
Vaughn
Old January 27th 09, 01:17 AM posted to rec.aviation.homebuilt
abripl[_2_]
On Jan 26, 6:53 pm, "vaughn"
Vaughn
There are always insulting armchair critics that don't accomplish much
themselves. Successful flying cars have been around since 1957
http://www.aviation-history.com/garb...obile-1_f.html
Being mechanically successful may be different from commercially
successful. Terrafugia unit is not much more than a refinement of
previous efforts. I hope they succeed and I wish them the best of
luck.
Old January 27th 09, 01:35 AM posted to rec.aviation.homebuilt
vaughn
middle
Vaughn
themselves.
You have no idea what I have accomplished, so you seem to be the one doing
the insulting.
You are dead wrong. There have been various flying cars produced, even
certified over the years. None have achieved success by any normal measure.
Even the world's governments with their amazing military budgets have never
produced any such vehicle/plane in any quantity. Because of regulations on
both the aircraft and the automobile side that have been proglimated over
the decades since 1957, commercial success would be even less likely today.
luck.
It may be a surprise to you, but I happen to agree with you on this
point, but history tells me not to be optimistic..
Vaughn
Canard Mark Home Built 9 December 28th 08 01:19 AM
Canard or Mooney Linton Yarbrough Piloting 18 May 21st 08 09:54 PM
Canard or Mooney Gezellig[_2_] Home Built 3 May 21st 08 09:54 PM
Canard or Mooney Linton Yarbrough Home Built 0 May 12th 08 10:52 PM
Canard or Mooney clint Home Built 1 May 5th 08 02:37 PM
