Zaon MRX causing radio interference
Old March 24th 09, 07:58 AM posted to rec.aviation.soaring
Default Zaon MRX causing radio interference
With my new Zaon MRX PCAS mounted on top of my glare shield, I've been
experiencing some radio interference and linked this to the MRX: the
radio gives white-noise static -- like the squelch is not properly
adusted. When I turn the MRX off it goes away.
I've heard putting a "ferrite core" around the MRX's (and the
radio's?) power cord might help. (Here's one:
http://cgi.ebay.ca/Noise-Filter-Clip...QQcmdZViewItem
Does anybody else have this problem? Have you solved it in some way?
Eric
DG-300
Old March 24th 09, 01:30 PM posted to rec.aviation.soaring
jcarlyle
JJ Sinclair reported an MRX/radio interference problem several years
ago on this forum. When I installed my MRX in my panel I took the
precaution of installing a ferrite bead around the power cable, and
I've had no interference problems. It's good electrical practice to
use ferrite beads on DC supply leads. If you can, loop the power cable
so it goes through the ferrite core more than once in order to get the
best high frequency attenuation.
-John
radio's?) power cord might help. (Here's one:http://cgi.ebay.ca/Noise-Filter-Clip...QQitemZ3501565...
Eric
DG-300
Old March 24th 09, 02:01 PM posted to rec.aviation.soaring
qflyer1
I have the same problem. I also had the problem with the previous
model. I did the ferrite bead and it didn't do the job.
I finally sent it in and they replaced the power mosfet and that did
the trick.
I'm about to send this one in for a firmware upgrade and to deal with
this issue. Hopefully the same way.
Cheers,
Tim
1FL
radio's?) power cord might help. *(Here's one:http://cgi.ebay.ca/Noise-Filter-Clip...QQitemZ3501565...
Does anybody else have this problem? *Have you solved it in some way?
Eric
DG-300
Old March 24th 09, 03:30 PM posted to rec.aviation.soaring
Darryl Ramm
On Mar 24, 6:01*am, qflyer1 wrote:
On Mar 24, 2:58*am, wrote: With my new Zaon MRX PCAS mounted on top of my glare shield, I've been
the trick.
Cheers,
Tim
1FL
Eric
DG-300
Make sure you are installing a large enough ferrite bead (beads is
slang, fat walled cylinders might be a better description) that allows
the power cable to go through the middle and be wrapped around the
outside several times. Use a thin gauge wire cable to help with this
and the bead can still be small and allow you to feed the cable
through several times. It may be worth trying to installing this close
to the Zaon end of the power cable if it does not work elsewhere.
Darryl
Old March 24th 09, 10:47 PM posted to rec.aviation.soaring
qflyer1
the trick.
Cheers,
Tim
1FL
On the previous model I did wrap several turns on the bead. Only
sending it in fixed the problem.
On this one, I'm not wasting my time. I'm awaiting my rma # as I
write.
Seems to me whatever power supply, or downstream component, design
they used before is the same now.
Tim
Darryl
Old March 24th 09, 08:57 PM posted to rec.aviation.soaring
jcarlyle
Tim, that's very interesting. I have a friend who bought a MRX last
summer. While flying with him last fall I noticed that his MRX was
misreading the altitude of the tow plane. He's planning on sending it
in, but what with his problem and now yours I wonder if there was a QC
problem at Zaon last year. Don't get me wrong, I love my unit and I
know several that are performing exactly as they should - but they're
all older units.
-John
the trick.
Old March 24th 09, 09:11 PM posted to rec.aviation.soaring
Darryl Ramm
all older units.
-John
[snip]
By how much? And just compared to the towplane? The altitude of the
towplane sent to the Zaon is digital. So it is unlikely to "misread"
it. It uses it's own internal altimeter to calculate the relative
altitude. I would hope they agree to 100' or so. One issue is the Zaon
pressure sensor is exposed to ambient cockpit pressure and not the
static line pressure, so opening and closing vents/speeding up etc.
might affect the relative altitude it displays. If the difference is
more than a few hundred feet I'd next suspect the pressure sensor in
the Zaon.
It may be worthwhile before sending the Zaon back to compare what the
Zaon says to another aircraft that has a transponder that shows the
encoder's pressure altitude and play with opening and closing vents.
Of course if it is just the tow plane then it's encoder may also be
faulty, or maybe it really is an RF related problem that only happens
when close to the other transponder (but unlikely).
Darryl
Old March 24th 09, 09:49 PM posted to rec.aviation.soaring
jcarlyle
It was 300-400 feet off, sometimes above and sometimes below us - and
we were doing a normal tow, not boxing the wake. Vents were closed (it
was 35 degrees F on the ground before takeoff). Hopefully he and I
will be able to fly together within the next month. I've got a Becker
ATC4401 that reports the encoded altitude, so we'll be able to compare
that with his MRX in real time at different separation distances and
heights.
-John
the Zaon.
Darryl
Old March 24th 09, 11:33 PM posted to rec.aviation.soaring
Eric Greenwell
heights.
Does his glider have a transponder in it?
Do you know that the towplane encoder was working correctly?
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Old March 26th 09, 03:00 PM posted to rec.aviation.soaring
Andy[_1_]
heights.
The MRX internal baro altitude is both displayable and adjustable. It
should not require any other equipment, except an accurate altimeter
set to 29.92, to determine if the problem is the MRX baro sensor.
Andy
Flight computer - radio interference cernauta Soaring 3 August 1st 08 03:37 PM
FM radio interference from planes rb Piloting 34 July 19th 06 06:53 PM
GPS / radio interference Cub Driver Piloting 2 October 31st 04 11:57 PM
radio / vario interference - HELP! Chris Davison Soaring 13 November 3rd 03 07:09 AM
Radio Interference Information Ross Richardson Piloting 0 October 17th 03 03:06 PM
