Cambridge Vario adjustment?
Old May 18th 09, 02:07 AM posted to rec.aviation.soaring
Fred Blair
Default Cambridge Vario adjustment?
I have an LNav connected to a Model 20 GPS. The LNav has all the latest
updates.
The Vario that is part of the LNav system shows about 1 kt up when sitting
still. When the system is turned off, the vario settles back to zero. I
have a Winter mechanical and it shows zero while this one shows up.
Where can I adjust it to get to show zero right after start up?
Fred
Old May 18th 09, 02:37 AM posted to rec.aviation.soaring
Bernie[_4_]
Hi Fred,
I know nothing about the LNAV or Model 20, but when the Cambridge 302
does this it usually means someone has changed the vario setting to
'Netto'.
If you can find where this is set, you may be able to configure it
properly.
Regards, Bernie.
On May 18, 11:07*am, "Fred Blair"
I have an LNav connected to a Model 20 GPS. *The LNav has all the latest
updates.
still. *When the system is turned off, the vario settles back to zero. *I
Fred
Old May 18th 09, 05:24 AM posted to rec.aviation.soaring
Paul Remde
Hi Fred,
I don't recall exactly, but you may be able to find he answer in the free
L-NAV demo/training files.
http://www.cumulus-soaring.com/cai_d...m#demolnav.zip
Or in the manual he
http://www.cambridge-aero.com/manuals.htm
Let me know if that doesn't help.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Fred Blair" wrote in message
updates.
Fred
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
PZL vario zero adjustment. [email protected] Soaring 1 September 29th 07 03:38 AM
Old Cambridge vario Pupo Terso (Std. Austria) Soaring 3 February 16th 06 07:53 PM
Old Cambridge Vario Wiring Stewart Hamey Soaring 3 November 10th 05 11:40 PM
Old Cambridge Vario Wiring Stewart Hamey Soaring 0 October 31st 05 12:08 AM
