6lb 50A alternator
Old May 8th 09, 08:22 AM posted to rec.aviation.homebuilt
Philippe[_2_]
Default 6lb 50A alternator
Hello,
Is someone knows this alternator?
http://www.ecae.com/alt1.html
part number 2025 or 2026
2lb more heavy than kubota but 50A vs 15A....
Any comments?
Other source cheaper?
thanks
« Si tous les počtes voulaient se donner la main, ils toucheraient enfin
des doigts d'auteur! »
Philippe Vessaire ŇżÓ¬
Old May 8th 09, 02:56 PM posted to rec.aviation.homebuilt
et
On May 8, 12:22*am, Philippe wrote:
Hello,
* *Is someone knows this alternator?
* 2lb more heavy than kubota but 50A vs 15A....
Any comments?
thanks
* * Philippe Vessaire *ŇżÓ¬
I bought a small single wire 50A from greatplainsas.com for less than
$100. Seems to work well.
Ed
Old May 8th 09, 03:49 PM posted to rec.aviation.homebuilt
Anthony W
This one is 60 amps and about $125 I'd have to get back to you on the
weight but I think it's 5 or 6 pounds and a 1 wire connect...
http://www.oregonmotorcycleparts.com/images/alt2s.JPG
Tony
Philippe wrote:
Hello,
Any comments?
thanks
Old May 8th 09, 08:40 PM posted to rec.aviation.homebuilt
Anthony W
I made a mistake, that's a 45 amp alternator and it sells for $120.
Tony
Tony
Philippe wrote:
Hello,
Any comments?
thanks
Old May 9th 09, 08:14 PM posted to rec.aviation.homebuilt
jerry wass
Philippe wrote:
Hello,
Any comments?
thanks
Yes, I know that alternator--I have one just like it--except it comes
with a multi-groove pulley from the junk yard-(easy to swap pullys )
It's made by Nippondenso. several Japanese cars use them.
A good junk yard or alternator/starter rebuilder should be able to fix
you up with a used-(checked out on machine) or rebuilt one.
see if they can cut off the vehicle plug end for you while they're at it
If I recall correctly there's only a sensor wire that goes direct to
batt, and an activator that goes to Ign. Switch,
Make certain you get new brushes & bearings--The engine you're going to
put it on is going to shake the s**t out of it.
Old May 9th 09, 08:17 PM posted to rec.aviation.homebuilt
jerry wass
Philippe wrote:
Hello,
Any comments?
thanks
Since you're in France, you'd be better off finding one there.
Old May 10th 09, 02:37 AM posted to rec.aviation.homebuilt
Charlie[_2_]
Philippe wrote:
Hello,
Any comments?
thanks
Search Ebay for 'suzuki samuri alternator' & you'll find dozens, if
you're not in a big hurry. Late '80s to early '90s models. There are 7
on there right now.
A favorite of RV builders.
Be aware that with the one-wire alternators, there's typically no way to
shut them down if the internal regulator fails. If you don't have
over-voltage protection, you can cook your avionics.
I'm not telling you not to use it (I'm flying a similar model); just be
aware of the issues.
Lots of discussion on RV-x forums and on the aeroelectric list.
http://aeroelectric.com/consulting.html
It's actually an email list; use the link above to sign up. There's also
an archive search engine for the list available at Matronics.com.
Charlie
Old May 10th 09, 09:03 AM posted to rec.aviation.homebuilt
abripl[_2_]
They sell those on eBay too. In 2004 when doing my 40hour phase 1 test
I had a couple of those mini alternators. One worked intermittently
and the second "replacement" one fried on me. Then I got a larger 60A
one from Vans Aircraft parts and it has been working so far.
On May 8, 2:22 am, Philippe wrote:
Hello,
Any comments?
thanks
Alternator longevity a Home Built 2 September 11th 06 05:25 PM
FS: NEW ALTERNATOR NIPPONDENSO Ernesto Sanchez Home Built 2 November 25th 04 06:31 PM
Alternator field cycling & alternator damage Nathan Young Owning 7 November 14th 04 09:02 PM
Did I hurt my alternator? Paul Tomblin Piloting 5 October 24th 04 04:21 AM
q alternator 152 Euromotors Piloting 2 July 16th 04 09:34 AM
