Hi, I hear a lot about pitch sensitivity. Can that mean more than one
thing? For example, it seems it could mean: 1. A glider in which smaller than typical stick movements are needed for pitch control 2. A glider in which the pitch stability is less, in that when perturbed from trimmed level flight the number of pitch oscillations is large before returning to level flight (or not return at all). 3. A glider in which the pitch stability is fine, but the time to respond to correction is long, so the pilot overcorrects to cause PIO. .... or does it always mean #2? Are all-flying tails always pitch sensitive (definition #2), or is it a combination of the all-flying tail with something else? Does even an experienced pilot have to live with more risk in a pitch sensitive glider, or is the process of getting used to it that is more risky? Thanks |
I think it always means 1, at least when I use it and have heard
others. By the way, a single model can have widely differing sensitivity depending on cockpit load/CofG position. A well-known 2- seater with a permissibly light solo pilot (think 16-year old girl on 1st solo) can be 4x more sensitive than with 2 up, one being an overweight instructor. She finds herself flying a glider totally different in feel to anything she has flown before. Can lead to PIO. No heavy instructor knows what she is going to experience. So I am told. Chris N. |
For the Janus A I had a share in it was none of the above. The two
less than ideal features were, 1. The elevator loads didn't increase with speed so that at high speed you had to be very careful to move the stick gently or you might pull alot of G (in either direction). 2. The elevator didn't seem to be mass balanced so in turbulence you would get alot of feedback through the stick. On Fri, 26 Jun 2009 11:01:39 -0700 (PDT), Bret wrote: Hi, I hear a lot about pitch sensitivity. Can that mean more than one thing? For example, it seems it could mean: 1. A glider in which smaller than typical stick movements are needed for pitch control 2. A glider in which the pitch stability is less, in that when perturbed from trimmed level flight the number of pitch oscillations is large before returning to level flight (or not return at all). 3. A glider in which the pitch stability is fine, but the time to respond to correction is long, so the pilot overcorrects to cause PIO. ... or does it always mean #2? Are all-flying tails always pitch sensitive (definition #2), or is it a combination of the all-flying tail with something else? Does even an experienced pilot have to live with more risk in a pitch sensitive glider, or is the process of getting used to it that is more risky? Thanks |
On Fri, 26 Jun 2009 11:01:39 -0700, Bret wrote:
2. A glider in which the pitch stability is less, in that when perturbed from trimmed level flight the number of pitch oscillations is large before returning to level flight (or not return at all). Both the gliders I've tried straight flight, hands off stick with (ASW-20, Std. Libelle) have gradually built up a definite, but stable phugoid over 5 cycles or so. The '20 stabilized with a +/- 5 kt speed excursion over a 25 second period. I don't remember the Libelle numbers except that both speed excursion and period were less than for the '20. As I'm told that all aircraft show this behavior and that it becomes more pronounced as the airframe drag is reduced, I question whether counting oscillations is relevant to stability estimates. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Jun 26, 1:01*pm, Bret wrote:
Hi, I hear a lot about pitch sensitivity. *Can that mean more than one thing? For example, it seems it could mean: 1. *A glider in which smaller than typical stick movements are needed for pitch control 2. *A glider in which the pitch stability is less, in that when perturbed from trimmed level flight the number of pitch oscillations is large before returning to level flight (or not return at all). 3. A glider in which the pitch stability is fine, but the time to respond to correction is long, so the pilot overcorrects to cause PIO. ... or does it always mean #2? Are all-flying tails always pitch sensitive (definition #2), or is it a combination of the all-flying tail with something else? Does even an experienced pilot have to live with more risk in a pitch sensitive glider, or is the process of getting used to it that is more risky? Thanks Look up the phrase stick force per g. Also the phrase phugoid. Generally, stick force is what we notice the most. Stick motion also, but the real touchy feel is lack of stick force. Phugoid is a hands off situation. Short term phugoid should be damped. Long term phugoid should be at least neutral. We don't spend much time hands off. If you have your hands on (stick fixed) the phugoid will be more damped. Like you said, all flying tails often have less well behaved stick force and phugoid characteristics. The problems can be worked via pivot points, balance, contour changes, springs and bobweights. Or you can design the thing with good stability characteristics in the first place and forget about making everything as small as possible. |
