small o/a torch preferences?
Old June 18th 09, 11:09 PM posted to rec.aviation.homebuilt
patrick[_2_]
Default small o/a torch preferences?
Hello; I'm considering a project - homebuilt recumbent bike- that I'm
going to use as an excuse to buy a smaller o/a torch. I currently have
a victor torch, model 100-with the valves at the bottom of the largish
body and would like to buy one of the smaller torches with the valves
at the top of the body. There's 3 commonly available torches with the
topside control on the north american market- the victor, harris and
smith torch. Any preferences among the 3? Thanks Pat
Old June 18th 09, 11:26 PM posted to rec.aviation.homebuilt
Gerry van Dyk
I would wholeheartedly recommend the Meco Midget from TM Tech,
although it's probably more expensive than any that you've listed. It
could almost be described as a "jeweler's" o/a torch. I forked out
the bucks and am absolutely delighted with it.
http://tinmantech.chainreactionweb.c...52d 4c9d44c1b
The other torch commonly used in homebuilt aircraft (that's still
available) is the Henrob 2000. (formerly Dillon etc) Nice handle but
from what I gather it's substantially bulkier and heavier than the
Meco.
http://www.cut-like-plasma.com/
Hope this helps.
Gerry
smith torch. Any preferences *among the 3? Thanks Pat
Old June 19th 09, 12:11 AM posted to rec.aviation.homebuilt
canuck_bob
I'm a rank amateur OA welder but have been happy with the little
Smith. Wish I had double stage regulators though. My flame settings
wander a bit at the low pressures I use.
Old June 19th 09, 12:27 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
I had both a Smith and a Victor.
Both were fine instruments with the right sized tips.
"Small" diameter hoses are recommended.
Less fatigue handling the torch that way.
While I'd love to play with a Meco Midget,
it was just too expensive for my limited budget.
Richard
Old June 19th 09, 02:57 AM posted to rec.aviation.homebuilt
On Thu, 18 Jun 2009 15:09:06 -0700 (PDT), patrick
Henrod.
Old June 20th 09, 03:04 AM posted to rec.aviation.homebuilt
On Fri, 19 Jun 2009 10:09:45 GMT, Stealth Pilot
Henrod.
clare dont you find your knuckles getting cooked by the henrob?
radiant energy really made the hand uncomfortable after a short
welding stint when I was using one.
I have a Dillon Mk3 but I'd love a little smith to get my hand lust a
little further away but havent found anywhere that carries them in my
country. we seem to be stuck with the comet 3 handle in australia.
Stealth Pilot
Australia
I don't have a Henrob but have used one. They are for FINE work - and
where the heat is not re-radiated/reflected back too much. Like
holding an artists brush as far as control is concerned.
Fuel Lube Preferences? Orval Fairbairn[_2_] Owning 2 January 16th 09 04:29 AM
OSH '08 Redux -- The Torch Has been Passed, Part II Jay Honeck[_2_] Piloting 28 August 8th 08 01:29 PM
OSH '08 Redux -- The Torch Has Been Passed, Part I Jay Honeck[_2_] Piloting 7 August 5th 08 04:09 AM
Ol Shy & Bashful preferences Stuart & Kathryn Fields Rotorcraft 1 March 2nd 08 12:25 AM
IFR/Flight Following -- ATC Preferences? Mitty Instrument Flight Rules 94 November 7th 05 01:12 PM
