OLC sluts changing wings in mid air
Old August 6th 09, 07:32 AM posted to rec.aviation.soaring
JS
Default OLC sluts changing wings in mid air
At a recent impromptu club meeting at a local pub, the subject came
up:
If you had to bail out, would you get OLC points for the distance
covered under canopy?
The pilot who came up with the idea was supposed to post this,
but...
Imagine taking your logger with you as you jump. Those little things
you can hang around your neck would work, unless they get caught in
the suspension lines of the chute, of course. Or you could simply
unscrew or un-Velcro the logger from the glider or grab the PDA before
you leave. Keep it in your left hand, as you'll need the right for the
ripcord.
Does the OLC have handicapping on parachutes? Round chutes have a
pretty poor glide ratio and would score amazingly if there was any
wind. Strong wave days would be best... Until it came to the landing,
but there are no OLC points for style.
I've seen even students with round parachutes go up in thermals.
Thermal centering would be much easier with a square. With practice
this could lead to some serious points.
Old August 6th 09, 07:52 AM posted to rec.aviation.soaring
Tim Taylor
On Aug 6, 12:32*am, JS wrote:
* At a recent impromptu club meeting at a local pub, the subject came
up:
* The pilot who came up with the idea was supposed to post this,
but...
* Imagine taking your logger with you as you jump. Those little things
ripcord.
* Does the OLC have handicapping on parachutes? Round chutes have a
* I've seen even students with round parachutes go up in thermals.
LOL, I knew the weather has been bad in the Northern Hemisphere but
now I know it is really bad. Way too much time on your hands. I
want to know when will the OLC points factor speed as well as distance
into the score. That will make it much more interesting.
Old August 6th 09, 01:37 PM posted to rec.aviation.soaring
ZL
Tim Taylor wrote:
up:
but...
ripcord.
OLC has you both covered, sort of.
Check under OLC-Scoring for the New OLC-Speed category. Just appeared a
couple weeks ago.
There's also a ParaHangGliding category. Right next to Gliding in the
top menu bar. Doesn't look like its got quite as many participants in
the US yet. Not sure if they have a separate category for air drop
start. And it doesn't look like you'd get a handicap boost for a round
chute, but I could be missing something.
ZL - OLC slut
Old August 6th 09, 02:54 PM posted to rec.aviation.soaring
Uncle Fuzzy
up:
but...
ripcord.
Thanks for reminding me to up my hull insurance for UF. I forgot to
do that when I added the 302A. If I decide to 'switch catagories'
I'll try to remember to take my logger and battery before I go.
Another Jim
The old gives way to the new (then) - A changing era.jpg (1/1) DavidG Aviation Photos 1 May 21st 09 11:55 AM
Changing language in GPS-NAV Paul B Soaring 7 February 8th 08 03:02 AM
X-Wings and Canard Rotor Wings. Charles Gray Rotorcraft 1 March 22nd 05 12:26 AM
Changing Of The Guard Grantland Military Aviation 3 March 14th 04 05:36 PM
Changing from VFR to IFR hawk_spring Simulators 6 October 18th 03 09:41 PM