Bret wrote:
Thoughtful questions about pitch sensitivity massaged below... Hi, I hear a lot about pitch sensitivity. Can that mean more than one thing? "Almost certainly...to different people of various backgrounds." So it'll pay dividends to keep asking your questions until the answers make sense to you. FWIW, you're probably asking (at least partially) about a topic postgraduate engineers could (and do) specialize in, i.e. longitudinal ('pitch') stability. From Joe Pilot's usual perspective though, 'pitch sensitivity' tends to have a broader meaning. Typically, ships having a low ratio of stick-force/G response are deemed 'more sensitive' than those with a high(er) ratio response. Examples of the latter are any Schweizer - you have to pull 'really hard' to induce (say) 4G on them, while a lighter pull force (from the same speed) will induce 4G on (say) a G-103. The actual force numbers are what they pay test pilots to measure. Another general measure of pitch sensitivity is the starting force ('breakout force' in test pilot terms) required to induce a pitch change from trimmed flight. And since so much glider trimmed flight occurs around thermalling speed, the pilot community tends to dial in 'normal stick forces' at these speeds. Painting with a broad brush, glass ships tend to have lower breakout forces than Schweizers and are thus thought of as 'more pitch sensitive.' In the interest of communication, I recommend expending effort defining the terms of any conversation about this sort of stuff... - - - - - - For example, it seems it could mean: 1. A glider in which smaller than typical stick movements are needed for pitch control Yup... - - - - - - 2. A glider in which the pitch stability is less, in that when perturbed from trimmed level flight the number of pitch oscillations is large before returning to level flight (or not return at all). Yup...more below. - - - - - - 3. A glider in which the pitch stability is fine, but the time to respond to correction is long, so the pilot overcorrects to cause PIO. A *VERY* thoughtful realization...and one that seems applicable in some circumstances to the Zuni I fly. It actually took me a number of years to realize the validity of your surmise, and where I think I tend to see it is in two situations: 1) turbulent air aloft, and 2) landing flare. Aloft, in turbulent air (all my Zuni flight has been in the U.S. intermountain west) there - sometimes, not always - seems to be a distinct delay between making a pitch input and that input's taking effect. I usually notice this after the effect happens (& I forget or get impatient), I make a(nother) pitch input, and both seem to take effect 'at once.' It's more a nuisance than anything else, but I don't think it's entirely in my imagination. Some pitch inputs simply don't seen to take effect in the same time constant 'most others' do. (It's not control slop...) Where it can be more problematic (to me, anyway) is in the landing flare. I years ago gave up trying to execute a smooth, continuous stick motion as part of transitioning from the approach position to the 2-point position, because I simply can't do it. (It was trivially easy in the HP-14 from which I transitioned.) Whether my failing comes about from a time-constant lag due to the all-flying stabilator, pitch system friction, pitch system geometry, pilot ineptitude or whatever, I have no real idea. (I evolved a work around, 2-step flare methodology that works well enough.) - - - - - - ... or does it always mean #2? "Yes," to aeronautical engineers. "Pitch stability" has a distinct engineering meaning when applied to airplanes/gliders, and even at the undergraduate level the topic may occupy a full-semester course; your '#2' directly addresses the engineering aspect of 'pitch stability.' Quite math intensive the course is, but the comprehensive gist of the course is easily (more or less) summarizable: as the CG moves aft, pitch stability lessens. If you messed about with flying models as a kid, you already understand this. Engineers talk about 'stick-free' and 'stick-fixed' pitch stability, and as you might guess one is a measure of the plane's pitch reaction to a perturbation (stick movement, gust, etc.) while the pilot is holding the stick, and the other the plane's reaction when s/he is not. An example of the former might be doing a high-speed pass and initiating a pitch change, while an example of the second might be flying through turbulence while you're trying to offload personal water ballast (aka 'take a leak') with neither hand on the stick. Mathematically, the situations are different, but to Joe Average Pilot an *absence* (or even the reduction) of pitch stability (of either type) is (may be any or all): noticeable, alarming, backward, different, dangerous. Typically, aft CG limits on a glider are chosen to provide 'sufficient' pitch stability at full-aft CG. The glider definitely does NOT suddenly go from 'stable' to 'unstable' with the shift occurring exactly AT the aft CG