"Secret" Overvoltage Protection?
Old February 15th 09, 05:26 AM posted to rec.aviation.homebuilt
Default "Secret" Overvoltage Protection?
I had an unusual experience last week, and figured I'd air it here for
some opinions.
My Fly Baby had developed charging problems again. I wasn't sure if it
was the generator or regulator, so I decided to do a bit of temporary
wiring to bypass the regulator (Generator armature to +12V, ground the
Field terminal).
I knew that in this mode, the generator could produce high voltages that
could fry my radio (ICOM IC-A5) and transponder (Microair). So I left
the power switches for both off.
I started the engine and watched the voltmeter. It read 8V at idle, but
when the power came up, the voltage started to rise. I chopped the
throttle before the voltage got much past 14V on the gauge.
So, the regulator was bad. Fortunately, I'd bought a spare at a
fly-market a few years back ($5). I switched regulators, buttoned up
the cowl, and mounted up for a test flight.
Strangely enough, neither the radio nor the transponder would power-up
at first try. I cycled the power on and off, and pressed the "on"
buttons on each a couple of times.
The ICOM powered up about the third try, and worked normally. The
Microair was more stubborn, but after about 15 minutes of power-on, it
too came on when I hit the switch.
The only thing I can think of is that both units have some sort of
overvoltage protection that clears itself after a time. Neither has the
classical "On" button with mechanical contacts that make or break the
power to the unit; the "On" button undoubtedly tells some aspect of the
circuit board what to do (on the Microair, one hits the power button
multiple times to adjust the LCD lighting).
Still, the units shouldn't have seen that direct generator output...they
were turned off. So what activated the overvoltage protection?
Anybody got any ideas?
Old February 15th 09, 02:06 PM posted to rec.aviation.homebuilt
Peter Dohm
Sorry about the top post; but I didn't want to cut your original text.
You have been tricked and, without schematics of the Com and Transponder, I
really don't know exactly how they are supposed to work. However, the
common problem with modern electronics is that, without an old fashoined
mechanical switch, a portion of the circutry must remain powered on when the
device is turned off.
I am now about ten years out of date as an electronic technician, so I
really don't know what additional parts reamain operational; but, at the
most basic, system clocks, memory of any preselected channels (or
frequencies), the on-off control circuitry, the voltage protection circuits,
and possibly any crystal heaters. It is not just an aviation problem
either, as I suspect that it may be a primary cause of failure in personal
computers and other houshold electronics; but it is easiest to see in
automotive radios--which usually have no internal batteries or capacitors to
keep the memory alive when the main battery is disconnected for even a few
seconds.
Anyway, I'm glad that the protection circuits appear to have worked without
damage.
Peter
"Ron Wanttaja" wrote in message
I had an unusual experience last week, and figured I'd air it here for some
opinions.
Field terminal).
could fry my radio (ICOM IC-A5) and transponder (Microair). So I left the
fly-market a few years back ($5). I switched regulators, buttoned up the
Strangely enough, neither the radio nor the transponder would power-up at
first try. I cycled the power on and off, and pressed the "on" buttons on
Microair was more stubborn, but after about 15 minutes of power-on, it too
Old February 15th 09, 05:11 PM posted to rec.aviation.homebuilt
The difficulty is the lack of definitive understanding of how my
airplane is wired. The original builder didn't generate a schematic. I
inherited one drawn up by the third owner:
http://www.bowersflybaby.com/tech/elect.gif
When I ran the regulator-bypass generator test, I turned on the Master
Switch, the Field Switch, and the Generator Output switch, but left off
the switches for the radio and the "Aux" (which goes to the transponder).
If the schematic is correct, then no +12v power should have been
available to the devices unless I'd turned the breaker/switches on.
However, there is the possibility the schematic is wrong...that the
switches may control connection of the devices to the GROUND, and that
the +12V is delivered to the radio and transponder whenever the master
switch is on. Since I have a wooden airplane, there is no "ground", per
se. Two wires go to each device, and whether the breaker/switch
connects one wire to the ground bus or the other one to +12V wouldn't
make much difference in operation.
If the breaker/switch does control connection to the ground, there is a
chance that the devices still see ground via their antenna ground plane.
If that is the case, then an overvoltage at the +12V input *might*
still be detected and reacted to.
However....neither device will power-up if the breaker/switch is turned
off. The ground plane for the comm radio antenna is connected to ground
by the same wire that connects the radio itself to the ground.
Curious....
Old February 15th 09, 06:01 PM posted to rec.aviation.homebuilt
bildan
On Feb 15, 10:11*am, Ron Wanttaja wrote:
really don't know exactly how they are supposed to work. *However, the
airplane is wired. *The original builder didn't generate a schematic. *I
switch is on. *Since I have a wooden airplane, there is no "ground", per
se. *Two wires go to each device, and whether the breaker/switch
* If that is the case, then an overvoltage at the +12V input *might*
off. *The ground plane for the comm radio antenna is connected to ground
Curious....
A lot of newer avionics have DC-DC buck/boost voltage regulators built
in. This shows up on the specs as an input voltage of say, 10 - 36 V
meaning the internal regulator will deliver a constant voltage to the
circuit boards if the aircraft power bus is somewhere in that range.
