Duration of Condition Inspections, USA
Old February 28th 09, 04:49 AM posted to rec.aviation.homebuilt
Default Duration of Condition Inspections, USA
Where in the US aviation regulatory literature is the time limit of a
Condition Inspection stated? Does it run out at the end of the
calendar month or a year to the date it was last performed.
Where is the reference that clearly lists the time limit?
Robert Mudd
Old February 28th 09, 08:22 AM posted to rec.aviation.homebuilt
AC 8130.2F, Section 153:
"153. ISSUANCE OF EXPERIMENTAL AMATEUR-BUILT OPERATING LIMITATIONS.
"a. Operating limitations must be designed to fit the specific situation
encountered. The ASI may impose any additional limitations deemed
necessary in the interest of safety. The ASI and/or designee must review
each imposed operating limitation with the applicant to ensure that the
operating limitations are understood by the applicant.
"b. The following operating limitations shall be prescribed to
experimental amateur-built aircraft:
"(22) No person must operate this aircraft unless within the preceding
12 calendar months it has had a condition inspection performed in
accordance with the scope and detail of appendix D to part 43, or other
FAA-approved programs, and was found to be in a condition for safe
operation." (page 165)
Old February 28th 09, 01:42 PM posted to rec.aviation.homebuilt
routund
Robert Mudd
It is in the Operating Limitations that are issued for each Experimental
certification. Some times those OLs don't get passed on to subsequent owners.
Silver/Gold Duration Question Dixie Sierra Soaring 11 May 29th 07 11:06 PM
Silver Duration [email protected] Soaring 5 April 11th 07 02:12 PM
Local flight >227 hours duration Casey Wilson Piloting 4 February 22nd 05 10:49 PM
Altitude loss for 5h Duration Flight nyffeler Soaring 9 August 28th 04 11:12 AM
aircraft financing duration help news.det.sbcglobal.net Aviation Marketplace 1 June 30th 04 06:27 PM
