Really strange going-on with radios
Old March 15th 04, 01:28 AM
Roy Smith
Default Really strange going-on with radios
I had a very strange experience on a flight from HPN (White Plains, NY)
to BID (Block Island, RI) this morning. We were in an Arrow equipped
with:
GPS: Apollo GX-50
Nav/Com 1: Apollo SL-30 Nav/Com (slaved to the GX-50)
Nav/Com 2: King KX-155 Nav/Com
plus some other stuff whose exact model numbers I can't remember (King
DME, Narco xponder, some random audio panel).
We were on V3 between Carmel and Hartford, level at 7000, navigating by
GPS. We tuned Madison VOR (110.4) on the SL-30 to confirm cross-radial
fixes. Instead of receiving MAD, we got HVN (a nearby VOR). The morse
ident was ..../...-/-., both by ear and by the auto-decode of HVN on the
SL-30. We had 110.4 in both the active and standby slots of the SL-30.
HVN is 109.8.
Then we tried putting 110.4 in the KX-155, and got the same thing! I'd
admit I didn't actually try to use the nav signal (i.e. figure out what
radial we were on), but the morse ident was unquestionably HVN.
We cross-checked the two en-route charts we had, and a sectional, so I'm
sure we had the frequency correct. I just looked them up on airnav when
I got home to confirm as well.
I can think of no possible hardware fault or mis-cabling that could
possibly cause those symptoms. Given that there were two of us, and we
cross-checked the freq on 3 different charts, operator error seems
unlikely (but never something to be ruled out). Can anybody think of a
rational explanation?
Old March 15th 04, 03:39 AM
Ron Rosenfeld
with:
Did you check with ATC? other a/c?
Old March 15th 04, 03:45 AM
Roy Smith
Unfortunately, "no" on both counts.
Old March 15th 04, 01:52 PM
Ron Rosenfeld
I, too, am at a loss.
Can you reproduce the problem at will? Or was it a one time thing?
If the latter, perhaps there was some source of interference in the cockpit
-- a cell phone or other electronic piece of equipment. Or maybe you were
just passing through the LI Sound Triangle :-).
Switching radios on 1 antenna Nicholas J. Hirsch Home Built 16 June 14th 04 02:49 PM
Air Force radios jam garage door openers THE ASSOCIATED PRESS Otis Willie Military Aviation 1 May 21st 04 02:13 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 07:22 AM
More GPS's HeadSets and Radios Forsale - MAKE OFFERS George Aviation Marketplace 1 January 13th 04 07:16 AM
Military helmet, civilian radios - my solution Dave Hyde Home Built 7 September 16th 03 02:20 AM
