ellison carb
Old August 25th 09, 11:54 AM posted to rec.aviation.homebuilt
Philippe[_2_]
Default ellison carb
Hello,
Ellison claims the Ellison Throttle Body Injector need a heating box.
Some users say they never experiment any carb icing.
My question: is any ellison user experiment a TBI carb icing?
Thanks
Philippe Vessaire Ò¿Ó¬
Old August 25th 09, 02:39 PM posted to rec.aviation.homebuilt
Stealth Pilot[_3_]
On Tue, 25 Aug 2009 12:54:44 +0200, Philippe
Hello,
Thanks
phillipe
the word you needed was experience
has any ellison user experienced throttle body carb icing?
(you can say rude words in french now :-) )
Stealth Pilot
Old August 25th 09, 04:02 PM posted to rec.aviation.homebuilt
Ron Webb
Use the heat box!
I had an experimental with an io360. Had a tendancy in certain weather
conditions to cut out during takeoff. You'd be at a couple hundred feet, and
it'd either start to miss, or just outright stop. Very embarassing. Happened
more than once.
Turned out that if the air temp was about 70F with high humidity, it was
icing up. The low pressure point in the airflow was right at the fuel
delivery bar. I put a temp sensor there and saw 22F at that point. Remember
the gas law: PV=NRT. As pressure goes down, temperature goes down. It works.
Put in a heat box. Make sure it works. There is supposed to be 90F of change
in temp with the heat in. Use it on takeoff.
"Philippe" wrote in message
news:1267456.3S40VBb9nU@GastonCoute...
Hello,
Thanks
Old August 26th 09, 01:41 AM posted to rec.aviation.homebuilt
Hello,
Thanks
In Canada they are required by law unless you can demonstrate icing is
impossible.
Ellison throttle body ADK Home Built 10 June 21st 06 11:20 AM
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
Carb temp guage vs. Iceman carb ice detector Mike Rapoport Piloting 1 September 28th 04 03:13 AM
Ellison TBI and ROTAX 582 Bill Elliott Aerobatics 0 December 22nd 03 05:58 PM
Ellison TBI and ROTAX 582 Bill Elliott Home Built 0 December 22nd 03 05:58 PM
