I have recently red that instantenious rate of turn of Vietnam vintage supersonic
fighters is less than 15 deg/sec. What are the excat figures for F-4, F-105 and F-8? Please include speed and altitude. Nemanja Vukicevic student of aircreft engineering |
"Wolfhenson" wrote in message om... I have recently red that instantenious rate of turn of Vietnam vintage supersonic fighters is less than 15 deg/sec. What are the excat figures for F-4, F-105 and F-8? Please include speed and altitude. Well, I don't have any pubs or tacmans available, so we're going on memory, but you number is maybe a bit low for a hard-wing F-4, real close for the F-8, definitely too high for the 105. Corner speed (6.5 G) for Phantom was about 425KIAS, 370 for F-8, 105 was higher. Ed Rasimus should be able to give you some data there. Ignoring momentary pitch rates (which can be phenomenally high) current fighters can exceed 20 degrees/second. R / John |
On Fri, 13 Aug 2004 14:24:14 -0500, "John Carrier"
wrote: "Wolfhenson" wrote in message . com... I have recently red that instantenious rate of turn of Vietnam vintage supersonic fighters is less than 15 deg/sec. What are the excat figures for F-4, F-105 and F-8? Please include speed and altitude. Well, I don't have any pubs or tacmans available, so we're going on memory, but you number is maybe a bit low for a hard-wing F-4, real close for the F-8, definitely too high for the 105. Corner speed (6.5 G) for Phantom was about 425KIAS, 370 for F-8, 105 was higher. Ed Rasimus should be able to give you some data there. Corner velocity, by definition, is the minimum speed at which you can generate maximum allowable G-load. So, the corner for the F-4 relates to 7.33+ G at most weights. We usually used 420 KIAS for the F-4 hard-wing. The max G, of course, could be considerably reduced based on stores retained--even empty fuel tanks. For the F-105, which had a max allowable G of 8.2, the speed was higher--generally considered around 480 KIAS. But, the fact of the matter was that drag rose so fast at high G that you couldn't sustain for very long--airspeed bleed off put you below corner very rapidly. (One reason why an F-105 driver only felt comfortable in the 540-600 KIAS region!). Generally, the sustained turn rate was around 14-15 degrees/second for the F-4 hard-wing and about 12.5-13.5 for the F-105. The real issue with the 105 in air/air was that if an opponent could come up to your speed, he couldn't turn with you. If you slowed to his speed, you'd be the main course for lunch. Ignoring momentary pitch rates (which can be phenomenally high) current fighters can exceed 20 degrees/second. That is SUSTAINED!!!! The idea of holding 9 Gs for a while still makes my vision dim sitting at the computer. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Phantom Flights, Bangkok Nights" Both from Smithsonian Books ***www.thunderchief.org |
Ed Rasimus wrote:
On Fri, 13 Aug 2004 14:24:14 -0500, "John Carrier" wrote: "Wolfhenson" wrote in message . com... I have recently red that instantenious rate of turn of Vietnam vintage supersonic fighters is less than 15 deg/sec. What are the excat figures for F-4, F-105 and F-8? Please include speed and altitude. Well, I don't have any pubs or tacmans available, so we're going on memory, but you number is maybe a bit low for a hard-wing F-4, real close for the F-8, definitely too high for the 105. Corner speed (6.5 G) for Phantom was about 425KIAS, 370 for F-8, 105 was higher. Ed Rasimus should be able to give you some data there. Corner velocity, by definition, is the minimum speed at which you can generate maximum allowable G-load. So, the corner for the F-4 relates to 7.33+ G at most weights. We usually used 420 KIAS for the F-4 hard-wing. The max G, of course, could be considerably reduced based on stores retained--even empty fuel tanks. For the F-105, which had a max allowable G of 8.2, the speed was higher--generally considered around 480 KIAS. But, the fact of the matter was that drag rose so fast at high G that you couldn't sustain for very long--airspeed bleed off put you below corner very rapidly. (One reason why an F-105 driver only felt comfortable in the 540-600 KIAS region!). Generally, the sustained turn rate was around 14-15 degrees/second for the F-4 hard-wing and about 12.5-13.5 for the F-105. H'mm, those numbers seem kind of high for both, as far as sustained capability goes. 400 KTAS, turn rate in Deg./sec. (rounded off) = 19 (7g); 22 (8g). 