Task Building
Old July 28th 09, 06:32 AM posted to rec.aviation.soaring
Uncle Fuzzy
Default Task Building
Is there any flight planning software that will allow you to:
Load YOUR waypoint file,
Then
Display it graphically on the screen (map overlay showing SUA's would
be nice)
Then
Pick waypoints (by clicking on them, not making text entries!)
OUTPUT: total distance in (pick your units) , distance of each leg,
and percentage of the total distance for each leg. Optionally, allow
un-picking any giving waypoint and picking another.
Generating a task to send to your flight recorder when you're
satisfied with the result.
I have to admit I've only played with See You a little, and really
nothing else.
Old July 28th 09, 11:02 AM posted to rec.aviation.soaring
Dan[_4_]
Then
be nice)
Then
and percentage of *the total distance for each leg. Optionally, allow
nothing else.
StrePla does all that. It also stores the tasks, so that you can
select that task again in the future. Once you select a start point
and first TP, it displays the area (by shading it) that allows for FAI
triangles, etc. It communicates with your flight recorder to pass
declaration, turnpoints, common tasks, and also retrieves flight
tracks. Very graphical, very simple. I've used it with a Volkslogger
since '95. (It also communicates with Pocket StrePla, and passes
maps, airspace, turnpoints, tasks with my IPAQ 3950. They're at
www.strepla.de
Old July 28th 09, 12:36 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Both SeeYou and StrePla do that extremely well.
For SeeYou, you can see how it works in my free online training videos he
http://www.cumulus-soaring.com/train...raining-SeeYou
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Uncle Fuzzy" wrote in message
Then
be nice)
Then
nothing else.
Old July 28th 09, 02:10 PM posted to rec.aviation.soaring
Tuno
That's a decent description of how I edit my tasks in SeeYou.
Use Ctrl-T to go into [Tasks] editing, click the green + in the tool
buttons bar to add a task, and use View | Map (or Alt-1) to edit the
task using clicks and drags on the map. There is a small learning
curve to it but it's very easy once you get the hang of it.
2NO
Old July 28th 09, 02:45 PM posted to rec.aviation.soaring
Uncle Fuzzy
2NO
Thanks to you all! I figured it was just my ignorance of the See You
features that was the problem.
Thanks again!
Old August 5th 09, 08:09 PM posted to rec.aviation.soaring
Fred[_4_]
Then
be nice)
Then
nothing else.
There is a free TaskPlanner written by one of our members.
To to http://www.houstonsoaring.org then Members/Downloads and then
download the TaskPlanner.
You can import any tp file in the Cambridge format.
It has lots of options for which tps to show based on distance, etc.
It displays a map and then you just click on the tps and it calculates
the distance and FAI triangle angles. When you import your tps, just
go to Edit/Add tps and make sure your home gliderport is marked as
home and then it shows up as red, but you can start from any point if
you wish.
Fred - Greater Houston Soaring Association.
How to be a Task-setter / CD noel.wade Soaring 5 September 27th 08 02:00 AM
SeeYou task settings Tuno Soaring 7 February 22nd 07 03:51 AM
New DMSt task: 4 TPs Klaus T. Soaring 0 January 9th 06 12:03 AM
1000k comp task Mel Dawson Soaring 0 July 5th 05 08:22 PM
New Task JJ Sinclair Soaring 5 October 23rd 03 01:36 AM
