Ka-6CR and E Canopy Mods.
Old February 28th 09, 10:45 PM posted to rec.aviation.soaring
Robert Buck
Default Ka-6CR and E Canopy Mods.
Is anyone familiar where to find plans or kits or otherwise of the
"Swiss" canopy modification, (bigger canopy with wider base), for the
Ka-6CR? Also, same for the "Cabrio" (open cockpit), canopy's for the
CR and E? Many thanks for any assistance in finding such...our location
is in the United States, the State of Vermont.
Rob Buck
Old March 1st 09, 12:25 AM posted to rec.aviation.soaring
vontresc
Ka-6CR? *Also, same for the "Cabrio" (open cockpit), canopy's for the
CR and E? *Many thanks for any assistance in finding such...our location
Rob Buck
I own a Cr, and I was looking into the possibility of the open canopy
mod. There is a TM available from Schleicher that outlines the process
of building the open canopy. Unfortunately the TM-23 is in German.
http://www.alexander-schleicher.de/tm/06/060_TM23_D.pdf
The gist of the TM is that you build a canopy frame from the plans
(which are not available in the online version), and you need to close
off the rest of the fuselage when using the open canopy.
Peter
Old March 1st 09, 04:02 AM posted to rec.aviation.soaring
Neal Pfeiffer
The original canopy has the wood frame that curves up and inward for a
few inches. Where the Plexiglas is attached to the base is distinctly
narrower than the bottom of the wood frame. The back curve of the
Plexiglas for the original canopy does not have any reverse curvature
when viewed from the rear and it matches the fuselage behind it.
If the Plexiglas is extended down to the bottom of the opening and a
smaller 1" frame is used, the Plexiglas will need to be reverse curved
when viewed from the rear, if the original fuselage is not to be
modified. The "Swiss" canopy on one of my Ka6BRs does not have reverse
curvature, but only because the fuselage has a fair amount of filler
behind it under the wing. This may be an anomaly, however, I think that
it is probably more the rule since reverse curvature in the lower canopy
would tend to distort the view and make the additional transparency less
useful.
So if you choose to move to a "Swiss" (oder Schweizer) canopy, you may
want to consider added fuselage modifications.
You may want to follow the classified ads on segelflug.de and search for
Ka6 canopy frames (Haube) to find one that could be converted to a
Cabrio. There have also been some Cabrio canopies advertised there in
the past year. I have considered buying one myself. I'm too busy with
my restoration projects to consider building one now.
Good Luck!
...... Neal
Rob Buck
Peter
Old March 1st 09, 07:37 AM posted to rec.aviation.soaring
Rob Buck
Peter
Peter, allow me to introduce Rob Buck. Rob... Peter.
Pete, Rob is a long time friend of Burt and has flown at Marfa many
times.
Rob, I helped Peter find his K6 and recently joined him in Marfa for a
week of training and fun with Burt.
I hope you guys can help each other out with this project and I look
forward to sharing a flight, a drink, and a great evening of talk with
you sometime hopefully in Marfa but anywhere will do!
Matt Michael
Old March 1st 09, 08:13 PM posted to rec.aviation.soaring
vontresc
Rob Buck
Peter
Peter, allow me to introduce Rob Buck. *Rob... Peter.
times.
Matt Michael
I'm starting to think Matt knows EVERYONE in soaring sometimes.
Back to the subject of Canopies. I just emembered that there is
someone on the German sailplane classifieds site is selling pars from
his wrecked Ka-6.
http://www.segelflug.de/cgi-bin/clas...uery=retrieval
He lists his personal site, too. Unfortunately I do not read Czech,
but the pic on the Segelflug.de listing sure looks like a "Schweizer
Haube"
Pete
Old March 2nd 09, 05:52 AM posted to rec.aviation.soaring
Rob Buck
Peter
times.
Matt Michael
his wrecked Ka-6.
http://www.segelflug.de/cgi-bin/clas....cgi?search_an...
Haube"
Pete
It only seems that way because you are just starting to get to know
people and I know a couple people who DO know everyone in soaring.
It's a small and amazing community. I'm proud to be a part of it.
MM
Old March 4th 09, 10:45 PM posted to rec.aviation.soaring
Robert Buck
Ka-6CR? =A0Also, same for the "Cabrio" (open cockpit), canopy's for
CR and E? =A0Many thanks for any assistance in finding such...our
locatio=
n
Rob Buck
Peter
Old March 4th 09, 11:15 PM posted to rec.aviation.soaring
Robert Buck
locatio=
n
Rob Buck
Peter
Peter...
Many thanks...looked up the TM and will see if I can find plans. From
Schleicher?
All the Best,
Rob
Robert Buck
useful.
Good Luck!
...... Neal
Neal...
Many thanks and will keep my eyes open. Also, saw the pix of your
restored "E"...congratulations. See you at IVSM, I hope!
Rob
location
Rob Buck
Peter
Old March 4th 09, 11:30 PM posted to rec.aviation.soaring
Robert Buck
for
locat=
ion
Rob Buck
Peter
times.
Matt Michael
Hi Matt...
Thanks...going to IVSM in Elmira? Appreciate your assistance. Hopefully
we'll all get together before long...can't make Marfa this year...I
think.
Rob
Spot, Mods!!!! NW_Pilot Owning 0 June 22nd 08 01:46 AM
Engine Mods Paul Missman Owning 8 February 17th 05 03:40 AM
Vne/Va/Aircraft Mods Dale General Aviation 2 August 26th 04 02:07 AM
mods for a Cherokee 140 Tony Woolner Owning 8 January 7th 04 12:20 PM
Ventus A/B Mods Al Soaring 0 November 8th 03 07:06 AM
