club resources
Old March 17th 09, 05:14 PM posted to rec.aviation.soaring
Brad[_2_]
Default club resources
When a soaring club provides towplanes to a regional or national
contest, how is a club typically compensated for loaning out their
equipment, or are they?
Is a contest and the use of a club towplane by non-club members seen
as a "commercial" operation? And if so, does the towplane need a 100
hour inspection to be legal?
How are tow fees assesed so that contestants, who are probably not
members of the club providing the towplane, pay a fair amount so that
club members are not subsidizing their tow fee?
Brad
Old March 18th 09, 12:18 AM posted to rec.aviation.soaring
Micki
Brad
Brad,
each contest manager has their "own" concepts of how the tow plane
thing works...I can only tell you what I do in the west (arizona,
utah, and new mexico). I will also preface this by telling you that I
overly compensate my tow pilots, because without them you can't have a
contest!
new SSA sanctioning rules require a million dollar liability insurance
policy paid for by the plane owner, with the pilot listed.
I pay for one tank of gas fuel (ferry fee)
i pay the pilots a standard fee for every single tow. Every contest
(sanctioned) has to keep a record of every tow plane, every glider,
and every time each was towed.
I also pay for lodging for my tow pilots
I also pay for catered event meals for my pilots
Oh, I also give each of my tow pilots a free contest t-shirt.
Every day after the launch, I go over my tow log with each tow pilot
to make sure we agree. At the end of the contest, I pay them the set
amount per tow and the tank of gas.
The Tow planes do not have to be insured as a "commercial" operation,
as long as they have a liability insurance policy. I calculate the
tow fee amount based on the gas required to launch, drop tow at 2,000
agl, and return.
Some contests charge their contestants per tow, and transfer the money
to the tow pilots, some contests just charge a standard amount to the
contestants, and then work separate deals with their tow pilots. (the
amounts you are allowed to charge for contest registrations and tows
are listed in the rules). If my calculations prove to be more than
the maximum allowed by the rules, then (and only then) I apply for a
contest waiver to charge what is necessary.
Also, I would recommend that you talk to some of the "chief tow
pilots" around the country with lots of experience. One of the ones I
recommend, is Bob Lynn out of Colorado. They can guide you as to the
requirements, and what they recommend. Also, John Seaborn has been
writing a contest manager's organization guide that is absolutely
wonderful, and can help new contest organizers. Also, there is always
the option of getting an experienced contest manager to train you in
your first contest.
I hope this helps
Micki
Old March 18th 09, 05:32 AM posted to rec.aviation.soaring
noel.wade
Micki -
This is a bit of a subject jump - but where would one find John
Seaborn's guide? We're trying to encourage some folks to try a "mini
contest" out in Ephrata this spring/summer (18m Nats are preventing a
normal Regional there this year)... But the "mini contest" is being
put on largely by folks that have never run a contest before, so any
organizational guide or "CD/CM manual" would be great!
Thanks, take care,
--Noel
Old March 18th 09, 12:42 PM posted to rec.aviation.soaring
Brad
Use of club tugs at contests is now an available endorsement under the
SSA insurance program. Our club policy has it and it was automatic
this year on renewal.
That said, current concensus is that this is a "for hire" situation
and the insurance company expects that pilots flying will have the
appropriate certificate and that the tug will have appropriate
inspections for this use(read 100 hr). BTW- if you do annual every 100
hr, you can roll these over and never have this concern.
There is some ambiguity in resposes by FAA related to certificates
required, but the prudent thing to do is to use commercially rated
pilots. This is clearly what the insurance company expects.
Currently approved tow rates for contests should create no financial
issues for tow providers.
Good Luck
UH
Old March 21st 09, 11:30 AM posted to rec.aviation.soaring
HL Falbaum[_2_]
Brad
Good Luck
UH
UH---
Where did the consensus come from? Clearly charging for tows makes it "for
hire". Is there consensus as well about towpilot required certificates.
FAR 61.113 "Private Pilot Privileges" list exceptions to the "no
compensation" rules. Sub Paragraph (g) allows "towing a glider".
It is totally unequivocal, and the sentence structure is plain. This is in
contrast with the sentence structures referring to qualifications of a
towpilot, in another paragraph.
We have run into a problem due to this for the upcoming 15m Nationals at
Cordele. We have, with some difficulty, finally rounded up enough Commercial
rated towpilots, but it will cost more ferry fuel.
I have sought clarification via the SSA Government Liason Committee and they
are working on it.
Hartley Falbaum
"KF" Georgia, USA
Old March 22nd 09, 07:22 AM posted to rec.aviation.soaring
CindyASK
Brad
SNIPPED.
are working on it.
Hartley Falbaum
"KF" Georgia, USA
It seems possible that a couple folks are fishing either separately
or collectively for information, or speculating.
Brad:
How is a club towplane compensated? By a check for US dollars.
Is a club-tug towing in a contest a “Commercial operation”?
According to typical arrangements and typical insurance, yes.
Does the tug then need a 100-hour inspection? No.
How are tow fees assessed so the club isn’t subsidizing a contest?
Ask your club’s officers. Costs are different across the US.
