Hi all,
Beginner student here again. ![]() The weather during my last training session was overcast with ceiling at 2,500 ft. Right after our last tow for the day to 2,000.....after the release and a turn or two....it started to rain, perhaps for just 5-10 seconds. I could see the rain drops on the canopy and see them pushed back by the relative wind. My instructor made no mention of it and I forgot to ask about it post landing. What are the implications about getting rained on in flight? Obviously, if the ceiling is 2500 and overcast, this is primarily a "training day." How should a glider pilot react to rain? How does it affect the control of the aircraft? How does one fly safely in the event or threat of rain? --Michael |
Michael,
First, welcome to soaring. All of us were beginners once, and it's great that you are asking questions. The things that come to mind with rain: Is there a possibility of lightning? If so, stay clear. Composite ships are especially prone to lightning damage and I seem to remember hearing of damage to the metal control linkages in one glider. High performance gliders will suffer more loss of L/D in rain due to their laminar flow airfoils -- which rain makes non-laminar flow, with higher drag. Will visibility stay VFR? Aside from seeing other traffic, is there any danger of loss of spatial orientation? A good general rule: If it feels dangerous, it probably is. At a minimum, err on the side of believing that until you confirm otherwise. Martin |
Rain on the wings will almost certainly increase the stall speed - by
how much depends on the particular airfoil. As a rule of thumb, older wood & fabric or metal gliders suffer only a little degradation, early glass (like my Open Cirrus) suffers quite a lot, newer glass suffers something in between. This means that if you are landing with wet wings you need a higher approach speed to retain the same safety margin over the stall. Your instructor will advise you (but maybe later in your training - now you've got too much to think about just following the tow plane). *Never* winch launch with wet wings, as this could lead to a stall and spin off the wire. I wouldn't aerotow with anything more than mildly damp wings either. |
There is also an illusion caused by rain on the canopy that makes the
glider appear higher than it is - causing the pilot to flare higher than normal. When you have rain on the windscreen, you should gently fly it on; it is a surprise when you find that the height you expect to touch the ground is not correct. Also, because you think you're higher, you tend to fly a lower approach, so add a few feet for obstacle clearance in rain. There will also be a tendancy for the inside of the canopy to mist up more, so open the vents. |
![]() What are the implications about getting rained on in flight? Obviously, if the ceiling is 2500 and overcast, this is primarily a "training day." How should a glider pilot react to rain? How does it affect the control of the aircraft? How does one fly safely in the event or threat of rain? --Michael Most of the time, light rain is not going to be troublesome with training flights as long as the visibility is good. However, take it from one who knows: Even light rain can be accompanied by an occasional downburst or or unexpected wind shear. You don't have to be actually caught in the downburst itself. A downburst near the field can result in a very rapid change in wind direction (shear). Not good if it catches you on landing or takeoff. I was getting checked out in a glass 2-seater for the first time. An instructor and I were doing takeoffs and landing in a Grob. A little light rain had started falling. Almost now wind. Ceiling was probably around 2000' but we were only towing to 800-1000. We were on the takeoff run on what was to be my last dual flight that day. We had just lifted off behind the Maul tug and airspeed was indicating about 70 (don't remember if it was knots or mph). Unexpectedly, the Maul plopped back down onto the runway, then we did the same. I glanced at the airspeed and it was reading 40! Then I noticed the trees tops whipping around. We were too close to the end of the runway at that point to abort and the Maul went up over the low trees at the end and we went with him. We immediately started descending into the valley and picked up some speed. We got rolled around pretty violently. The Maul driver got it more-or-less back under control, managed to start climbing, and expressed his surprise that we had not broken the tow rope in the turbulence. As we turned back towards the airport, things calmed down. We had been caught in a reversal of wind direction, apparently due to a downburst off the approach end of the field. |
On Apr 26, 9:36*pm, Michael wrote:
Hi all, Beginner student here again. * ![]() The weather during my last training session was overcast with ceiling at 2,500 ft. *Right after our last tow for the day to 2,000.....after the release and a turn or two....it started to rain, perhaps for just 5-10 seconds. *I could see the rain drops on the canopy and see them pushed back by the relative wind. My instructor made no mention of it and I forgot to ask about it post landing. What are the implications about getting rained on in flight? Obviously, if the ceiling is 2500 and overcast, this is primarily a "training day." *How should a glider pilot react to rain? *How does it affect the control of the aircraft? How does one fly safely in the event or threat of rain? --Michael When wet, some airfoils, such as found on the Pic-20, can turn your glider into a lawn dart... more like a hang glider than a slick glass ship.... maybe 15:1. And, associated with some rain can be some unpredictable and changing winds... strong down, strong up, headwind, crosswind, downwind. In my opinion, days that are overcast, and possibly rainy, should be left to the ducks, not gliding... much less training gliding. We might be eager to fly, and train, but haste can make waste... or worse. Think safety. Fly safe. 19 |
