Welding and fumes
Old August 13th 09, 10:31 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Welding and fumes
Two weeks ago I had my fuselage sandblasted and coated with two-part
epoxy. I had to get it primed prior to welding because it's going to
be outside and I need the 4130 tubing to be protected.
Prior to welding a tab, I used the torch to burn off the epoxy
coating. I noticed lots of fumes.
Is there a better way of removing the epoxy coating?
Are there any other precautions I should take beside simply trying to
keep my face out of the fumes? - Mike
Old August 18th 09, 06:54 PM posted to rec.aviation.homebuilt
flybynightkarmarepair
Sandblast it off with Black Beauty (slag) or steel shot. Walnut
shells won't do squat. Glass beads might work.
You could also try chemical strippers - depends on the epoxy. Use the
nasty Methyene Chloride stuff, epoxy just sneers at the "green"
strippers, for the most part.
Old August 19th 09, 04:05 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Tue, 18 Aug 2009 10:54:57 -0700 (PDT), flybynightkarmarepair
I'd go with the bead blast or shot blast. a dust off after leaves no
residual surface chemicals to stuff up the weld.
ballottini at 150psi will make short work of the epoxy.
well it would take my polyfiber 2 pack epoxy back no problems at all.
Stealth Pilot
Gas Welding Aid 1 - welding clamp 1.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 1 March 26th 09 07:20 AM
gas welding aid 2 - welding clamp 2.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:58 AM
gas welding aid 2 - welding clamp 2.JPG (0/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:57 AM
Gas Welding Aid 1 - welding clamp 1.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:50 AM
welding rod Del Rawlins Home Built 0 July 15th 03 11:21 AM
