I'm having difficulty getting the portrait driver to correctly work on
my 310. I've followed the installation and uninstallation directions as carefully as possible, but continue to get only half a screen in protrait after the install. I've tried to join the Naviter forum to clear this up there, but have not had my confirmation email or any response to going through the "so you haven't gotten your confirmation email" process either, so I'm reduced to ras. Any help is appreciated, as this thing is clearly way smarter than I am... -Paul |
On Apr 1, 7:15*pm, sisu1a wrote:
I'm having difficulty getting the portrait driver to correctly work on my 310. I've followed the installation and uninstallation directions as carefully as possible, but continue to get only half a screen in protrait after the install. I've tried to join the Naviter forum to clear this up there, but have not had my confirmation email or any response to going through the "so you haven't gotten your confirmation email" *process either, so I'm reduced to ras. Any help is appreciated, as this thing is clearly way smarter than I am... -Paul Have you considered just running it in landscape mode? The difference in device width is less than an inch. Not to mention being free of the troublesome portrait driver. |
I'm having difficulty getting the portrait driver to correctly work on my 310. I've followed the installation and uninstallation directions as carefully as possible, but continue to get only half a screen in protrait after the install. I've tried to join the Naviter forum to clear this up there, but have not had my confirmation email or any response to going through the "so you haven't gotten your confirmation email" *process either, so I'm reduced to ras. Any help is appreciated, as this thing is clearly way smarter than I am... -Paul Here's a short thread on the issue you're having : http://www.naviter.si/component/opti...8/topic,3366.0 No need to sign up. You can read all the forum threads as a guest. |
On Apr 1, 5:15*pm, sisu1a wrote:
I'm having difficulty getting the portrait driver to correctly work on my 310. I've followed the installation and uninstallation directions as carefully as possible, but continue to get only half a screen in protrait after the install. I've tried to join the Naviter forum to clear this up there, but have not had my confirmation email or any response to going through the "so you haven't gotten your confirmation email" *process either, so I'm reduced to ras. Any help is appreciated, as this thing is clearly way smarter than I am... -Paul Hi Paul I am running Henryk Birecki's GPS_LOG on an i310 with the screen rotation driver from Klaus-Peter Renner. This driver can rotate 90deg or 270deg. I use 270deg to have the wiring and thumbwheel on top. The screen rotation driver just runs under WinCE, so I guess it could work with other applications too. You can contact me outside this forum or check out the GPS_LOG Yahoo group. You can find my email address in the WestWind.(don't use this gmail addres) It works pretty well. Hans Van Weersch 3U |
| Thread Tools | |
| Display Modes | |
| XC-Soar and HP310 / HP314 (Euro) | Jim White[_3_] | Soaring | 12 | January 31st 09 05:54 AM |
| mSeeYou and HP310 (USA) | Tuno | Soaring | 4 | January 21st 09 03:07 AM |
| HP310 and XCSoar | Jim White[_3_] | Soaring | 2 | January 14th 09 07:15 PM |
| [07/10] - 10 Ubiquitous Self Portrait.JPG (1/1) Part 7 - last | Waldo.Pepper[_2_] | Aviation Photos | 0 | September 16th 08 04:29 AM |
| Alan B Shepard Jr portrait S63-02082.jpg | [email protected] | Aviation Photos | 0 | April 7th 07 11:07 PM |
