pourin pistons
Old February 11th 09, 12:24 AM posted to rec.aviation.homebuilt
jerry wass
Default pourin pistons
http://www.enginebuildermag.com/Arti...ston_pour.aspx
Very neat 2 spout ladle
Old February 11th 09, 05:03 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
Freaky clean foundry, that. Pretty sophisticated permanent mold,
including a permanent, internally expanded core. That ladle and the
two gates enabled the casting to fill rapidly from the bottom without
choking the runners. Very well designed mold.
Old February 12th 09, 02:21 AM posted to rec.aviation.homebuilt
Elliot G
"Jerry Wass" wrote in message
Cool link.
Are most aircraft pistons cast or forged???????
Old February 12th 09, 03:26 PM posted to rec.aviation.homebuilt
stol
Cool link.
Cast ..
Old February 12th 09, 04:25 PM posted to rec.aviation.homebuilt
jerry wass
Cool link.
Cast ..
I would have guessed "cast" because of the larger temperature
coefficient of forged metal---already have a big enough problem
with the cast pistons, controlling clearance changes with rapid
external temperature changes.
Old February 12th 09, 04:35 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
news
Cool link.
Cast ..
I would have guessed "cast" because of the larger temperature coefficient
with the cast pistons, controlling clearance changes with rapid external
Are they a metal reinforced casting, like a lot of auto pistons?
Old February 12th 09, 06:55 PM posted to rec.aviation.homebuilt
news
Cool link.
Cast ..
Probably. I'll find out when I make a cutaway later this year,
I hope. The steel inserts in the piston wall around the pin boss are
to control expansion across the widest axis of a cam-ground piston,
which is 90 degrees to the pin. Aluminum has a coefficient of linear
thermal expansion of almost exactly twice that of steel and an
aluminum piston can get bigger than its steel cylinder without some
control, or else a lot of clearance.
Pistons are usually cast of a high-silicon aluminum for wear
resistance. Machines beautifully.
Dan
Old February 17th 09, 04:45 AM posted to rec.aviation.homebuilt
Dan[_12_]
Cool link.
Cast ..
I would never buy forged parts. Counterfeit parts with forged
documents are usually lower quality.
Dan, U.S. Air Force, retired
High compression pistons on AEIO-540 Juan Jimenez Owning 5 April 18th 05 01:38 AM
WTB--WTB--O-470 pistons jerry Wass Home Built 0 August 17th 04 05:36 PM
WTB--WTB--O-470 pistons jerry Wass Aviation Marketplace 0 August 17th 04 05:36 PM
4--O-470 pistons,used jerry Wass Home Built 0 August 17th 04 05:07 PM
4--O-470 pistons,used jerry Wass Aviation Marketplace 0 August 17th 04 05:07 PM
