Turnpoint File Management
Old March 29th 09, 03:43 PM posted to rec.aviation.soaring
Papa3
Default Turnpoint File Management
So, I now have multiple loggers (an older CAI Model 20 and an EW
Microrecorder). I've got all of my task planning set up on SeeYou.
SeeYou can export waypoints and tasks in multiple formats. So far so
good.
Now, the problem. The older CAI can only handle 250 waypoints. There
are more than 500 waypoints in my file. I have a long task which
isn't conveniently laid out such that a "four corners" approach can
restrict me to only those turnpoints relevant to the task (it's a long
triangle). I don't see any way in SeeYou to conveniently restrict
the output of the CAI format file to only those points that fall
within the task area.
Anyone have any ideas? I'd prefer to find a way to use SeeYou for
this to avoid having multiple versions of the files floating around,
but I'm open to other options...
Erik Mann
LS8-18 P3
Old March 29th 09, 04:03 PM posted to rec.aviation.soaring
Andy[_1_]
Microrecorder). * I've got all of my task planning set up on SeeYou.
SeeYou can export waypoints and tasks in multiple formats. *So far so
good.
Now, the problem. * The older CAI can only handle 250 waypoints. There
are more than 500 waypoints in my file. * I have a long task which
triangle). * I don't see any way in SeeYou to conveniently restrict
Anyone have any ideas? *I'd prefer to find a way to use SeeYou for
Erik Mann
LS8-18 P3
Why do you need any turnpoints in the CAI 20? Are you using it for
navigation? I have a model 25 and it still has an old turnpoint file
from probably over 10 years ago. All it does it is make it beep when
I fly over Aguila which used to be the first turnpoint in our local
database. Not having a current database does not prevent the CAI from
being used as a (in my case backup)logger.
Andy
Old March 29th 09, 04:32 PM posted to rec.aviation.soaring
Mozarella.org
Hi Erik,
There are several ways to do that. The waypoints that are selected when you
do a "Save" will be included in the file. Please see the training video #29
"Exporting Waypoints" in the link below.
http://www.cumulus-soaring.com/train...raining-SeeYou
Let me know if that doesn't work for you.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
"Papa3" wrote in message
good.
Erik Mann
LS8-18 P3
Old March 29th 09, 05:15 PM posted to rec.aviation.soaring
Papa3
On Mar 29, 11:32*am, "Mozarella.org" wrote:
Hi Erik,
There are several ways to do that. *The waypoints that are selected when you
do a "Save" will be included in the file. *Please see the training video #29
"Exporting Waypoints" in the link below.http://www.cumulus-soaring.com/train...raining-SeeYou
Good Soaring,
Paul Remde
good.
Erik Mann
LS8-18 P3- Hide quoted text -
- Show quoted text -
Paul,
Awesome. Iterative passes at shift and drag gave me exactly what I
wanted. Many thanks!
P3
Old March 29th 09, 04:36 PM posted to rec.aviation.soaring
Tuno
Erik,
You're not using the CAI for navigation, right? The only reason you'd
need turnpoints in there is for electronic declarations for badges and
record attempts. So for those, just put in the ones you need for that
purpose.
What do you use for navigation?
2NO
Old March 29th 09, 05:02 PM posted to rec.aviation.soaring
Papa3
On Mar 29, 11:36*am, Tuno wrote:
Erik,
purpose.
2NO
What can I say... I'm old-fashioned (read: Cheap). Yeah, the primary
NAV in P3 is the Model 20 communicating to an old Compaq Aero running
GNII. I want the primary declaration to be in the Model 20 along
with all of the landing points within the triangular task area. The
EW will be the "dumb" backup with an exact duplicate of the
declaration.
What I was hoping someone would say is "Oh sure, there's an option in
SeeYou mysteriously hidden under some non-intutitive submenu to
'select waypoints within task area'". I can dream...
I do know a brute force way around this, but i'd prefer not to have to
semi-manually go in and pick the landpoints.
Old March 29th 09, 08:53 PM posted to rec.aviation.soaring
5Z
On Mar 29, 10:02*am, Papa3 wrote:
What can I say... I'm old-fashioned (read: Cheap). *Yeah, the primary
GNII. * I want the primary declaration to be in the Model 20 along
You still don't need to have any waypoints in the Model 20. I used to
have a setup like that in my old ship and had a whole lot more than
250 waypoints in the Aero, and none in the '20. When I'd declare a
task in GNII, it would upload the needed waypoints into the Model 20.
That was back in 2000, so my memory might be a bit foggy, but an
pretty sure that's how I did it.
-Tom
Old March 30th 09, 01:28 AM posted to rec.aviation.soaring
JS
Erik, you're on to the right way of doing it. Don't rely on a PDA to
remain connected to the logger. They can fail, and also pilot errors
such as finding as you load up the glider that you left the PDA at
home are not unheard of.
(Such foolishness could be a reason I always have a panel-mounted GPS
display too.)
Old March 30th 09, 05:44 PM posted to rec.aviation.soaring
Papa3
You still don't need to have any waypoints in the Model 20. *I used to
250 waypoints in the Aero, and none in the '20. *When I'd declare a
-Tom
Hi Tom,
Yes and no. It will load the points. However, it can be a "creaky"
solution. I had at least one record flight squished when I went to
load special use airspace after the task had been declared. I did
this in flight, and sure enough, it tried to reload all of the
waypoints but stopped at 250. Unfortunately, one of the ones
required for the task wasn't there, and it then threw some sort of
"invalid task" error. I just want to make sure that I have one and
only one file to use and that everthing is nice and neat before
takeoff.
Frankly, I'm doing this out of an "excess of caution", as I will make
sure that the backup logger and main logger have the same task
declarations, and it's a flight I can fly without really needing the
PDA.
P3
Old March 30th 09, 08:56 PM posted to rec.aviation.soaring
Eric Greenwell
PDA.
Are you allowed to have two declarations? Or do you need a paper
declaration if you want to use more than one logger?
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Waypoint/turnpoint files [email protected] Soaring 6 March 7th 08 04:23 PM
Turnpoint database [email protected] Soaring 6 November 11th 05 11:11 PM
Turnpoint conversion SW? For Example John Smith Soaring 11 March 23rd 05 06:56 PM
Turnpoint descriptions Tuno Soaring 5 June 27th 04 02:41 PM
FAI turnpoint Question Mark Grubb Soaring 13 February 15th 04 02:31 AM