Then again, if you are training in a 2-33, a little rain will probably
increase your performance by washing some of the bugs and dirt off! Seriously, in a non-laminar wing (any metal trainer, pretty much), especially if it hasn't been waxed recently (and who waxes a 2-33 or a Lark!), light rain will have no aerodynamic effect. Biggest problem will be reduced visibility through the canopy, and less braking action if you land on grass. Obviously, stay away from heavy rain showers or thunderstorms, but pattern-bashing in a light, occasional drizzle beats watching birds fly. Good training, too. Kirk |
On Apr 27, 11:29*am, "
wrote: Then again, if you are training in a 2-33, a little rain will probably increase your performance by washing some of the bugs and dirt off! Seriously, in a non-laminar wing (any metal trainer, pretty much), especially if it hasn't been waxed recently (and who waxes a 2-33 or a Lark!), light rain will have no aerodynamic effect. *Biggest problem will be reduced visibility through the canopy, and less braking action if you land on grass. Obviously, stay away from heavy rain showers or thunderstorms, but pattern-bashing in a light, occasional drizzle beats watching birds fly. Good training, too. Kirk Kirk beat me too it! When you have an ugly crinkled metal wing bristling with rivets, a few raindrops are hardly going to matter from an aerodynamic perspective. The most important consideration is the type of cloud overhead producing the rain. Out here in the US west, there's a good chance it'll be a shower cloud or thunderstorm that may produce downdrafts and lightning - things to worry about a lot more than a few raindrops. If you are in western Europe where most of the rain comes from stratiform clouds, it's not so bad. Heck - if you live in some of the countries with the worst climate (Britain for example), flying in the rain is a necessary skill! Mike |
I also did some of my initial training in a 2-33 in the rain.
Naturally a light steady rain with good visibility, not associated with unstable air. One thing nobody has mentioned is the sound. Even a light rain sounds like someone is throwing BB's at the canopy. I've also had to deal with rain while out on course on a cross-country flight, and my glider has the same airfoil as a PIK-20. I've thermalled to cloudbase more than once in a steady rain from lake- effect cumulus (with full water ballast). I've also had to ridge soar through heavier rain that ran across the wing in sheets (the boundary layer water flow was mostly laiminar, the airflow not so much). And I used a rain street to run upwind and get home late in the day. But I've also landed out just a few miles from home when a summer thermal street overdeveloped and started raining on me. So there is a performance hit from rain, but it does not necessarily mean the end of your soaring day. In fact, one promising soaring day almost looked like a bust, until we realized the rain over the airport was falling from a massive wave cloud--we towed upwind out of the rain, and had an amazing wave flight. On Apr 27, 4:40*pm, Mike the Strike wrote: On Apr 27, 11:29*am, " wrote: Then again, if you are training in a 2-33, a little rain will probably increase your performance by washing some of the bugs and dirt off! Seriously, in a non-laminar wing (any metal trainer, pretty much), especially if it hasn't been waxed recently (and who waxes a 2-33 or a Lark!), light rain will have no aerodynamic effect. *Biggest problem will be reduced visibility through the canopy, and less braking action if you land on grass. Obviously, stay away from heavy rain showers or thunderstorms, but pattern-bashing in a light, occasional drizzle beats watching birds fly. Good training, too. Kirk Kirk beat me too it! *When you have an ugly crinkled metal wing bristling with rivets, a few raindrops are hardly going to matter from an aerodynamic perspective. The most important consideration is the type of cloud overhead producing the rain. *Out here in the US west, there's a good chance it'll be a shower cloud or thunderstorm that may produce downdrafts and lightning - things to worry about a lot more than a few raindrops. If you are in western Europe where most of the rain comes from stratiform clouds, it's not so bad. *Heck - if you live in some of the countries with the worst climate (Britain for example), flying in the rain is a necessary skill! Mike- |
Our second encounter with freezing rain | Longworth | Piloting | 7 | February 19th 08 02:14 AM |
Rain, rain, go away... | PJ Hunt | Rotorcraft | 3 | October 30th 04 07:51 AM |
Pic 20's in the rain | Matt | Soaring | 23 | May 14th 04 03:04 AM |
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 0 | March 15th 04 02:32 PM |
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 08:08 AM |