500KTAS, turn rate in Deg./sec. (rounded off) = 15 (7g); 17 (8g); 20 (9g). 600KTAS, turn rate in Deg./sec. (rounded off) = 13(7g); 14 (8g); 16 (9g). One source (Richardson/Spick) gives steady state turn radii and time to make a 180 for the slat-wing and hard-wing, @ M0.6 and 0.9, 10kft. The slat-wing has the advantage, making a 180 in 15.53 sec. @ M0.6 (11.59 deg./sec.), and 13.96 sec. @ M0.9 (12.89 deg./sec.). The hard wing appears to be perhaps 10-20 deg. or so behind. Assuming ISA, @10kft, Mach 1.0 is 638 knots. M0.6 and M0.9 = 383 and 574 KTAS respectively, so M0.6 is well under F-4 (hard) corner, M0.9 a bit over at that height -- assuming KIAS = KCAS, 420 KCAS = 490 KTAS @10kft. OTOH the Thuds 480 KCAS corner is slightly under M0.9; ca. 558 KTAS. FWIW, the same source has a graph comparing the hard and slat-winged F-4's Ps capability @ M0.9 and10kft. The hard-wing has a Ps advantage at low g (4.5g), with the slat-wing advantaged at higher g, although the slats apparently have a lower max. g limit, +7 vs. +7.33g. Guy |
On Fri, 13 Aug 2004 23:08:33 GMT, Guy Alcala
wrote: Ed Rasimus wrote: Corner velocity, by definition, is the minimum speed at which you can generate maximum allowable G-load. So, the corner for the F-4 relates to 7.33+ G at most weights. We usually used 420 KIAS for the F-4 hard-wing. The max G, of course, could be considerably reduced based on stores retained--even empty fuel tanks. For the F-105, which had a max allowable G of 8.2, the speed was higher--generally considered around 480 KIAS. But, the fact of the matter was that drag rose so fast at high G that you couldn't sustain for very long--airspeed bleed off put you below corner very rapidly. (One reason why an F-105 driver only felt comfortable in the 540-600 KIAS region!). Generally, the sustained turn rate was around 14-15 degrees/second for the F-4 hard-wing and about 12.5-13.5 for the F-105. H'mm, those numbers seem kind of high for both, as far as sustained capability goes. 400 KTAS, turn rate in Deg./sec. (rounded off) = 19 (7g); 22 (8g). 500KTAS, turn rate in Deg./sec. (rounded off) = 15 (7g); 17 (8g); 20 (9g). 600KTAS, turn rate in Deg./sec. (rounded off) = 13(7g); 14 (8g); 16 (9g). One source (Richardson/Spick) gives steady state turn radii and time to make a 180 for the slat-wing and hard-wing, @ M0.6 and 0.9, 10kft. The slat-wing has the advantage, making a 180 in 15.53 sec. @ M0.6 (11.59 deg./sec.), and 13.96 sec. @ M0.9 (12.89 deg./sec.). The hard wing appears to be perhaps 10-20 deg. or so behind. Assuming ISA, @10kft, Mach 1.0 is 638 knots. M0.6 and M0.9 = 383 and 574 KTAS respectively, so M0.6 is well under F-4 (hard) corner, M0.9 a bit over at that height -- assuming KIAS = KCAS, 420 KCAS = 490 KTAS @10kft. OTOH the Thuds 480 KCAS corner is slightly under M0.9; ca. 558 KTAS. FWIW, the same source has a graph comparing the hard and slat-winged F-4's Ps capability @ M0.9 and10kft. The hard-wing has a Ps advantage at low g (4.5g), with the slat-wing advantaged at higher g, although the slats apparently have a lower max. g limit, +7 vs. +7.33g. Guy Remember that fighter pilots generally don't have time (even in today's computer laden techno-wonder aircraft) to go through that kind of convolution of calculations. For example, at 400 KIAS (not KTAS) you couldn't get 8G in an F-4. Note that all of your start numbers are offered in "true" rather than indicated airspeed. There are other issues, such as with the hard-wing vs soft-wing question for the F-4--you'll get different performance between the B, C, D, S, J, K, G, and E models depending upon things like TISEO, slotted slabs, C/G etc. Generally, you are correct that the hard-wing finishes the turn well behind the LES bird, but in a lot of situations the hard-wing sustains while the LES bird experiences rapid drag rise and airspeed bleed-off. P-sub-s advantage, as you say, usually goes to the hard-wing. The LES bird only wins in the knife fight. Finally, my head hurts and I don't want to open the door to the complexities of trying to calculate comparisons between KIAS, KTAS and mach as related to turn rate. Basic rule (kept simple for dumb fighter drivers) is that it takes indicated airspeed to pull G. Mach don't make turn (and for that generation super-sonic meant an incredible loss of G potential) and true airspeed is only valuable for getting to the bar early. Indicated (and it's close relative calibrated) is the only knots you need to worry about when you want to max perform. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" "Phantom Flights, Bangkok Nights" Both from Smithsonian Books ***www.thunderchief.org |
