Book suggestions; Practical Welding
Old August 20th 09, 11:04 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Book suggestions; Practical Welding
I'm an OxAy welder or rather, I can weld a nice bead on .035 4130 and
can jig up and build a cluster. But only on a workbench.
There is a wealth of practical knowledge that's not covered in the
books I have; for example, how do you weld on an aircraft while
retaining the fabric covering (think WHOOSH!!!!!)
Anyone found a book that goes past the basics and discusses practical
hint and kinks? - Mike
Old August 24th 09, 10:39 PM posted to rec.aviation.homebuilt
Phil
WHOOSH .... is bad , I have been in the EAA for about 1000 years , used to
work for A/C manufacturing as certified welder , have had to do repairs on
covered planes , we just cut the cover away for 10 or 12 inches in every
direction and taped it fast , got some wet rags and packed every inch of
fabric with wet cloth , you really have to be aware of your torch and treat
it like a loaded gun , welding near fabric is not a solo job either, you
must have a extra man with an extinguisher and also a water hose under
pressure , it can and is done often , the newer TIG process does confine the
heat to a smaller area and less apt to have a disaster , good luck ..Phil L.
"Michael Horowitz" wrote in message
Old August 27th 09, 01:55 AM posted to rec.aviation.homebuilt
echristl
heat to a smaller area and less apt to have a disaster , good luck ..Phil L."Michael Horowitz" wrote in message
Also, aluminum foil is your friend. Put it over the wet rags. It is
cheap and effective for containing the "Oops! I pointed the flame the
wrong way for a second."
gas welding aid 2 - welding clamp 2.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:58 AM
Gas Welding Aid 1 - welding clamp 1.JPG (1/1) Stealth Pilot[_2_] Aviation Photos 0 March 26th 09 03:50 AM
There has _got_ to be a book that discusses 'practical welding' Mike Owning 2 April 16th 06 11:15 PM
Practical welding? mhorowit Home Built 21 August 23rd 05 04:33 AM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
