is TE probe needed?
Old July 13th 09, 11:50 PM posted to rec.aviation.soaring
JSoar
Default is TE probe needed?
My homebuilt self-launching sailplane is getting very close to it's
first flight. However, to make a long story short, I don't have any
good place to install a total energy probe right now. I have an old
variometer that I was planning on starting with, if it still works.
Otherwise I may need to get a new variometer for it, like the B400 or
RAS-V1000. But I see where they require a TE probe. Can these or
similar varios be used without a TE probe and still get useful
results, maybe just hook it up to the static system? Or are there some
small low cost varios that don't need a TE probe?
Thanks in advance,
Jerry Booker
www.jsoaraero.com
Old July 14th 09, 12:29 AM posted to rec.aviation.soaring
Thanks in advance,
Jerry Bookerwww.jsoaraero.com
A good total energy system is more important than what vario you hook
it to.
You may not want to do it right now, but sooner or later you will want
to add it.
Aerodynamically the upper part of the fin seems to work best by
keeping it out of disturbed
flow.
That said, a quick and dirty solution is to mount the probe on the aft
fuselage as far back as you can reach.
Another alternative is buying a vario with electronic compensation.
The down side of this is that you need a pretty good static system to
avoid creating more probelms than you solve.
Good luck and keep us posted.
UH
Old July 14th 09, 03:39 AM posted to rec.aviation.soaring
Eric Greenwell
What speeds do you expect to fly at? The slower you go, the less TE
helps. If your gliding speed range is, say 30 to 50 knots, I say start
off with just the static connection.
You could easily mount a TE in the nose; the drawback is it's more
susceptible to ground damage. A TE probe in the tail is badly affected
by the propeller blast, and can be almost worthless when the engine is
running. Some pilots switch it to static, even cabin static, during the
engine run.
Or are there some
Small, yes, low cost, no. Electronic TE using the pitot and static
require a vario with a pitot input, and the cheap ones don't have it.
You might find what you want by looking at hang glider varios. Their
speed range is probably close to what I'm guessing the Red Tail will be
flying, and their stuff seems to be much cheaper than sailplane instruments.
* Sections on Mode S, TPAS, ADS-B, Flarm, more
Old July 14th 09, 09:00 AM posted to rec.aviation.soaring
Dave Martin[_3_]
If you can get hold of a QWEK converter this should do the job.
The converter is a diaphram inside a capsule that is plumbed into the
vario/asi circuit. Many Polish gliders are fitted with them as standard,
so you may find someone who has one lying around.
They are simple to fit and provided you get them in the right place in the
plumbing work OK. It also requires one per instrument and is G sensitive to
so should be mounted vertically.
Some fin tubes instead of being the conventional fin probe use a venturi
on a probe that could be nose mounted, but again these have their faults
The converter takes a feed from the pitot pressure before it gets to the
ASI, then T's into the vario circuit between the bottle and the
instrument. There must be someone in the US with one lying around. They
just need to be checked to ensure the diaphram has not perished.
Dave
engine run.
Or are there some
instruments.
www.motorglider.org
Old July 14th 09, 04:18 PM posted to rec.aviation.soaring
Ron Gleason
One alternative may be a f
Old July 14th 09, 07:59 AM posted to rec.aviation.soaring
Heinz
Some years ago I build a TE-Probe per Dick Johson for our club's
1-26D. See http://www.postfrontal.com/PDF/PW5_TE.pdf. or search the
SSA site for how to. The whole project cost me a couple of bucks and
took about 1 hr to do.
I mounted the probe just behind the removable turtle-deck
(accessibility issue). I used a phenolic block with a hole for the
probe so that I could raise or lower it to find the "out-of-boundary-
layer" position. about 6-7" did the trick.
And the results were great. Thermal-flying was much eased.
Heinz
Thanks in advance,
Ka-6 TE Probe vontresc Soaring 14 August 30th 08 03:17 AM
TE Probe on ASW-15 [email protected] Soaring 4 April 29th 07 01:43 AM
Outside air temperature probe dlevy Owning 9 November 7th 06 05:14 PM
Old CHT probe replacement Frank Ch. Eigler Owning 3 August 31st 05 03:22 PM
TE-Probe for 1-26D Heinz Gehlhaar Soaring 6 January 17th 05 10:52 PM