Ed Rasimus wrote:
On Fri, 13 Aug 2004 23:08:33 GMT, Guy Alcala wrote: Ed Rasimus wrote: Corner velocity, by definition, is the minimum speed at which you can generate maximum allowable G-load. So, the corner for the F-4 relates to 7.33+ G at most weights. We usually used 420 KIAS for the F-4 hard-wing. The max G, of course, could be considerably reduced based on stores retained--even empty fuel tanks. For the F-105, which had a max allowable G of 8.2, the speed was higher--generally considered around 480 KIAS. But, the fact of the matter was that drag rose so fast at high G that you couldn't sustain for very long--airspeed bleed off put you below corner very rapidly. (One reason why an F-105 driver only felt comfortable in the 540-600 KIAS region!). Generally, the sustained turn rate was around 14-15 degrees/second for the F-4 hard-wing and about 12.5-13.5 for the F-105. H'mm, those numbers seem kind of high for both, as far as sustained capability goes. 400 KTAS, turn rate in Deg./sec. (rounded off) = 19 (7g); 22 (8g). 500KTAS, turn rate in Deg./sec. (rounded off) = 15 (7g); 17 (8g); 20 (9g). 600KTAS, turn rate in Deg./sec. (rounded off) = 13(7g); 14 (8g); 16 (9g). One source (Richardson/Spick) gives steady state turn radii and time to make a 180 for the slat-wing and hard-wing, @ M0.6 and 0.9, 10kft. The slat-wing has the advantage, making a 180 in 15.53 sec. @ M0.6 (11.59 deg./sec.), and 13.96 sec. @ M0.9 (12.89 deg./sec.). The hard wing appears to be perhaps 10-20 deg. or so behind. Assuming ISA, @10kft, Mach 1.0 is 638 knots. M0.6 and M0.9 = 383 and 574 KTAS respectively, so M0.6 is well under F-4 (hard) corner, M0.9 a bit over at that height -- assuming KIAS = KCAS, 420 KCAS = 490 KTAS @10kft. OTOH the Thuds 480 KCAS corner is slightly under M0.9; ca. 558 KTAS. FWIW, the same source has a graph comparing the hard and slat-winged F-4's Ps capability @ M0.9 and10kft. The hard-wing has a Ps advantage at low g (4.5g), with the slat-wing advantaged at higher g, although the slats apparently have a lower max. g limit, +7 vs. +7.33g. Guy Remember that fighter pilots generally don't have time (even in today's computer laden techno-wonder aircraft) to go through that kind of convolution of calculations. For example, at 400 KIAS (not KTAS) you couldn't get 8G in an F-4. Note that all of your start numbers are offered in "true" rather than indicated airspeed. Because TAS and g give turn radius and rate independent of altitude, while using KIAS/KCAS doesn't. I converted them to KCAS to see what TAS/Mach the a/c would be at a fairly 'typical' combat altitude for Vietnam. There are other issues, such as with the hard-wing vs soft-wing question for the F-4--you'll get different performance between the B, C, D, S, J, K, G, and E models depending upon things like TISEO, slotted slabs, C/G etc. Sure, but lacking the graphs for all those, I can only provide what I have. Generally, you are correct that the hard-wing finishes the turn well behind the LES bird, but in a lot of situations the hard-wing sustains while the LES bird experiences rapid drag rise and airspeed bleed-off. P-sub-s advantage, as you say, usually goes to the hard-wing. At low g, anyway. Once induced drag becomes the major component instead of form/wave drag, the advantage appears to be the other way. The LES bird only wins in the knife fight. Finally, my head hurts and I don't want to open the door to the complexities of trying to calculate comparisons between KIAS, KTAS and mach as related to turn rate. Basic rule (kept simple for dumb fighter drivers) is that it takes indicated airspeed to pull G. Mach don't make turn (and for that generation super-sonic meant an incredible loss of G potential) and true airspeed is only valuable for getting to the bar early. Indicated (and it's close relative calibrated) is the only knots you need to worry about when you want to max perform. I agree, but since the question was asked (and answered) relative to dps at various altitudes and speeds, you need to look at that using TAS vs. g, because radius/rate at constant TAS and g don't vary with altitude. Once you do, you can convert it to KIAS/KCAS, to see how fast the a/c thinks it's going (and if it's even capable of that combination). As you say, for corner velocity the pilot's only concerned with KIAS or KCAS, whichever the instruments display. Guy |
Easy question but no easy answers.
