Grob 109 wing pins
Old February 7th 09, 02:43 PM posted to rec.aviation.soaring
Bob Jenneson
Default Grob 109 wing pins
Hi,
I am seeking advise on the replacement of the wing pins fitted in the
end of the spars on Grob 109 and 109B.
This also applies to the Grob Twin Astir.
A brief history.
These pins are welded to a plate that is glassed into the wing spar end
during manufacture. It was found out at a later time that some of these
assemblies were prone to cracking around the welds and required replacement
if found to be cracked.
In Australia we are required to "ultrasonic " test these pins every 500
hours ( AD 370 )
If tested 'OK' we keep flying.
We now have two aircraft that have 3000 hours each ( Life extension time )
and no cracks found.
Do we need to change the pins?
This is serious and expensive surgery and I am seeking advise as to how
other countries have dealt with this problem.
I understand that Australia in the only country that uses the ultrasonic
test.
Grob are happy to supply the new pin assemblies, but is it really necessary
if the old ones have a 3000 hour safe history.
Any help appreciated, Bob.
Grob 109 wing pins BT Soaring 0 February 7th 09 06:05 AM
Grob wing retainer bearings Tim Soaring 3 September 3rd 06 03:55 PM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 01:46 AM
Hinge pins for Pegasus AD tooromeo Soaring 0 May 17th 05 03:56 PM
taper pins Ernest Christley Home Built 4 September 12th 03 04:15 AM
