Cambridge 302 Question
Old April 19th 09, 09:51 PM posted to rec.aviation.soaring
Default Cambridge 302 Question
I've have a Cambridge 302 in my glider. I have the setting at 0%
since I have the total energy probe fed into it, along with the pitot
tube and static port. The te tube is split just behind the cockpit as
recommended. The static and pitot are split or "t'd" behind the
instrument panel.
When I push hard forward to increase airspeed.....the cambridge VSI
goes up to 10knots positive.
Then when I pull back to bleed off airspeed.....the VSI goes down to
10 knots negative.
The manual says to increase the % , but doesn't say how much.
Another option is to not use the te tube and put it at 100%.
The te probe in my glider is located about 6 feet behind the wing spar
on the top of the fuselage. It's not the conventional spot on the
rudder.
Any thoughts? Recommendations?
Old April 19th 09, 10:27 PM posted to rec.aviation.soaring
Darryl Ramm
On Apr 19, 1:51*pm, wrote:
I've have a Cambridge 302 in my glider. *I have the setting at 0%
tube and static port. *The te tube is split just behind the cockpit as
recommended. *The static and pitot are split or "t'd" behind the
instrument panel.
10 knots negative.
on the top of the fuselage. *It's not the conventional spot on the
rudder.
Any thoughts? *Recommendations?
Yep, pretty easy. Normally you would just change the % compensation
until it behaves as you want. But then normally you would need little
if any electronic compensation.
You say it's a fuselage mounted probe, there is nothing wrong per se
with fuselage mounted TE probes, Dick Johnson spent time trying to
point that out.
Presumably you have a mechanical vario and capacity flask on the other
side of the split TE line. Does that mechanical vario seem to behave
correctly? If so the problem is at the Cambridge 302, and that 302
should not need huge compensation adjustments (normally none).
Check the plumbing carefully, it might be as simple as you actually
have the static and TE lines crossed at the Cambridge (that would be
the first thing to check - don't rely on the color or the tubing etc.
(it might be spliced wrong you cant' see) really check there is a air
pressure connection by blowing gently onto (not into!) the TE probe).
Also simplify the problem. Block off any ports you really don't need.
Check all connections carefully, etc. Block the other side of the TE
line where it splits. Double check that the IAS and pressure altitude
on Cambridge all look OK (long shot but it may show up a problems).
If you start to suspect the Cambridge, try just sticking it on the
static line with 100% compensation and see what it does. But this
really should not be needed.
Darryl
Old April 19th 09, 10:34 PM posted to rec.aviation.soaring
instrument panel.
10 knots negative.
rudder.
point that out.
Check all connections carefully, etc. Block the other side of the *TE
Darryl- Hide quoted text -
- Show quoted text -
I have all new tubing and new capacity flasks. The other two
mechanical VSI seem to work well. The cambridge works well
too....unless I push forward to speed up or pull back fast to slow
down.
Does the 100% compensation and the two static line system work ok?
SA
Old April 19th 09, 11:53 PM posted to rec.aviation.soaring
instrument panel.
10 knots negative.
rudder.
Scott,
Go to screen 10 on the CAI 302 and note the indicated airspeed. You
may have the Pitot & static switched. Which mode are you in when this
happens climb or Cruise?
At TE probe requires that the Compensation be set at 0%. The Probe
supplies the Compensation.
Richard
www.craggyaero.com
Old April 20th 09, 12:10 AM posted to rec.aviation.soaring
Darryl Ramm
instrument panel.
10 knots negative.
rudder.
point that out.
I have all new tubing and new capacity flasks. *The other two
mechanical VSI seem to work well. *The cambridge works well
down.
SA
All new tubing and all new capacity flasks probably leak more often
than all old tubing and all old capacity flasks that have not had all
new fingers poking around in them :-)
Three varios? The TE line is split three ways beyond the seat and the
two mechanical varios have their own capacity flasks right? The reason
for splitting beyond the seat is just to give some line impedance so
that the flow to/from the capacity flasks does not significantly
affect the direct pressure reading 302.
The electronic compensation and a static source works very well on a
C302. I use that on mine, it provides a separate vario independent of
the TE. However it is only as good as the static and pilot sources. I
know Cambridge (Dave Ellis?) previously argued that a good TE probe
was better than electronic compensation, but I can't tell the
difference.
However your ships seems to have something going wrong and instead of
just changing things I personally would work out what the problem is
first.
I had misread the direction of the vario change when you said you
pushed/pulled. So the other poster's suggestion that you have a big
leak may be more likely. Does the behavior of you speed up/slow down
test depend on the cockpit vents being full open of closed. If you
were flying with the vents mostly open, speeding up could raise
cockpit/fuselage internal pressure, causing a false climb indication.
Has a tube fallen off somewhere? Is a right angle or "T" adapter
cracked or fallen apart entirely. Are any lines blocked off, are the
stoppers really secure/airtight? Do you have something else
misconnected somewhere so that the TE line is actually open to the
ambient cockpit pressure. Have you checked the tube has not fallen off
the TE probe? Try making the circuit as simple as possible and remove
any split behind the seat (in case you have a huge leak in a capacity
or other vario case - unlikely though - if those other varios seem to
work - but it is not clear if they actually show a climb when they
should or if you are just saying they don't show false speed relate
readings). If they don't show a climb when they should you could have
a huge leak on the mechanical vario side that (in a stretch) could
explain this. Is there an alt static source behind the panel, is it
accidentally open? Is it plumbed in the correct line?
You may be too close to the problem. Have somebody else sanity check
what you have done and how you have debugged it. Be prepared to buy
them a beer when they walk straight up point out the "obvious"
error :-)
Darryl
Old April 20th 09, 07:59 AM posted to rec.aviation.soaring
Darryl Ramm
instrument panel.
10 knots negative.
rudder.
Scott,
Go to screen 10 on the CAI 302 and note *the indicated airspeed. *You
may have the Pitot & static switched. *Which mode are you in when this
At TE probe requires that the Compensation be set at 0%. *The Probe
Richardwww.craggyaero.com
To be clear, you can adjust the compensation when using a TE probe.
Normally a small percentage to correct compensation issues, but
usually not needed. The manual appears to say you *must* use 0 when
using a TE probe. But this is wrong. And the manual also contradicts
itself and explains you can do this tweaking. But none of that is of
course related to the problem described here.
Darryl
Old April 20th 09, 08:05 AM posted to rec.aviation.soaring
Darryl Ramm
instrument panel.
10 knots negative.
rudder.
Scott,
And that was a clever suggestion - pitot and static swapped and the
302 in cruise mode and configured to be a super netto or netto vario
so the indicator relies on the airspeed....
Note to Scott - the altimeter display on the 302 home screen has
nothing to do with the static plumbing, it senses cockpit ambient
pressure, so is cannot help debug this question. So try what Richard
suggests.
Darryl
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 03:51 AM
Cambridge 302A/303/SNav question Bob Soaring 7 November 26th 06 03:46 PM
Cambridge Fuse Question Brian Iten Soaring 9 January 4th 05 02:43 PM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
