SeeYou Wind Calculation
Old June 2nd 09, 01:09 PM posted to rec.aviation.soaring
Ken Kochanski (KK)
Default SeeYou Wind Calculation
Good Morning,
How does SeeYou calc wind speed and direction when you are reviewewing
flight logs.
I notice the wind shifts direction and velocity ... even while running
ridges ... so I assume it is not using some measurement of drift while
thermal-ing ...
KK
Old June 2nd 09, 03:10 PM posted to rec.aviation.soaring
Darryl Ramm
On Jun 2, 5:09*am, "Ken Kochanski (KK)"
Good Morning,
flight logs.
thermal-ing ...
KK
It depends on the IGC file, there may be TAS data in the file or wind
vectors in the K-record in the IGC file. This has been discussed here
in the past. For a plain IGC file SeeYou can only use circle drift.
Darryl
Old June 3rd 09, 03:39 AM posted to rec.aviation.soaring
Ray[_5_]
Darryl Ramm wrote:
On Jun 2, 5:09 am, "Ken Kochanski (KK)"
Good Morning,
flight logs.
thermal-ing ...
KK
Darryl
From the SYM manual:
Wind is calculated using three methods in SeeYou Mobile
.. Position drift when Lat/Lon are the only available data
.. Groundspeed difference when groundspeed and track are received from
the GPS
.. Combination of Groundspeed and straight flight when true air speed is
received from the instrument.
In this case, the wind is updated in straight flight as well.
Old June 3rd 09, 06:47 AM posted to rec.aviation.soaring
Darryl Ramm
On Jun 2, 7:39*pm, Ray wrote:
Good Morning,
flight logs.
thermal-ing ...
KK
Darryl
*From the SYM manual:
the GPS
You are quoting the SeeYou Mobile documentation, the question was for
SeeYou. It is not what was received from the GPS but what is in the
IGC file. And don't assume because some logger has or gets certain
data it is going to write it to the file. e.g. The C302 will often
output very nice TAS data on NMEA but does not log it to it's own IGC
file (but SeeYou Mobile will log the TAS data to it's IGC flight log
file if it is being driven from that C302). Also just be cautions
looking at the wind vector, it can appear to jump around but have very
low values even when driven by not really meaningful data.
I may be wrong on what I said on the K-record with wind direction/
speed data. SeeYou does just seem to be ignoring that. Seems a bit
stange to do that if SeeYou Mobile bothers to write them in the first
place to an IGC file.
Darryl
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
SeeYou and wind GARY BOGGS Soaring 4 April 24th 08 02:17 AM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
Three leg GS to TAS calculation Mike Rapoport Owning 21 September 12th 04 04:37 AM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 04:33 AM
