L/D @ SPEED
Old January 28th 09, 06:59 PM posted to rec.aviation.soaring
Mark Jardini
Default L/D @ SPEED
Sailplanes have of necessity a polar with min sink at speeds where
circles can be small enough to center thermals, and L/Dmax only a few
knots higher. Ballast is added to raise the L/D max perhaps 10Kts
higher.
What might a wing look like that was built for optimum L/D @
80-100Kts? What kind of L/D might be possible?
(will this winter never end?)
Mark J
Old January 29th 09, 01:18 AM posted to rec.aviation.soaring
Default L/D @ SPEED
higher.
Mark J
The wing you are talking about woudn't be a whole lot different than
current flapped ships with the flaps
in the first reflexed position. This is the target sweet spot for
these ships now.
UH
Old January 29th 09, 01:58 AM posted to rec.aviation.soaring
DRN
Default L/D @ SPEED
higher.
Mark J
Antares 20E max L/D is already up around 70 knots.
Still, there are a lot of compromises to make these
modern gliders thermal well...
See ya, Dave "YO electric"
Old January 29th 09, 05:05 AM posted to rec.aviation.soaring
Default L/D @ SPEED
higher.
Mark J
If you think just in terms of wing loading, and ASW-27 needs about
14lbs/sq ft to get best L/D up to 80 kts and 18 lbs/sq ft to get it to
90 knots. Ignore aspect ratio, Reynolds number effects, etc and take
it back to wing area and you are talking about 62-79 sq ft. instead of
the 98 sq ft of the -27 and an aspect ratio of 31-39 instead of the 25
on the current -27. Without doing the math, say that the aspect ratio
effect outweighs the Reynolds number effect by a little bit and you
get a 75-80 sq ft wing and an aspect ratio just above 30.
I'm guessing with current construction techniques you could build it,
but without some new airfoil innovation it might not climb very well.
9B
Old January 29th 09, 05:18 AM posted to rec.aviation.soaring
Default L/D @ SPEED
higher.
Mark J
on the current -27. *Without doing the math, say that the aspect ratio
9B
Oh, and I'd be surprised if you could get the max L/D much above the
mid 50s on a 15 M ship. Of course, you'd want to cruise it well above
the max L/D speed. Out west you might be able to imagine a glider
that could win races optimized around 14 lbs/sq ft, but I'd think even
western conditions might prove insufficient to support a glider with a
best L/D design point of 100 kts, since that implies cruise speeds
pretty considerably into triple digits and stall speeds and circling
radii that are pretty big.
9B
Old January 29th 09, 04:15 PM posted to rec.aviation.soaring
Peter Higgs
Default L/D @ SPEED
Hi All, I once read an article by a 'boffin' at Cranwell, who stated that
Vx was always 84% of Vy. In other words the two speeds are
mathematically linked... Something like the inverse of the 4th root.
I can understand that the induced drag increases by the inverse square, as
the speed decreases, so there must be one further square root to take into
effect in the equation.
So if you have a high Vy then your Vx will also be high, and the glider
will not turn in the thermals very tightly. Unless you can modify the
wing shape, with flaps, for the two different types of flight.
Pilot Pete
Old January 29th 09, 06:27 PM posted to rec.aviation.soaring
flying_monkey
Default L/D @ SPEED
I saw a glider with the Sinha (sp?) deturbulator tape this last
weekend. The owner was explaining the theory of how that works, and
it seems to revolve around the turbulent stream hitting exactly at the
location of this tape, which would explain why it works only at that
speed. I thought about this question just after talking to him: Why
not coat the whole aft 2/3 of the wing with the deturbulator material,
then you would cover all the possible reattachment points? Of course,
as a scientist, I wonder about the validity of any test where the
proponent says that "You have to take each test individually, not
aggregate them together." Sounds like anecdotal evidence to me.
But, assuming that this would really work, then you could have what
the owner described as a "induced drag only" wing, and it L/D would
depend only on fuselage drag. So, a wing like this on a really
streamlined fuselage (Diana?) might see high L/D speeds.
Just my $0.02,
Ed
Speed Astir Jono Richards Soaring 3 March 25th 06 07:19 AM
One way to speed up a Fly Baby Ron Wanttaja Home Built 4 March 23rd 06 08:01 AM
'Speed Pants'... .Blueskies. Home Built 14 December 14th 05 04:02 AM
763 Cruising Speed. [email protected] General Aviation 24 February 9th 04 09:30 PM
AI... is it speed consuming??? Jesper Andersen Simulators 0 October 3rd 03 11:24 AM