It also means that the device will work on both 12v and 24V systems.
FWIW, I have a Microair 760 in my glider and find it is unusually
sensitive to input voltage. Whenever the SLA battery drops to 11V, it
goes totally bonkers.
This brings up a slight fork to this thread and that is alternator
failure. I've had three - one in hard IFR.
It seems to me that modern avionics should have a UPS just like the
computer I'm typing on. Modern avionics use far less power than they
used to and batteries are getting better. It should be possible to
have a UPS battery on the avionics bus that will power the whole panel
longer than the fuel will last.
Old February 15th 09, 11:47 PM posted to rec.aviation.homebuilt
Dana M. Hague[_2_]
On Sat, 14 Feb 2009 21:26:23 -0800, Ron Wanttaja
classical "On" button with mechanical contacts...
I wonder if it's the same problem that I've seen on a number of
occasions with computers, which typically is the computer getting
zapped by a static discharge (the "rubbing your feet on a carpet on a
dry day" thing). The symptom is that the computer won't turn on at
all, and the fix is to unplug and/or remove the battery, then press
and hold down the power button for ten seconds or so to drain off any
static. Plug it in and/or replace the battery, and voila! The
computer works again. A transient voltage spike too fast for your
gauge to register may have done the same thing to your electronics.
-Dana
There is always a law against doing anything interesting.
Old February 16th 09, 08:21 PM posted to rec.aviation.homebuilt
On Feb 15, 9:28 am, Bryan Martin
You are correct in that some circuits in many avionics devices will be
powered up anytime the master switch is on. The only way to be sure
these devices are completely isolated from ship's power is to pull the
fuse. But, avionics devices are not going to have any memory circuits or
clocks that require a keep alive voltage unless they have a dedicated
battery for the purpose. When the master switch in an airplane is off,
there is no power at all getting to the avionics, all circuits are
completely disconnected from the ship's power unless they have a backup
power source. About the only thing in most airplanes that might bypass
the master relay is an electric clock.
No, some avionics have a "keep-alive" feed to them via a tiny
fuse directly from the hot side of the battery contactor. Narco's MK12d
+ radios, for instance. If that isn't connected the memory is gone and
the display will default to the lowest frequencies on system shutdown.
Clocks usually have a feed through another tiny fuse. And Artex's new
ME406 ELTs also have a hot feed to the panel switch, but all it does
is feed the LED indicator so that power isn't robbed from the ELT's
battery to do it. Kannad and some others don't use a hot wire. The hot
feed is an item that adds to the installation cost, by the way. Got to
find a place for the fuse and run a wire from it to the panel. Labor,
man.
I'm wondering if Ron's problem was a low system voltage after
he installed the new regulator, until it woke up and started the
generator charging. Some of these radios will drop offline if they
aren't getting nearly the full rated voltage.
Dan
Old February 17th 09, 02:32 AM posted to rec.aviation.homebuilt
RST Engineering
Dan et al ...
The "tiny fuse" you refer to is actually a single fuse mounted as close as
possible to the battery box. AIVR, you can have either 3 or 5 amps directly
from the battery (i.e. a 3 or 5 amp fuse) in a "keep alive" circuit that
doesn't go through the master relay but is wired directly to the battery.
That circuit is then wired to the clock and any other avionics that need to
draw (usually microamps) current to keep memories alive and the like.
In the Cessna, I mounted that fuse on the master relay bracket and got the
"hot" from the master relay itself on the upstream side of the battery.
Minimum wire and minimum chance for fire if the wire insulation shorts to
ground. Use a rather thin wire with an extra coat of heavy shrink sleeving;
if it DOES short to ground it will fuse rather than start a fire.
"It is the mark of an educated mind to be able to entertain a thought
without accepting it."
--Aristotle
man.
Dan
Old February 17th 09, 05:04 PM posted to rec.aviation.homebuilt
On Feb 16, 7:32 pm, "RST Engineering" wrote:
Dan et al ...
That's where I find them and where I put the Artex's fuseholder. I
don't want an always-hot unfused wire any longer than necessary. The
Artex uses a quarter-amp fuse.
Dan
Old February 18th 09, 10:57 PM posted to rec.aviation.homebuilt
Dan D[_2_]
"RST Engineering" wrote in message m...
Dan et al ...
What size wire do you recommend? 22ga?
Old February 19th 09, 04:39 AM posted to rec.aviation.homebuilt
RST Engineering
Who is asking?
--Aristotle
"Stealth" Secret Service aircraft No Name Piloting 10 August 21st 08 12:12 AM
NASA to Release "SECRET" Survey Larry Dighera Piloting 9 November 13th 07 12:54 PM
THE BIGGEST SECRET 9/11, 7/7 and ("Operation Iraqi Freedom"? ) Mighty Thor General Aviation 0 October 27th 07 11:35 AM
THE BIGGEST SECRET 9/11, 7/7 and ("Operation Iraqi Freedom"? ) Mighty Thor Instrument Flight Rules 0 October 27th 07 11:34 AM
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [3/5] - "03 Blackhawk - a different angle on Sunday.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
