Yesterday, I flew to an airport for breakfast and as I turned off onto
the taxiway, the engine quit. It's never done that before. Re-started fine. Did not quit when I returned to my home airport. Maybe the turbulence was enough to fix it ![]() Some history...the plane had been sitting for for several years and I started flying it again last fall. It seemed to be OK last fall but I had another issue (that turned out to be a big intake leak that prevented it from starting) that I now have fixed. So, could this stalling be something like the float sticking? After I started it, it seemed to "load up" a bit and took some RPM to clear it out. Maybe this is a clue? Scott Corben Junior Ace |
Dear Scott,
Your symptoms match those of carb icing. -R.S.Hoover |
Scott wrote:
Yesterday, I flew to an airport for breakfast and as I turned off onto the taxiway, the engine quit. It's never done that before. Re-started fine. Did not quit when I returned to my home airport. Maybe the turbulence was enough to fix it ![]() I've had that happen, and have been with another small-Continental- powered aircraft where that happened. Instant re-starts in both cases. I tend to agree with Bob...carb ice. On approach, with the engine idling for a bit, the carb heat muff may have cooled down to the point where it couldn't prevent the ice any more. If it re-occurs, there are some potential hardware problems that could going on. Here's a Harry Fenton article on the subject: http://www.bowersflybaby.com/tech/fenton.htm#a65-quits Ron Wanttaja |
Ron Wanttaja wrote:
Scott wrote: Yesterday, I flew to an airport for breakfast and as I turned off onto the taxiway, the engine quit. It's never done that before. Re-started fine. Did not quit when I returned to my home airport. Maybe the turbulence was enough to fix it ![]() I've had that happen, and have been with another small-Continental- powered aircraft where that happened. Instant re-starts in both cases. I tend to agree with Bob...carb ice. On approach, with the engine idling for a bit, the carb heat muff may have cooled down to the point where it couldn't prevent the ice any more. If it re-occurs, there are some potential hardware problems that could going on. Here's a Harry Fenton article on the subject: http://www.bowersflybaby.com/tech/fenton.htm#a65-quits Ron Wanttaja OK...but if it was carb ice, would the engine restart immediately after getting out to hand prop? My "heat muff" is a replica of an Aeronca 7 series heat muff...just an aluminum "cover" that clamps around the "Y" of the exhaust pipe. Is there an easy way to get more heat such as wrapping a spring or something around the pipes to get more thermal mass? Ideas anyone??? Scott |
Scott wrote:
OK...but if it was carb ice, would the engine restart immediately after getting out to hand prop? Sure...the flow of cooling air would stop, and the carb would quickly warm up by conduction. Frank Courtney, in his book "The Eighth Sea," claims to be the discoverer of carburetor icing...not the first to HAVE carb ice, but the first to discover what was causing some otherwise-unexplainable engine failures. He had been participating in a cross-country race with an engine with an updraft carb and no air filter. The engine quit, he set the plane down, and climbed out. He reached the engine just in time to see a chunk of ice drop out of the carburetor throat. My "heat muff" is a replica of an Aeronca 7 series heat muff...just an aluminum "cover" that clamps around the "Y" of the exhaust pipe. Is there an easy way to get more heat such as wrapping a spring or something around the pipes to get more thermal mass? Ideas anyone??? IIRC, Tony Bingelis recommends exactly your approach; wrapping screen-door springs around the pipes. You need more surface area inside the heat to pick up heat to transfer to the air. You might ask at the Aeronca Aviators Club forum page... http://www.aeronca.typeclubs.org/BB3/ ....or ping Harry Fenton directly via the links at the start of the page I previously posted. Ron Wanttaja |
Ron Wanttaja wrote:
You might ask at the Aeronca Aviators Club forum page... http://www.aeronca.typeclubs.org/BB3/ ...or ping Harry Fenton directly via the links at the start of the page I previously posted. Ron Wanttaja Will do, Ron, THANKS! As far as starting right up again, yes, I figured it probably does as the engine is still quite warm after landing and without air flowing to move the heat through, the carb would warm up fairly quickly and melt the ice... Do you know what is the mechanism that causes power loss (and ultimately quitting) due to carb ice? The book drawings show that ice builds up in the throat of the carb (if I recall) so it looks like the diameter of the throat is reduced? What does that do to make the engine run at reduced power and/or eventually die? I suspect that it impedes the air flow through it, effectively making the mixture richer until eventual death. Am I close? Scott |
On Jul 12, 11:52 am, Scott wrote:
Do you know what is the mechanism that causes power loss (and ultimately quitting) due to carb ice? The book drawings show that ice builds up in the throat of the carb (if I recall) so it looks like the diameter of the throat is reduced? What does that do to make the engine run at reduced power and/or eventually die? I suspect that it impedes the air flow through it, effectively making the mixture richer until eventual death. Am I close? Getting warm, but still a ways from the truth. There are two factors that cause the temperature drop in the carb: The venturi accelerates the air, thereby dropping its pressure and temperature. We need that pressure drop to suck fuel from the nozzle, but could do without the temp drop. The laws of physics being what they are, we have to deal with it. A similay pressure and temperature drop takes place at the throttle plate when it's closed or mostly closed; the air squeezing past the edge of the plate accelerates a whole bunch and gets cold, however briefly. The other factor is the fuel itself. As it sprays into the airflow, it vaporizes. Anytime we turn a liquid into a vapor, we effect a heat transfer; in this case it's from the air to the liquid as it turns to a vapor. So the air gets mighty chilly. Same effect you get if you dip your hand in gasoline then hold it up and let it dry;your hand gets cold. The fuel sprays from the main nozzles when the power level is higher, and from the idle ports in the carb wall, next to the edge of the throttle plate, at lower settings. So the air, and any water vapor in it as it passed through the carb, is chilled. The vapor, if there's enough of it, will condense, and if the temperature drop is large enough, it will freeze to anything handy. Carb ice. The total temperature drop caused by both venturi effect and evaporation of the fuel can be as much as 38°C, or about 71°F. We can expect carb ice at ambient temps of up to 38°C or 100°F if the humidity is near 100%, or the temp/dewpoints are almost the same. If I want to go diving off some cliff into the water, I want to know what the water conditions are, and what's under the surface. If I want to go flying, I need to know what the atmosphere is up to. That includes temperture and dewpoint spread; if they're close together, I will expect carb ice so I'm not surprised when the engine starts acting up. If your engine quit on the rollout due to carb icing, either your system is leaking and the carb isn't getting warm enough air, or you're not applying it soon enough and getting the carb warmed up some before reducing power. Or you're making long glides without running the power up and warming the carb periodically. What sort of RPM drop do you get when you pull the carb heat in cruise? When are you applying carb heat? How long was the power-off glide? What were the temp and dewpoint on the day in question? Dan |
Scott wrote:
Yesterday, I flew to an airport for breakfast and as I turned off onto the taxiway, the engine quit. It's never done that before. Re-started fine. Did not quit when I returned to my home airport. Maybe the turbulence was enough to fix it ![]() Some history...the plane had been sitting for for several years and I started flying it again last fall. It seemed to be OK last fall but I had another issue (that turned out to be a big intake leak that prevented it from starting) that I now have fixed. So, could this stalling be something like the float sticking? After I started it, it seemed to "load up" a bit and took some RPM to clear it out. Maybe this is a clue? Scott Corben Junior Ace the "loading up" part - could be ice related, or - Fixed ignition timing can cause that problem if allowed to idle too long. |
On Jul 12, 7:43 am, Scott wrote:
Yesterday, I flew to an airport for breakfast and as I turned off onto the taxiway, the engine quit. It's never done that before. Re-started fine. Did not quit when I returned to my home airport. Maybe the turbulence was enough to fix it ![]() Scott, it just wanted to make sure it got a short breather before you launched into that headwind home. Glad you didn't get beat up too bad on the way back. Matt Scott Corben Junior Ace |
Gunny wrote:
On Jul 12, 7:43 am, Scott wrote: Yesterday, I flew to an airport for breakfast and as I turned off onto the taxiway, the engine quit. It's never done that before. Re-started fine. Did not quit when I returned to my home airport. Maybe the turbulence was enough to fix it ![]() Scott, it just wanted to make sure it got a short breather before you launched into that headwind home. Glad you didn't get beat up too bad on the way back. Matt Scott Corben Junior Ace Hi Matt, Well, it was kind of a handful. Fortunately, myself nor the aeroplane was damaged ![]() looked pretty nice! Scott |
Infamous engine stall on takeoff | James Robinson | Piloting | 8 | January 4th 07 05:08 PM |
Continental engine E185 | Philippe | Home Built | 4 | July 14th 04 01:14 PM |
Continental Tierra 285 Engine | chip | Aviation Marketplace | 5 | May 8th 04 01:02 PM |
Continental Tierra 285 Engine | chip | Home Built | 4 | April 30th 04 02:12 AM |
Continental A65 engine | Philippe Vessaire | Home Built | 0 | July 10th 03 05:49 PM |
