US contest scoring formula is broken
Old June 23rd 09, 07:08 AM posted to rec.aviation.soaring
Steve Koerner
Default US contest scoring formula is broken
Over the last several years I've found it quite annoying that I cannot
read the rules and understand the US scoring formula. The
calculation of US scores has become encumbered with so many correction
factors, devaluation factors and the like that mere mortals cannot
relate soaring performance to score results. It did not use to be
that way.
Day 5 preliminary scores for the ongoing US Standard class nationals
at Montague are showing that the current complex scoring formula
generates ridiculous results. The winning performance was a 217 mile
flight at 72.50 mph (congratulations David Greenhill). The second
place speed of 61.30 mph received 85% of the winners score for a speed
which was 15% slower. So far, OK.
Then a bizarre compression comes into play for slower finishers. The
seventh place pilot flew a mere 67 miles at 23.33 mph and received 76%
of the winners score. That’s absurd. He flew only about one third of
the speed and distance that the second place finisher flew yet scored
a mere 70 fewer points.
We need to completely scrap the present over-elaborated scoring
equations and get back to a scheme for scoring that is both simple and
understandable. The simple scoring protocol of yore may have produced
minor inequities at times; but, there was never anything as crazy as
the scoring we’re generating right now at the US nationals.
Old June 23rd 09, 02:08 PM posted to rec.aviation.soaring
Andy[_1_]
On Jun 22, 11:08*pm, Steve Koerner wrote:
Then a bizarre compression comes into play for slower finishers. *The
of the winners score. *That’s absurd. *He flew only about one third of
I have not studied the results but I wonder if the "worst day" rule is
being applied. It's a flag in Winscore (worst day scoring adjustment)
that has to be selected by the scorer. It can be selected for
Nationals.
Andy
Old June 23rd 09, 02:18 PM posted to rec.aviation.soaring
Andy[_10_]
This in part results from a change in 2007 that changed Maximum
Distance Points (MDP) from 400 to 600. The relevant rules (for MAT and
TAT - similar for AST) a
11.6.6 Maximum Speed Points:
MSP = STF * (600 + 500 * SCR) (but not greater than STF *
1000)
11.6.7 Maximum Distance Points:
MDP = MSP * (0.8 - 0.2 * SCR)
11.6.8 Points for Finishers:
POINTS shall be equal to the largest of the following
three quantities:
MSP * SPEED / BESTSPD
MDP + 30 + MSP * 0.2 * ((SPEED/BESTSPD) - 0.4)
MDP + 30
As I understand it, the basic idea is that the rule makers (with pilot
input) are trying to make sure that pilots who have a landout can stay
somewhat competitive (See: 11.6.8 - dropping 600 points on a day is
hard to make up - 400 is still hard, but less so). There are also
provisions for devaluing tasks with lots of landouts (more than 20% -
see 11.6.6). Lots of landouts are thought to correlate to a higher
"luck factor". Short tasks are also devalued under similar logic.
The simplest scoring formulas would be to set Maximum Speed Points
(MSP) to 1000 and Minimum Distance Points (MDP) to zero and to get rid
of Scored Completion Ratio (SCR) and Short Task Factor (STF). What
this would mean is that if you finish, you get a score that is
directly proportionate to your percent of the winner's speed - no
matter how slow you go. If you land out you get zero. An alternative
is to to keep the idea of MDP (but we need to pick a number - 200,
400, 600, 800?) and relax the constraint that the best landout has to
get fewer points that any finisher. This allows us to keep the idea of
strict proportionality for any speed finisher. Under this scenario you
could see your score drop by a lot if you you are slow and finish
rather than landing out (because MDP exists, finishers whose speed as
a percent of the winner's speed is less than MDP/1000 could score less
than a long landout). This may be a bad idea as it encourages landing
out.
A third alternative is to pin any finisher's score that is less than
MDP to MDP - but this introduces the possibility that the bottom of
the scoresheet is populated with pilots who have identical scores
because they can't get above MDP. The lower you make MDP, the less
likely this is, but to avoid it for the Montague example described by
Steve MDP would need to be 300 points - which is less that it has ever
been in the rules. Obviously, that specific situation doesn't come up
often, and when it does its usually a funky day or a situation where a
pilot had something odd happen on course. It can also result from
cutting short at MAT (particularly if no turnpoints are assigned) or,
to a lesser extent, a TAT course.
I agree that the Montague example seems extreme, so it may warrant
review. It seems to me that all the alternatives have some tradeoffs
though.