limit. Nor will it go mathematically unstable until the CG is 'some ways *aft*' of the aft limit. (How far aft? Ah! Here's one of the black arts in glider design!!!) Rather, the glider's ability to return to its trimmed speed (in the absence of pilot input) diminishes as the CG moves aft. It is becoming 'less stable' and takes longer to return to its trimmed speed if flown stick free. In $10 word terms, the less stable a glider is, immediately following a stick-free pitch perturbation its 'phugoid oscillations' *tend* to increase in amplitude for a given magnitude perturbation, and, similarly increase in number before the plane again achieves trimmed speed after the perturbation. - - - - - - Are all-flying tails always pitch sensitive (definition #2), or is it a combination of the all-flying tail with something else? Another question worthy of books! My personal answer to the second part of your question is, "I don't know!" while my response to the first part is, "They sure seem to be!" If it happens, it must be possible. The way I tend to think of it is it's much more difficult for a designer to end up with 'acceptable pitch characteristics' designing around an all-flying tail than around a conventional (fixed horizontal stab w. trailing elevator). True whether we're talking power plane or glider. Obviously, designers of both have designed w. all-flying horizontal stabs (e.g. Cessna Cardinal, various Pipers, Zuni, St'd Cirrus, early Mini-Nimbus, LS-1, etc.). I find it interesting - and perhaps telling - that glider designers' attraction to all-flying horizontal stabilizers tended to be short-lived/early-ish in the glass revolution; both LS and Schempp-Hirth ultimately moved away from them. In the case of the Zuni, my ship (S/N 3, intended to be the production prototype) shows in its log a series of 7 flights over 7 months, logged as follows: 1) "Test" (initial flight); 2)/3) "Stall Tests"; 4) "Stall & High Speed"; 5) "Stability Tests"; 6) "Test New Stabilator"; 7) "Test Stabilator Modification". Unfortunately I don't know the details of the change(s?) implied by 6) & 7), but it's my understanding a hinge point change is in there somewhere...the distance of the change being considerably under an inch. - - - - - - Does even an experienced pilot have to live with more risk in a pitch sensitive glider, Short form answer is, "Yes." The glider just 'is' & it's up to the pilot to always adapt its characteristics. Without intending to be dramatic or scaremongering, here's a couple of illustrative stories about Standard Cirrii told me by good friends experienced in all flying stabilizer examples... One - a flight instructor/experienced XC gliderpilot of sober judgment, and mechanical engineer by training - said he was distinctly surprised to learn that above ~90 knots (as I recall from ~20 years ago) his 'stick force per G' began to noticeably lessen. In other words, instead of needing more force to apply more - in this case pull- up G-load - it required *less.* In response to the direct question, "Did you have to *push* to keep from pulling more G?" his answer was, "No...but I *did* have to lessen my pull force." Because this isn't a 'natural' response, designers generally try to avoid playing in this particular sandbox; as you might imagine, PIO - or worse - could easily result should Joe Pilot be surprised by the change. In engineering terms, the slope of the stick force per G line decreased, for this guy in this ship. Had the slope gone negative, he would have been flying a definitionally 'pitch unstable' glider. Two other good friends who owned/flew different St'd Cirrii for over 20 years each - both of whom weighed 210 pounds - independently told me that they 'always' flew with their hand at the base of the stick, forearm resting on thigh, when cruising above 70 knots or so, because it was just too easy to induce inadvertent high-G in turbulent air, flying faster while grasping the stick's hand grip. Both also said they routinely experienced 'unusual attitudes' while taking leaks. All 3 of these pilots loved their Cirrii...but gave their ships' limitations due respect. Now the above-mentioned things just 'are.' Simply being aware of them beforehand is a huge weapon in a pilot's arsenal. I don't consider any of them outright 'bad' or 'alarming'...they're just 'different' ('characteristics,' if you will). To pretend they're not there is to indulge in fantasy, but to suggest they're mountainous is to indulge in unwarranted hyperbole, in my view. Nevertheless, they're the sort of stuff you'll hear in post-flying bull sessions, often beer, ignorance and distance enlarged. - - - - - - or is the process of getting used to it that is more risky? Short form answer is, "Yes." To me, anything new is definitionally 'risky.' That noted, having a grasp beforehand of what you're likely to encounter considerably alters the picture. Think 'new experience' as opposed to 'risk of the unknown.' Regards, Bob - tries to avoid unintentional test piloting - W. |
Pitch "sensitivity" is most likely a result of an aft CG, IMHO.