Turn performance is going to depend on gross weight, configuration, and density altitude. It all boils down to drag and engine performance...so clean configurations, low fuel weights, and low density altitudes are required to get max performance. Unfortunately, we seldom had these when turn performance counted...we were usually heavy and relatively high...so much of this is just an academic discussion. As Ed pointed out, corner is the most g for the min speed. I might add that there is no "one" corner speed. Corner varies with the three variables I mentioned above. Most of our energy maneuverability (EM) diagrams were based on optimistic conditions (relatively clean and 1/2 internal fuel). From these, here are some generalizations. 1. Corner velocities varied from the high 300s to the high 400s (indicated airspeed...we didn't think in terms of TAS or mach, again as Ed said)...and this varied with aircraft type, weight, and altitude. 2. Max g in the F-4 was 8.5...but you had to be running practically on fumes to be able to get there without over-g'ing the jet. 3. A slatted F-4 at about 420KIAS could hit a little over 20 degrees per second in instantaneous turn rate...but could not sustain this. A relatively clean F-4E(S) at 39000+ lbs and 5000' MSL could sustain about 7.5 g's...but had to be at about 525KIAS to do this. Sustained g in the lower 400s dropped off to around 6g for these conditions. 4. I haven't flown the F-8 but I would imagine its numbers would be similar but attained a slightly slower speeds. 5. An interesting comparison is the F-104G. Under similar conditions, the Zipper had a lesser instantaneous g capability...about 15 dps (lower placard g limit) but a higher sustained capability (around 10-12dps, depending on which EM diagram you want to believe). Corner for the 104 was about 420KIAS under 10,000'MSL and best 0 Ps was at about 500KIAS or so. These numbers and observations come from personal experience in the jets and moldy old EM diagrams! Andy Bush "Wolfhenson" wrote in message om... I have recently red that instantenious rate of turn of Vietnam vintage supersonic fighters is less than 15 deg/sec. What are the excat figures for F-4, F-105 and F-8? Please include speed and altitude. Nemanja Vukicevic student of aircreft engineering |
Seriously snipped.
Corner velocity, by definition, is the minimum speed at which you can generate maximum allowable G-load. So, the corner for the F-4 relates to 7.33+ G at most weights. We usually used 420 KIAS for the F-4 hard-wing. The max G, of course, could be considerably reduced based on stores retained--even empty fuel tanks. The F-4's I flew (non-slatted J) had a 6.5 limit in the fighter configuration. There was a flight regime and gross weight where up to 8.5 G was permissible (around .7 mach ... which meant you had to be pretty low otherwise the KIAS wasn't there ... and 37.5K). IIRC, the Vn diagram tapered off from that peak of 8.5 at .7 IMN to 6.5 at approx 1.0 IMN. (I suspect a function of fuselage bending loads as the center of lift moved aft). Any time we'd exceed 6.5, the maintenance types would get your G, mach and weight and enter the performance charts to compute whether the over-G was truly in or out of the envelope. Typical culprit was an unexpected transonic pitch up at low altitudes. Generally, the sustained turn rate was around 14-15 degrees/second for the F-4 hard-wing and about 12.5-13.5 for the F-105. Don't know where you got these numbers, but sustained for the F-4 was under 10 degrees/sec at combat altitudes and weights (we typically used 15K, 4+4, no tanks, and 60% fuel) and was found at around 450 KIAS. The F-8 could do just under 11 degrees/sec @ 400 in similar conditions (better wing, less wing loading, not much less T/W). ... roughly a 1 degree/sec advantage. Of course the Mig-21 (the adversary we trained for) was a couple better than that. Still looking at under 15 degree/sec sustained. Ignoring momentary pitch rates (which can be phenomenally high) current fighters can exceed 20 degrees/second. That is SUSTAINED!!!! The idea of holding 9 Gs for a while still makes my vision dim sitting at the computer. Many jets have a lower G limit (typically 7.5). I've timed the F-14 and F-18 at airshows (do the T-bird solos do a max perf 360?). Of course, whether or not the pilot is truly at max performance or not in the wind-up turn is unknown, but a 360 (roll in to roll out) takes around 20-24 seconds, somewhat less than 20/sec. I got a single seat A-4 (stripped adversary) to 20 degrees/sec (not quite sustained, I lost a couple knots) in a 360 @ 1,000 feet and 180 KIAS 1/2 flaps. R / John |
