XCSoar and HP312
Old August 4th 09, 09:30 AM posted to rec.aviation.soaring
Max Kirschner
Default XCSoar and HP312
Is there an easy way to keep the back light on when using XCSOAR and the
HP312, mine keeps reverting to back light off.
I have tried setting it on in the Road mode.
Max
Old August 4th 09, 01:48 PM posted to rec.aviation.soaring
On Aug 4, 3:30*am, Max Kirschner
Max
Here's what a friend gave me. I have tried this and it works, but if
you let the 310 boot without the SD card in the slot, you will have to
do portions of this over again. I keep a print out of this in my
cockpit, just in case I boot without the card accidentally.
To set the backlight of the iPaq on:
From Windows CE desktop, Start - Settings - Control Panel
• Open "Backlight Control" and set High backlight (max)
• You don't need to change timeouts in the two upper boxes,
• because those values are controlled by "Display Properties".
• Exit "Backlight Control".
• Open "Power Properties".
• Powerscheme: AC Power
• set to "Never" all controls.
• Exit "Power Properties".
• Open "Display Properties"
• Select "Backlight" tag
• Select "Automatically turn off backlight while on external power",
and
• set it to 30 minutes, then exit with Ok.
• Open again "Display Properties"
• DESELECT "Automatically turn off backlight while on external
power".
• Exit with Ok.
• Open "Backlight control" again, you will see that "AC power and
device is idle for"
• box is now EMPTY, correctly. Don't do anything . Press Ok.
Old August 4th 09, 08:45 PM posted to rec.aviation.soaring
Max Kirschner[_2_]
At 12:48 04 August 2009, wrote:
On Aug 4, 3:30=A0am, Max Kirschner
Max
=95 Open "Backlight Control" and set High backlight (max)
=95 You don't need to change timeouts in the two upper boxes,
=95 because those values are controlled by "Display Properties".
=95 Exit "Backlight Control".
=95 Open "Power Properties".
=95 Powerscheme: AC Power
=95 set to "Never" all controls.
=95 Exit "Power Properties".
=95 Open "Display Properties"
=95 Select "Backlight" tag
=95 Select "Automatically turn off backlight while on external power",
and
=95 set it to 30 minutes, then exit with Ok.
=95 Open again "Display Properties"
=95 DESELECT "Automatically turn off backlight while on external
power".
=95 Exit with Ok.
=95 Open "Backlight control" again, you will see that "AC power and
device is idle for"
=95 box is now EMPTY, correctly. Don't do anything . Press Ok.
Many thanks it now works perfectly
Max
Old August 4th 09, 10:07 PM posted to rec.aviation.soaring
Mike Bamberg
Max
and
power".
=95 Exit with Ok.
device is idle for"
Max- Hide quoted text -
- Show quoted text -
There is an alpha version of the software with an automatic backlight
control for the HP 31x PND devices. Hopefully it will be fully
released soon and then you won't have to do all these gyrations to
keep the backlight on.
xcsoar [email protected] Soaring 40 August 13th 09 09:01 PM
HP310 and XCSoar Jim White[_3_] Soaring 2 January 14th 09 06:15 PM
XCSOAR Travis Beach[_2_] Soaring 3 May 24th 08 03:36 PM
XCSoar jorgie Soaring 2 November 2nd 04 12:05 AM
XCSoar Robert Danewid Soaring 2 February 7th 04 01:30 PM
Copyright Š2004-2025 AviationBanter.