Flying tail may feel "sensitive", but in gliders that is most likely due to lack of feel in the older all-flying tail gliders. An aft CG, up to a point, makes most gliders fly a lot sweeter. But get too far aft, and things get squirrily real fast! The big Schweizer 2-32, which has a all-flying tail, is neither pitch sensitive or lacking in feel - on the contrary it is a nice flying, if somewhat heavy, glider. The slab tail is big, and has a bit anti- servo tab on it, which probably contributes to it's nice feel. Spins nice too - and requires a manly push on the stick to recover! Kirk |
I agree with Kirk that the 2-32 feels pleasant due to the anti-servo
tab. I remember it was the same with the single place Lark. I'm sure that part of the "problem" with all-flying tails is that the mass in the system, which is higher than you would expect due to the need for mass balancing, imparts a little more momentum to the control system. If you correct one way or the other the surface will keep moving a little after you stop the input. I suppose we automatically learn to stop the input with different timing or physically stop the stick from overshooting the desired displacement. You basically have to stop the control from overshooting, whether you realize it or not, which I've never noticed with normal elevators or rudder-vators, mass balanced or not.. Again as Kirk suggested, this was most noticeable in an old, light glider that suddenly was an unpleasant handful when we flew through wake turbulence on the takeoff roll. Cheers, Galen (remove 'xxx' to reply) |
Bret,
I don't know the definition of "pitch sensitivity, but I do know about flying with an all-flying stabilator. I've been flying my LS1-d for about 15 years (has it been that long?) and it has the all-flying stabilator. Is it "pitch sensitive?" I don't think so, but I rarely fly anything else, thus I don't have anything to compare against. The glider will trim at my thermalling speeds (48-52 knots) and will trim at cruising speeds (70 - 75 knots) and will fly "hands off" for the short length of time I need to be hands off to do a small task as fold or unfold a chart, open a sandwich bag, etc. I haven't really explored how long it will go hands off. No need to. If I wanted to fly "hands off", I would sell the glider and get an airplane that has an autopilot. My good friend flies a Standard Cirrus, also with an all-flying stabilator. From what he says, his glider is a bit more "twitchy" in pitch than mine. He has his CG around 70 or 75 % rearward on the CG range and according the Weight and Balance I did this past Friday, mine's at 68%. From my experience, if a glider is supposedly "pitch sensitive", the pilot might get accustomed to it over time. And for the record, the sexy little stabilator on the LS1-c, LS1-d has it ALL OVER the big, fat, homely stabilator found on the Std. Cirrus. :-) Ray Lovinggood Carrboro, North Carolina, USA |
rlovinggood wrote:
Bret, I don't know the definition of "pitch sensitivity, but I do know about flying with an all-flying stabilator. I've been flying my LS1-d for about 15 years (has it been that long?) and it has the all-flying stabilator. Is it "pitch sensitive?" I don't think so, but I rarely fly anything else, thus I don't have anything to compare against. The glider will trim at my thermalling speeds (48-52 knots) and will trim at cruising speeds (70 - 75 knots) and will fly "hands off" for the short length of time I need to be hands off to do a small task as fold or unfold a chart, open a sandwich bag, etc. I haven't really explored how long it will go hands off. No need to. If I wanted to fly "hands off", I would sell the glider and get an airplane that has an autopilot. My good friend flies a Standard Cirrus, also with an all-flying stabilator. From what he says, his glider is a bit more "twitchy" in pitch than mine. He has his CG around 70 or 75 % rearward on the CG range and according the Weight and Balance I did this past Friday, mine's at 68%. From my experience, if a glider is supposedly "pitch sensitive", the pilot might get accustomed to it over time. And for the record, the sexy little stabilator on the LS1-c, LS1-d has it ALL OVER the big, fat, homely stabilator found on the Std. Cirrus. :-) Ray Lovinggood Carrboro, North Carolina, USA Well the Std Cirrus may have a homely stabilator. And it is indeed pretty "responsive" on the elevator. Compared to something like a DuoDiscus it is downright twitchy. Some points - Mine is at 90% aft CG - that makes it very twitchy. It got that way from taking heavy old instruments out of the front, that appear to have been balanced by adding gel to the tail boom around the wheel. - She's going on diet soon to get the CG to ~65%. You learn to love it - especially in not having to counter high forces at high speed. You learn to be very circumspect with control inputs at high speed... My Cirrus is an early model with the .75 degree washout wings, hands off is not really an option except for very brief moments. Trimmed to just about any speed she enters a slowly diverging phugoid if you leave the stick. Again - it seems to depend on the aircraft a little. Cheers Bruce Big homely Std Cirrus Driver. (both the glider and the pilot) |
Hornet tails | Glenn[_2_] | Aviation Photos | 0 | April 1st 07 03:38 AM |
Anyone have VX-31 F/A-18E photos (black tails)? | KC | Naval Aviation | 0 | January 5th 04 08:01 PM |
Flaps and V-Tails of Death | Wallace Berry | Soaring | 59 | November 26th 03 09:54 PM |
Cutting off shirt tails | Wally Samuelson | Military Aviation | 24 | September 3rd 03 12:33 AM |
ki-61 two tails? | old hoodoo | Restoration | 0 | July 21st 03 03:44 PM |
