Seems a little strange-
Old January 25th 05, 07:37 AM
Capt.Doug
Default Seems a little strange-
It seems a little strange when Havana Center says "Cleared to flight level
three zero zero". It seems a little strange going eastbound at FL 310. It
seems a little strange when Atlanta Center actually has a different altitude
available while going to O'Hare. It seems very strange when another airliner
passes within a 1000' at FL 360.
I just finished my first trip with RVSM (Conveniently sitting on a Caribbean
island while many of ya'll got snowed on- Nah Nah!). It didn't take long to
overcome the strangeness and appreciate the new way (unlike when they
started calling airspace by classes).
It is good, unless you are one of the uncertified stuck at FL280. A friend
in Washington DC related to me that after the inauguration there was a
logjam of airplanes waiting to depart at FL280 while his RVSM ride went
around all of them for a hasty departure. Another friend who drives a Lear
is stuck at 280 and can barely make TEB from MIA now.
D.
Old January 25th 05, 10:02 PM
zatatime
On Tue, 25 Jan 2005 06:37:40 GMT, "Capt.Doug"
D.
Care to elaborate for us non-flight level flyers why FL280 is now some
sort of magic number? I didn't know you needed a special endorsement
to fly higher than that.
TIA,
z
Old January 25th 05, 10:45 PM
jsmith
Domestic Reduced Vertical Separation M?? begins at FL280.
Prior to January 20, 2005, vertical separation between aircraft above
FL280 was 2000 feet. As of 20 January 2005, the vertical separation
between aircraft at FL280 and above is 1000 feet. Only aircraft properly
equipped for DRVSM are permitted to fly above FL280.
Old January 26th 05, 12:03 AM
Bob Noel
In article , jsmith
m = Minimums
non-RVSM aircraft can indeed fly above FL280, but will require special
handling (e.g., traffic permitting).
Bob Noel
looking for a sig the lawyers will like
Old January 26th 05, 05:36 AM
Scott Skylane
Bob Noel wrote:
/snip/
Bob,
That is what we thought, but there is more to it than that. This is from :
FAA Notice GEN04009 (Operational Policy/Procedures For RVSM In the
Domestic US, Alaska , Offshore Airspace and the San Juan FIR ( 24 Nov 04 )
http://www.faa.gov/ats/ato/150_docs/...N04009-120.doc
"2. Categories of Non-RVSM Aircraft That May Be Accommodated
* (a) Subject to FAA approval and clearance, the following categories
of Non-RVSM aircraft may operate in Domestic U.S. RVSM airspace provided
that they have an operational transponder:
• Department of Defense (DoD) aircraft
• Flights conducted for aircraft certification and development purposes
• Active Air Ambulance flights utilizing a “Lifeguard” call sign
• Aircraft climbing/descending through RVSM flight levels (without
intermediate level off) to/from FL’s above RVSM airspace (Policies for
these flights are detailed in paragraph k below)
• Foreign State (government) aircraft"
i.e. if you don't fit in the above categories, you *can not* operate
above FL280.
We've been slogging along at 280 all week...
Happy Flying!
Scott Skylane
Old January 26th 05, 09:34 PM
Dale
In a DC-6?!
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old January 27th 05, 12:57 AM
above FL280.
Not exactly true.
You can not operate in RVSM airspace if you don't fit in one of those
categories. You are allowed to transition it.
So if you can coax your plane up to FL430 you can operate above FL280
even without being RVSM equipped.
Old January 26th 05, 12:15 AM
Blueskies
"jsmith" wrote in message ...
Prior to January 20, 2005, vertical separation between aircraft above FL280 was 2000 feet. As of 20 January 2005, the
vertical separation between aircraft at FL280 and above is 1000 feet. Only aircraft properly equipped for DRVSM are
Altimeter accuracy ±65' for current birds and ±130' for older ones. Pretty amazing stuff actually, something like 1/4 of
1%...
Old January 26th 05, 02:14 AM
On Tue, 25 Jan 2005 23:15:41 GMT, "Blueskies"
1%...
Pretty sure that the ±65' and ±130' tolerance is for the "automatic
altitude control system" in regard to the "acquired altitude" in
"straight and level flight under nonturbulent, nongust conditions". If
there is an altitude select/acquire system, it's tolerance is ±25'
between the selected/displayed altitude and the corresponding signal
to the autopilot.
The tolerance for altimetry error is roughly between ±140' and ±200'.
There is also a requirement for an altitude alerter with a nominal
±200' ±50' (newer aircraft) and ±300' ±50' (older aircraft) alert
threshold.
If these numbers have changed recently, I apologize, am looking at
older reference/study material.
TC
Old January 27th 05, 02:00 AM
Blueskies
of
1%...
to the autopilot.
threshold.
TC
Yup, I looked at the docs again and it looks like you got it right, except the total altimetry system error may not
exceed 120 feet for pre-97 planes and 80 feet for recent birds....
Strange Class D boundary??? Roy Smith General Aviation 2 August 30th 04 02:56 PM
Strange engine event Paul Mennen Owning 33 July 9th 04 04:42 AM
Strange one about the 296 kage Piloting 0 June 13th 04 02:42 AM
Strange lost-comm situation Roy Smith Instrument Flight Rules 6 May 4th 04 04:11 AM
Really strange going-on with radios Roy Smith General Aviation 3 March 15th 04 01:52 PM
