OLC question
Old April 13th 09, 03:30 AM posted to rec.aviation.soaring
Sam Discusflyer[_2_]
Default OLC question
Looking at April 11th, some flights have # positions and others do not. The
ones without a # are also faded.
Can anyone explain?
Thanks SAM
Old April 13th 09, 04:45 AM posted to rec.aviation.soaring
M C
Usually there is a bad IGC file or the flight is not the minimum distance
to be scored.
The
Can anyone explain?
Thanks SAM
Old April 13th 09, 12:16 PM posted to rec.aviation.soaring
Yannick
If your flight is saved with a non-appproved logger, you'll also have
it faded.
More info he http://www.onlinecontest.org/olc-2.0...les#olc,league
First paragraph 1. Documentation and also http://www2.onlinecontest.org/validate.php.
The latest page doesn't seem to be up-to-date as XCSoar is now part of
the approved software.
Yannick
to be scored.
The
Can anyone explain?
Thanks SAM
Another 302 question... [email protected] Soaring 12 June 21st 07 03:49 AM
Question ?? Thomas Buyea Piloting 4 June 20th 07 07:52 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