9B
Old June 23rd 09, 02:48 PM posted to rec.aviation.soaring
Andy[_10_]
* * * * 11.6.6 Maximum Speed Points:
* * * * * * *MSP = STF * (600 + 500 * SCR) (but not greater than STF *
1000)
* * * * 11.6.7 Maximum Distance Points:
* * * * * * *MDP = MSP * (0.8 - 0.2 * SCR)
* * * * 11.6.8 Points for Finishers:
* * * * * * *POINTS shall be equal to the largest of the following
three quantities:
* * * * * * *MSP * SPEED / BESTSPD
* * * * * * *MDP + 30 + MSP * 0.2 * ((SPEED/BESTSPD) - 0.4)
out.
though.
9B
Sorry - I meant to say MDP is Maximum Distance Points, not Minimum.
9B
Old June 23rd 09, 02:51 PM posted to rec.aviation.soaring
T8
1000)
three quantities:
out.
though.
9B
It's the use of MDP in formulas 2 & 3, without regard to how many
miles any given pilot actually flew, that's causing problems.
Agreed that our scoring rules are getting a little dense. I'm
curious: how are European comps scored? Anyone got a link?
-T8
Old June 23rd 09, 03:06 PM posted to rec.aviation.soaring
stephanevdv
Agreed that our scoring rules are getting a little dense. *I'm
curious: how are European comps scored? *Anyone got a link?
-T8
In Europe, most "classic" contests use the scoring formulas from the
Sporting Code Section 3, Annex A (International competition rules), §
8.4. Fairly complicated too!
Old June 23rd 09, 03:11 PM posted to rec.aviation.soaring
rhwoody
1000)
three quantities:
out.
though.
9B
-T8- Hide quoted text -
- Show quoted text -
Has anyone thought of getting back to basics - by that I mean getting
rid of TAT and all of the follow on tasks to POST - and fly only AST -
Assigned Speed Task - start gate, finish gate, all competitors fly the
same turnpoints, finish gate - fastest pilot wins?
Old June 23rd 09, 03:31 PM posted to rec.aviation.soaring
Steve Koerner
I would urge that instead of looking at this in terms of ‘how can we
fix the Montague problem’ lets look at this much more fundamentally.
The Montague example shows that year after year of elaborating the
scoring formula has resulted in a mess.
It is time to step way back and start over. Let’s get rid of the
alphabet soup that now exists in the rules for scoring. All (or at
least most) of the accumulated complications in the rules were
undoubtedly made in the interest of improving fairness. Yet at the
most elemental level it is really unfair to be using a set of scoring
formulas that cannot be comprehended by an intellectually
sophisticated competitor who applies reasonable diligence in studying
the rules. That is what we have now. It is especially irksome that
competitors should put up with the unnecessary complication and still
not have a scoring system that produces reasonable results.
So here’s a simple proposal to get this discussion going in the right
direction: Let’s give 500 points for speed and 500 points for
distance. Period. Speed points are proportioned to the fastest
finisher’s speed; if you don’t finish you get zero speed points.
Distance points are proportioned to the best distance achieved.
Yes, on TAT and MAT style tasks, my formula would change the game plan
a bit. It would introduce an objective to go forth and fly far (like
OLC) as well as fast. Wouldn’t that be fun?
Old June 23rd 09, 03:35 PM posted to rec.aviation.soaring
Tim[_2_]
But then what would happen to US Sports Class the best bureacraticly
created catch-all class in the world...
Her's to real racing, with a minimum of complicated rules... and bring
Club Class tot he U.S. so we c;ub class pilots can actually fly AT
speed tasks in official contests.
EY
Old June 23rd 09, 03:39 PM posted to rec.aviation.soaring
Tim[_2_]
direction: *Let’s give 500 points for speed and 500 points for
distance. * Period. *Speed points are proportioned to the fastest
a bit. *It would introduce an objective to go forth and fly far (like
OLC) as well as fast. *Wouldn’t that be fun?
This idea would be a terrific start... or we could just score
according to the FAI rules and use SeeYou to score cotnests like the
rest of the world. You can definitely overcook the rules and we are
definitely in that kitchen.
EY
Transfer of IGC log for contest scoring Tom N. Soaring 22 February 21st 07 09:15 PM
Excel formula for logbook Wizard of Draws Instrument Flight Rules 11 August 30th 04 12:55 AM
Inaccurate Contest Scoring Bill Feldbaumer Soaring 21 June 14th 04 02:56 PM
History of Contest Scoring Bill Feldbaumer Soaring 8 October 8th 03 02:14 PM