the F-4 hard-wing and about 12.5-13.5 for the F-105. H'mm, those numbers seem kind of high for both, as far as sustained capability goes. 400 KTAS, turn rate in Deg./sec. (rounded off) = 19 (7g); 22 (8g). 500KTAS, turn rate in Deg./sec. (rounded off) = 15 (7g); 17 (8g); 20 (9g). 600KTAS, turn rate in Deg./sec. (rounded off) = 13(7g); 14 (8g); 16 (9g). I'm missing something here. You say the numbers are high and then offer higher numbers. Or are these just basic computations of turn rates w/o regard to airframe factors? Our thread has digressed slightly as we shifted the discussion from instantaneous turn to sustained turn. The former is reached at the upper left corner of the Vn diagram (curiously referred to as corner speed). The latter is achieved at zero PsubS, typically at higher KIAS and influenced by induced drag and (usually) transonic drag. To my knowledge no aircraft can sustain a turn at corner speed at typical combat altitudes (but get a clean F-16 low enough, hmm). One source (Richardson/Spick) gives steady state turn radii and time to make a 180 for the slat-wing and hard-wing, @ M0.6 and 0.9, 10kft. The slat-wing has the advantage, making a 180 in 15.53 sec. @ M0.6 (11.59 deg./sec.), and 13.96 sec. @ M0.9 (12.89 deg./sec.). The hard wing appears to be perhaps 10-20 deg. or so behind. Assuming ISA, @10kft, Mach 1.0 is 638 knots. M0.6 and M0.9 = 383 and 574 KTAS respectively, so M0.6 is well under F-4 (hard) corner, M0.9 a bit over at that height -- assuming KIAS = KCAS, 420 KCAS = 490 KTAS @10kft. OTOH the Thuds 480 KCAS corner is slightly under M0.9; ca. 558 KTAS. FWIW, the same source has a graph comparing the hard and slat-winged F-4's Ps capability @ M0.9 and10kft. The hard-wing has a Ps advantage at low g (4.5g), with the slat-wing advantaged at higher g, although the slats apparently have a lower max. g limit, +7 vs. +7.33g. I had the opportunity to fly against both hard and soft wing F-4's as an adversary on many occasions. The dynamics of ACM don't allow such fine measurements. Subjectively, the slat generated significantly better turn rates at the expense of energy addition rate and vertical performance. IIRC, the VX-4 brief advertised around the order of 2 degrees/sec advantage for the slat sustained and a 50 knot reduction in corner speed. One thing stood out, it's buffet-free performance didn't give the pilot many cues as to where his airspeed was headed ... easy to decell to a point where the energy package was zip-point. R / John |
John Carrier wrote:
Generally, the sustained turn rate was around 14-15 degrees/second for the F-4 hard-wing and about 12.5-13.5 for the F-105. H'mm, those numbers seem kind of high for both, as far as sustained capability goes. 400 KTAS, turn rate in Deg./sec. (rounded off) = 19 (7g); 22 (8g). 500KTAS, turn rate in Deg./sec. (rounded off) = 15 (7g); 17 (8g); 20 (9g). 600KTAS, turn rate in Deg./sec. (rounded off) = 13(7g); 14 (8g); 16 (9g). I'm missing something here. You say the numbers are high and then offer higher numbers. Or are these just basic computations of turn rates w/o regard to airframe factors? snip Yes. I wanted to show what the maximum turn rate was for the various KTAS/g combinations; sustained would be less. Guy |
| Thread Tools | |
| Display Modes | |
| B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In | zeno | Instrument Flight Rules | 0 | October 30th 04 07:20 PM |
| B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In | zeno | Home Built | 0 | October 30th 04 07:19 PM |
| Why was the Fokker D VII A Good Plane? | Matthew G. Saroff | Military Aviation | 111 | May 4th 04 06:34 PM |
| US (Brit/Japanese/German/USSR) Use of Gun Cameras in Fighters?? | ArtKramr | Military Aviation | 3 | July 17th 03 07:02 AM |
| CUrtiss Hawk 75 performance debate | Jukka O. Kauppinen | Military Aviation | 3 | July 16th 03 11:45 AM |
