UK Ready To Ditch STOVL F-35?
Old August 6th 09, 05:01 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Default UK Ready To Ditch STOVL F-35?
"London's Daily Telegraph reports this morning
that the UK is preparing to switch from the short
take-off, vertical landing (STOVL) version of the
F-35 Joint Strike Fighter to the F-35C carrier (CV)
model, because it costs less and has a greater
weapon load and range."
See:
http://www.aviationweek.com/aw/blogs...5-3993b83569ca
If the UK ditches the F-35B model, will the USMC have
to switch to the F-35C too?
Old August 7th 09, 12:55 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
hcobb
See:
http://www.aviationweek.com/aw/blogs...plckController...
No, they've got the world's best PR. How else could you explain the
EVF?
Doe this mean the Brits will ditch the Frog Carrier for a real one
from the USA?
"The gas-turbine/electric ships would be fitted with separate steam
generators to power the cats."
EMALS being far too complex for them to master I take it?
-HJC
Old August 8th 09, 02:53 PM posted to rec.aviation.military.naval
In article
from the USA?
No, because the gas-turbine carrier is something we can build fairly
readily. And we're still proud - sometimes too proud - about that stuff.
Too wacky for the Daily Telegraph to give credibility to. Other news
sources are definitely discussing it.
Interpreting the biases of the UK press is not exactly simple. The first
thing you have to grasp is that our newspapers don't have any kind of
legal duty to be unbiased, and mostly see their own biases as being a
sensible, middle-of-the-road viewpoint, which the British people would
embrace en masse were they not being misled by rival papers. Some of the
more delusional ones, such as the Daily Express, really do appear to
believe that everyone agrees with them.
The Telegraph is essentially based on the idea that the 1950s were the
last time of earthly paradise, but that there was a kind of Silver Age
in the eighties under Thatcher, at least in the aspects of the time that
weren't forward-looking.
John Dallman,
, HTML mail is treated as probable spam.
Old August 9th 09, 08:10 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Peter Stickney[_2_]
See:
I don't see why, The UK buy is a minor part of the F-35B program.
(Just as it was with the production of the original Harrier)
The USMC buy is somewhere between 270-400 aircraft, depending on which
projections you look at. The RAF is looking for 90, and the RN is looking
for 60.
Pete Stickney
The better the Four Wheel Drive, the further out you get stuck.
Old August 10th 09, 09:35 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
In my view the STOVL F-35 version is in most situations the best air
superiority and air defense weapon in the world.
This is because the most vulnerable part of a fighters is its landing
and takeoff field. Apart from 'death star' super powers such as the
USA with a big reserve of aircraft safe in the continental USA many
airforces were defeated on the ground. Consider the problem of
defending nations bordering the ex USSR (eg Sweden, Norway, Finland,
Germany). The STOVL version could potentially be dispersed in
forrests, sand embankments such that the STOVL fighters can quickly
climb up and ambush the enemy using advanced Meteor or AMRAAM style
missiles.
This apect of its capabilities seems to be neglected despite this
being a dream of the Luftwaffe in the 1950s and 60s. (who had an
extensive and interesting STOVL program).
The USN version, the F-35B, is interesting due to its enlarged wing
area making it potentially highly manouverable. It appears it isn't
stressed to be a dog fighter. I suspect that might be changed.
Old August 10th 09, 10:01 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jeb in Richmond
and takeoff field. *Apart from 'death star' super powers such as the
Germany). * The STOVL version could potentially be dispersed in
missiles.
being a dream of the Luftwaffe in the 1950s and 60s. *(who had an
area making it potentially highly manouverable. *It appears it isn't
stressed to be a dog fighter. *I suspect that might be changed.
The STOVL F-35 is not going to be capable of true vertical takeoff
with any kind of payload and probably its vertical landing performance
is going to be more marginal than the Harrier's. It's certainly going
to be more destructive; the V-22s are already tearing up the same
decks that the Marines want to operate F-35s off of, so it's almost
guaranteed that at some point, the Marines will have to stop using the
STOVL birds off the same helo decks in order to preserve them for
actual helicopters. If you're wanting to use roadways and other
civilian structures for flight ops, buy the carrier version and rely
on its tougher structure.
Old August 10th 09, 11:56 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
missiles.
I pair of AMRAAMs is all it needs to be a threat and I believe it can
actually carry an additonal pair of smaller AAMs in the interior
weapons bays.
actual helicopters.
I don't suppose anyone though of putting aside some money for
improvements to the decks so that they can handle the exhaust eflux
of a F-35 and X-22?
Similary mobile platforms can be developed to protect the 'civilan
structures' and there are also alternatives to concrete that can
handle much higher heats and stresses.
Perhaps the X-22 needs a reverse flow combustion chamber so that the
exhaust is just behined the prop and therefore somewhat diliuted by
air.
on its tougher structure.- Hide quoted text -
- Show quoted text -
Old August 11th 09, 02:05 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jeb in Richmond
weapons bays.
They were having a hard enough time with getting the empty weight
where it needed to be to achieve hover. It's not as bad as X-32 was,
but still. If you're planning on flying air-to-air with two missiles
and a partial fuel load, then maybe it's acceptable, but there's a
reason they're not calling this a VTOL airframe.
I wonder how a short takeoff run will look in the F-35? Will they even
swivel the exhaust or just rely on the lift fan to augment the wing
lift?
Old August 10th 09, 10:14 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
William Black[_1_]
missiles.
That's because there's no credible threat in the medium term.
William Black
The secret of life is honesty and fair dealing.
If you can fake that, you've got it made.
Old August 10th 09, 10:54 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
hcobb
missiles.
If only the Eurofighter had a ghost of a chance of matching its
original landing distance spec.
-HJC
Carrier Variant Of F-35B Lightning II, STOVL Mike[_7_] Naval Aviation 0 October 27th 07 11:23 PM
Couple local guys ditch a plane in a river John Huthmaker Piloting 3 January 17th 06 05:29 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 11th 04 11:45 PM
Norway may ditch the JSF! John Cook Military Aviation 13 May 11th 04 12:39 AM
Travolta - did he ever ditch an aircraft? TheShootingSports Piloting 60 March 23rd 04 12:51 PM
