Becker AR3201
Old April 5th 09, 01:49 PM posted to rec.aviation.soaring
Default Becker AR3201
Does anyone have experience with audio on transmit being heard over
the speaker?
It does not have intercom wired and we believe it is wired according
to available wiring diagram.
Have manual which has no troubleshooting section.
Have tried changing battery also.
Thanks UH
Old April 5th 09, 03:00 PM posted to rec.aviation.soaring
Roger Fowler[_2_]
We are running two AR3201's in our club gliders and have not seen this.
We did the installation ourselves. If you want to send your wiring
diagram, I will be glad to compare it to ours.
Roger
the speaker?
Thanks UH
Old April 5th 09, 03:40 PM posted to rec.aviation.soaring
Rex
UH,
You are probably hearing the side tone. This is what you want when
using a headset. Try this:
On the side of the radio is a hole with a sidetone adjusting pot
labled with a headset pictogram. Use a screwdriver and turn the screw
inside the hole. The other hole is for adjusting squelch threshold.
Rex Mayes
Williams Soaring Center
the speaker?
Thanks UH
Old April 5th 09, 07:27 PM posted to rec.aviation.soaring
On Apr 5, 10:40*am, Rex wrote:
UH,
You are probably hearing the side tone. *This is what you want when
labled with a *headset pictogram. Use a screwdriver and turn the screw
inside the hole. *The other hole is for adjusting squelch threshold.
Rex Mayes
the speaker?
Thanks UH- Hide quoted text -
- Show quoted text -
That was it- way too easy.
Thanks Rex!
UH
Old April 6th 09, 11:15 PM posted to rec.aviation.soaring
Johan Nykvist
Hi!
I have owned 2 becker 3201, If I can remember, it must be wired in a
special way to get the mic output to the speakers..
Im pretty sure its the wireing that is the problem.
It can be a bit hard to follow up the d-sub connections..I know.. I did
hard work to get the same prolem as you have. But I wanted that in my
previous aeroplane. :-) (it had a noice maker in the front lol)
Best Regards
Johan Nykvist, Sweden
the speaker?
Thanks UH
FS: Becker Transponder Fox Two Soaring 2 October 29th 10 11:55 PM
AR3201 Harness? noel.wade Soaring 13 March 10th 09 02:23 PM
Wanted: Becker AR3201 Ira Blieden Soaring 0 December 14th 06 06:28 PM
Looking for a Becker AR3201 Ira Blieden Soaring 0 December 8th 06 01:38 PM
Becker radio AD Tom Serkowski Soaring 3 November 2nd 04 01:43 AM
