Subject says it all. Why do the landings for night currency have to
be made to a full stop? Thanks Chris |
On Aug 11, 6:39*pm, wrote:
Subject says it all. *Why do the landings for night currency have to be made to a full stop? Thanks Chris Look at the regs for day time currency. . The easy answer is, if you bounce enough you could otherwise get 2 touch and go a littles, then a full stop, on a 5000 foot runway. Why would you want to skimp on proving to yourself you were still sharp enough? If you did three and weren't happy with them, even if to a full stop, would you stop because you could put a check mark next to current, or would you go back for some more to prove to yourself, not anyone else, you were good enough? I'd not want to fly with someone else as a PIC if he or she told me she had been inactive, then did 3 touch and goes. Would you? |
... Subject says it all. Why do the landings for night currency have to be made to a full stop? Because the takeoffs should be from a dead start. |
because the FAA says so...
Randy L. -- Remember: Any landing that you can walk away from, is a landing that you can be fined, sued, or prosecuted for. "a" wrote in message ... On Aug 11, 6:39 pm, wrote: Subject says it all. Why do the landings for night currency have to be made to a full stop? Thanks Chris Look at the regs for day time currency. . The easy answer is, if you bounce enough you could otherwise get 2 touch and go a littles, then a full stop, on a 5000 foot runway. Why would you want to skimp on proving to yourself you were still sharp enough? If you did three and weren't happy with them, even if to a full stop, would you stop because you could put a check mark next to current, or would you go back for some more to prove to yourself, not anyone else, you were good enough? I'd not want to fly with someone else as a PIC if he or she told me she had been inactive, then did 3 touch and goes. Would you? |
On Aug 12, 1:17*pm, Ross wrote:
wrote: Subject says it all. *Why do the landings for night currency have to be made to a full stop? Thanks Chris I read the replies and I hope this is a better answer. One poster said it correctly, the FARs say you have to. But, night flying is so different than day. The perspectives of the runway environment are different and whether you have a dark night or a full moon night. Safety would be an answer, but I think it is more the difference. Night flying on a moonless night is akin to IFR, almost, especially in a sparsely populated area. Just another bit of information. Before I had to sell my plane, our local airport wanted to get night approach lights. I took the airport sponsor and another pilot and went to a couple of airports that had VASI lights. I made much better landings at night following the VASI than I did at my home airport without them. I really found it amazing. I guess ThenI tended to be high on approach at night. -- Regards, Ross C-172F 180HP Sold ![]() KSWI If you want to really test your night time skills, find an isolated uncontrolled airport with minimal lighting -- be sure it has a 4000 foot or more runway. Then, do your landings planning touchdown a thousand feet from the approach end. The only way I can do it consistantly is to put the Mooney in landing configuration, set the manifold pressure to where I want it, and fly the approach airspeed. I make throttle adjustments until my target flare point stays fixed in my sight picture when I'm 500 feet above the ground. I would much rather fly an ILS to minimums with a crosswind component near max allowable than fly into small airports with basic lighting at night. At least on an ILS when I look up and see the airport invironment I know where things are supposed to be. Landing between the RR lights, or just setting up right, means among other things factoring in the width of the runway when imagining the sight picture to look for. I prove all too often that that 'Right Stuff" is really hard to find in my flight bag. |
"Ross" wrote in message ... am wrote: Subject says it all. Why do the landings for night currency have to be made to a full stop? Thanks Chris I read the replies and I hope this is a better answer. One poster said it correctly, the FARs say you have to. I think he already knew that, but wanted the logic behind it, so the below certainly helps. But, night flying is so different than day. The perspectives of the runway environment are different and whether you have a dark night or a full moon night. Safety would be an answer, but I think it is more the difference. Night flying on a moonless night is akin to IFR, almost, especially in a sparsely populated area. Just another bit of information. Before I had to sell my plane, our local airport wanted to get night approach lights. I took the airport sponsor and another pilot and went to a couple of airports that had VASI lights. I made much better landings at night following the VASI than I did at my home airport without them. I really found it amazing. I guess I tended to be high on approach at night. I find night landing not so much a problem as takeoffs, since we're pretty much in open, dark country and once airborne the depth perception diminishes rather quickly. It's not so bad when in and out quickly. Matt |
BT wrote:
what are "night approach lights"? do not recall hearing that term before BT "Ross" wrote in message ... snip -- Regards, Ross C-172F 180HP Sold ![]() KSWI It was my lame term for VASI, etc type of approach landing light systems. -- Regards, Ross C-172F 180HP Sold ![]() KSWI |
| Thread Tools | |
| Display Modes | |
| Why must night landings be full-stop? | Ron Garret | Piloting | 25 | March 17th 08 01:34 PM |
| Night currency question | john | Piloting | 55 | December 19th 07 08:00 AM |
| Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 08:52 PM |
| regaining night currency but not alone | Teacherjh | Instrument Flight Rules | 11 | May 28th 04 03:08 PM |
| Night Currency | Doug Campbell | Instrument Flight Rules | 21 | October 17th 03 11:53 PM |