Private Pilot Towing
I was contacted following some local conversations about an
interpretation
of the FARs as a part of the Governmental Liaison Committee for SSA.
The question posed to me was whether or not a Private pilot could be
“compensated” for towing at a contest….
In the example given,
“could the Private certificate tow pilot be provided meals or
lodging?”
I cited 61.113(g) as the FAR in play. I also read it as a very
simplistic
sentence, which I had observed change in an FAR update in about 2004.
Based on the 2004 documents published with that change, I believed it
was
a pretty plain conclusion that private pilots could tow and be
compensated.
I also warned the contest organizers raising the issue that the
FAR may not be the most limiting consideration. The tow plane’s
Insurance coverage would likely be the most restrictive document
on the subject of which human may provide service to whom.
In the dark ages, private pilots couldn’t tow anything. A Chapter
(which
is no longer in existence in Region 8) asked for help from SSA.
They couldn’t find enough Commercial pilots and sought relief.
SSA helped. SSA negotiated a waiver from the FAA, to allow club
operations to use Private pilots -- if the pilots did not use the
accumulation of flight time toward a furtherance of ratings.
Accumulating flight time was considered by FAA to be
“compensation”, as total time has value toward aviation employment.
The waivers continued for many years, until the FAA decided there was
NO safety issue under this SSA-initiated-documented program. Rather
than continue wavier extensions, they changed the privileges of
Private pilots in 1997 to allow glider towing, and noted that time
could be accrued. But the FAA was silent on other forms of
compensation. This was another instance of SSA’s action
benefiting all US glider ops, not just “members”.
In 2004, FAA rewrote Part 61 again, to include towing of ultralight
vehicles under Sport pilot and Light Sport Aircraft rules. At that
time, in the comments of adoption, the FAA stated that Private
pilots were indeed allowed to tow gliders for compensation and
hire (their words, not mine). But the FAA declined to extend
that privilege to Sport or Recreational pilots.
The FAA referred to 61.113(g).
Since a few folks in SSA disagreed with my recent answer,
and talked to a person in FAA who agreed with them, SSA has
sent a formal letter to the FAA to ask for an interpretation of
61.113 (g). I don’t anticipate SSA getting an answer to that
letter before most, if not all, of the 2009 soaring season is
completed.
The SSA Group Insurance Program was modified to include Private
pilots towing internally to the club’s operations many years ago.
Private pilots were insured to operate club tugs, including towing
club members giving rides for hire or instruction.
Meanwhile, soaring goes on.
100-Hour Inspections
As far back as the late 1970’s SSA did receive a formal FAA letter
of interpretation that states that towing a glider is specifically
NOT carrying passengers. If your towplane:
1) does NOT give flight instruction for hire,
2) does NOT carry passengers for rides
(for this you need drug testing, etc. see Part 136 Air
Tours),
then the tug does NOT need 100-hour inspections. Save some club/
school bucks.
If you are training tow pilots, that doesn’t require a CFI-A trainer.
The trainee is part of the tug flight crew, not a passenger.
No 100-hour is required. Usually, this operation IS included in SSA
Group coverage. (Check your tow pilot’s recent experience needs
for 2009, as this is formally Spring now. FAR 61.69 (a) 6.)
Contest Towing
Who can tow at contests?
SSA contest rules don’t specify anything but a liability
insurance requirement for each tug, and FAR compliance.
SSA contest rules do set the maximum entry fees, and the
maximum value calculated for tow fees, adjusted annually
to reflect current costs. If the fees didn’t meet tug expenses,
contests wouldn’t get launched.
The SSA Group Program was recently modified to include
club tugs towing at SANCTIONED contests, provided they were
using Commercial tow pilots, and the tugs and pilots could be
paid at any exorbitant rate they could negotiate
(my tongue is firmly in-cheek here, folks.)
Contest staff is charged with being certain their contracted tugs
are operated within their coverage. Could a tug owner have
liability coverage, and the insurance include a Private pilot towing?
Sure. But that isn’t a very likely scenario.
Fly safely, and renew your SSA membership.
Cindy Brickner
Old March 23rd 09, 01:00 PM posted to rec.aviation.soaring
Brad
Good Luck
UH
UH---
are working on it.
Hartley Falbaum
"KF" Georgia, USA
Maybe concensus is the wrong term , but I don't know of any contest
organizer, and several have been looking at this including you, that
see a way around the insurance company interpretation that contest
towing is for hire and from their point of view , a commercial
operation.
This does NOT mean that their position agrees with the applicable
FAR's and official interpretations of them.
The SSA underwriters took a big hit from thr Toanapah accident and I
assume this affects their thinking in risk management.
It certainly does make it harder for all of us in the contest system
to keep the sport affordable and accessible.
UH
Mountain Flying & High-Performance Resources? Chris G. Piloting 5 December 13th 05 10:00 AM
Simulation Resources Database Tom Allensworth Simulators 2 September 27th 04 01:02 AM
Trying to find resources on tanker history Bjørnar Bolsøy Military Aviation 24 June 2nd 04 02:36 PM
Cheapest Club (was Best Gliding Club Website) Clint Soaring 20 November 15th 03 04:49 AM
Flight Sim Resources! LPA Simulators 0 September 7th 03 07:40 PM
