Hello there, I just have a question you might be able to help me with
if you have the time, I am wiring a 46 stinson From Scratch using cessna applications and was wondering if the clock is wired to the power buss so it has to be set every time as the buss is only hot when the relay is activated or is it on the other side of the master relay so it will run all the time, as the new clock instructions just say red to poss and black to neg, Thank you for any help you may be able to give, Brad |
You can find the wiring diagrams in the service manual. Check out this site:
http://www.airplanemanuals.com/Manuals/Cessna/C172-175/ Scott Wilson |
On Apr 22, 2:03*pm, goldaussy wrote:
Hello there, I just have a question you might be able to help me with if you have the time, I am wiring a 46 stinson From Scratch using cessna applications *and was wondering *if the clock is wired to the power buss so it has to be set every time as the buss is only hot when the relay is activated or is it on the other side of the master relay so it will run all the time, as the new clock instructions just say red to poss and black to neg, Thank you for any help you may be able to give, Brad I had a powered clock added to my PA28. Since it was fully digital, its power consumption was virtually zero so the shop wired it directly to the battery side of the buss. They used an inline fuse to protect against potential short circuits. |
Clock | Tom Cummings | Owning | 12 | March 28th 05 06:56 PM |
Daytron clock? | Hankal | Piloting | 0 | May 24th 04 12:55 AM |
Best Clock? | Jay Honeck | Owning | 26 | February 25th 04 05:35 PM |
FA Wakmann eight day clock | Steve | Aviation Marketplace | 0 | January 1st 04 10:27 PM |
A-10A clock repair | vlad | Aviation Marketplace | 0 | September 16th 03 05:55 AM |
