Hi,
Could anyone give me a brief overview of the benefits of buying a certified engine over a non-certified engine? Why do manufacturers sell both? Price difference? Does the owner have to get the engine certified after purchasing? Thank you for your help |
More information needed.
What country? Into which airframe is it going? A certified engine/propeller combination into a kit built aircraft may shorten the certification process for the aircraft. An non certified engine/propeller combination into a kit built aircraft could lengthen the certification process and procedures for the aircraft. In the US, a non certified engine into a "standard" certified aircraft could impact (limit) the future use of that aircraft to non commercial applications. "aerojones" wrote in message ... Hi, Could anyone give me a brief overview of the benefits of buying a certified engine over a non-certified engine? Why do manufacturers sell both? Price difference? Does the owner have to get the engine certified after purchasing? Thank you for your help -- aerojones |
On Feb 16, 8:17*am, "BT" wrote:
In the US, a non certified engine into a "standard" certified aircraft could impact (limit) the future use of that aircraft to non commercial applications. Huh??? Either the engine is approved (by STC or by the FSDO (unlikely)) or its not. There is no seperate standard in the US to allow a certified airplane to run an non-certified engine.. -Robert |
![]() "Peter" wrote in message ... "BT" wrote In the US, a non certified engine into a "standard" certified aircraft could impact (limit) the future use of that aircraft to non commercial applications. I think it would be a bit more serious than that ![]() True.. putting in an engine that is outside of the TCDS will require paperwork, 337 field approval and all of that. If there is already an STC for that engine in that airframe.. it's a tad easier.. But in any case.. a non certified engine.. even if approved for installation.. could remove the aircraft from commercial services. |
If the gov't requires you to use a certified engine you must use a
certified engine. If it does not there is no reason to use a certified engine. The price difference is the cost of getting the gov't certification (which also usually means the engine is less advanced since certificating authorities hate dealing with advancements). For instance an IO-360 vs the same Lycoming engine for experiementals, you would never buy the certified IO-360 unless you are required to. -Robert On Feb 15, 4:36*pm, aerojones wrote: Hi, Could anyone give me a brief overview of the benefits of buying a certified engine over a non-certified engine? Why do manufacturers sell both? Price difference? Does the owner have to get the engine certified after purchasing? Thank you for your help -- aerojones |
IFR GPS certification | nobody | Instrument Flight Rules | 17 | March 16th 05 04:16 AM |
IFR GPS certification | nobody | Owning | 14 | February 28th 05 04:07 PM |
FAA Certification | fred D | Soaring | 7 | June 15th 04 03:01 PM |
Pitts Certification | moby | Aerobatics | 2 | February 4th 04 01:26 PM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
