America's Army Sucks, Fact
Old May 30th 04, 06:32 PM
cain_uk
Default America's Army Sucks, Fact
America's army sucks.
They have no idea how to fight a war. I mean dropping bombs from a
B-52 at 30,000 feet isn't war, its called a western. Their a bunch of
cowboys. And now we here about the disgusting behavior of American's
torturing Iraqi prisoners.
For real soldiers, look other the other side of the Alantic, Britian.
Old May 30th 04, 07:06 PM
WalterM140
As a former Marine, I don't make a lot of excuses for the US Army.
The Brits don't have any really great shakes going for them either.
The most famous Brit general of the 20th century -- Montgomery-- was borderline
incompetent. None of his plans ever worked even remotely as advertised. Crap,
he planned the raid of Dieppe. Look how that turned out.
I watched with great interest the British attack on the Falklands. It's not
generally known, but only @ 40% of the bombs that hit Brit warships actually
detonated. They were US munitions left over from WWII. Reduce that dud rate to
zero and the whole Brit expeditionary force becomes POWs.
Brit military prowess? They have great NCO's. That's what I hear.
Walt
Old May 30th 04, 11:21 PM
Guy Alcala
As a general rule I don't respond to threads started by trolls, but some of what
you wrote below in response is both on topic and factually incorrect, so I'll
correct it.
WalterM140 wrote:
snip
detonated.
I guess that depends on how you define 'generally known.' It's certainly well
known among many of the readers of this NG, and even more generally known among the
readers of s.m.n.
No, they weren't. The Fuerza Aerea Argentina used British Mk. 13/18 series 1,000
lb. bombs, US. Mk. 82 500 lb. bombs (the CANA A-4s used the Snakeye retarded
version; the FAA used the slick version), and French Para-retard bombs, either 250
or 400kg (sources differ. Photos I've seen of one of the French duds at Ajax Bay
looks to me more like a 250 than 400 kg job.) All of these bombs are post-WW2
vintage, with the possible exception of some of the British bombs used by the
Canberras. The Mk. 82s would definitely date from post-1965, which is when
Argentina received the first A-4s. The Mk. 82 wasn't even around in WW2, not
entering service until the mid-50s or so. I suspect the same is true for the
French para-retard weapons, if they didn't date from even later.
You could equally say reduce the dud rate to zero and the odds are good the FAA
doesn't have any a/c left, because most of them have been shot down. The reason so
few bombs detonated is because the FAA pilots had the normal instinct for
self-preservation, and usually flew as low and fast as they could to make the job
of the defenses much harder. But this meant that bombs were often dropped from
altitudes too low to allow sufficient time for fuse operation, so many of the bombs
dudded, or the fuse delays were so long (to allow time for the wingmen to clear the
target before the bombs exploded) that bombs which weren't stopped by structure
inside the ship passed on through and out the other side before exploding. The
whole reason for the defenses was to make the pilots more worried about survival
than destroying their targets, thus increasing the incident of duds. CTG 317.0
(the amphibious shipping), Commodore Clapp, was very glad that the Argentine pilots
were chosing to make level bomb runs instead of pop-up dive attacks, for just that
reason.
On the few occasions where the defensive fire was minimal, the pilots were
willing/able to climb high enough before dropping (ca. 300 feet AGL for a slick Mk.
82) that the fuses had time to operate, and the 'dud' rate dropped off accordingly.
Guy
Old May 31st 04, 01:19 PM
WalterM140
WalterM140 wrote:
snip
not
actually
detonated.
well
among the
readers of s.m.n.
Sure, but 'most people' don't read this newsgroup.
1,000
either 250
Bay
post-WW2
Thanks for the correction. I heard something else.
FAA
reason so
job
from
bombs
clear the
structure
The
survival
317.0
pilots
that
reason.
Well, that's interesting, but it seems to indicate that the Brits were gambling
they could induce the Argintines to attack incorrectly. Not very prudent.
You seem to agree that if -all- the bombs had detonated the Brit supporting
force would have been reduced below a level where the invasion could have been
supported.
slick Mk.
accordingly.
Guy
Old May 31st 04, 05:01 PM
Alistair Gunn
WalterM140 twisted the electrons to say:
were gambling they could induce the Argintines to attack incorrectly.
Not very prudent.
The reason the Argentines came in low was Sea Dart, and the reason they
knew to come in at low to beat Sea Dart[1] was because they had two Type
42s of their own. However it's only prudent to assume that it if someone
sells you military kit that the version they sell you isn't as good as
the one they use themselves, so they might have been concerned that a
pop-up attack would have left them fatally exposed to Sea Dart[2]?
[1] Though I believe they was a successful engagement with Sea Dart
against a target at 50 feet?
[2] Though, IRIC, the Type 42s (and HMS Bristol) where never deployed
into San Carlos Water.
These opinions might not even be mine ...
Let alone connected with my employer ...
Old June 1st 04, 09:14 AM
Guy Alcala
Not very prudent.
Yes, in open water. Exeter claimed to have shot down at least one and
possibly two A-4Cs of Grupo 4, during the combined SuE/A-4 attack on 30? May
in which the Argentines believe (or claim to) that they hit HMS Invincible,
while the Brits say they never got close and actually overflew HMS Avenger,
missing her.
Correct, although Antrim's Sea Slug also limited them somewhat. As a
practical matter, neither Sea Slug or Sea Dart was a factor in/around San
Carlos Water, as the Argentine a/c were coming in 50-100 nm on the deck; any
pop up would have been to clear the hills around the water, leaving far too
little time for the radar-guided area SAM systems to acquire. Exeter shot
down a Learjet while in SCW, but that a/c was cruising at 40,000 feet.
Coming in as low as the fighter-bombers did essentially limited the
engagements to visual detection/acquisition/tracking; even the Sea Wolf ships
usually had insufficient time to fire using radar control when inshore.
Rapier, OTOH, might well have done considerably better if the FAA had gone in
for pop-up dive attacks.
Guy
Old June 2nd 04, 06:43 PM
Alan Minyard
Not very prudent.
I have often wondered why the Brits did not use manpads. Were they unavailable?
Al Minyard
Army ends 20-year helicopter program Garrison Hilliard Military Aviation 12 February 27th 04 07:48 PM
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 0 December 7th 03 08:20 PM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 06:48 PM
Ungrateful Americans Unworthy of the French The Black Monk Military Aviation 62 October 16th 03 08:05 AM
