8 Percent More Lift and 32 Percent Less Drag
Old August 19th 05, 06:50 PM
Larry Dighera
Default 8 Percent More Lift and 32 Percent Less Drag
Just when you thought aviation science had reached it limit:
http://www.aopa.org/members/files/pi.../news0508.html
Dept. of R&D
A whale of a tale
To improve aircraft wing design, scientists have turned to one of the
most unlikely sources in natu humpback whales.
Wind-tunnel tests using scale models of humpback pectoral flippers
have shown that the bumpy flipper is a more efficient design and has
better stall characteristics than anything currently in aviation. The
results were previously reported by researchers from West Chester
University, Duke University, and the U.S. Naval Academy in the journal
Physics of Fluids.
The researchers compared a smooth flipper, similar to a modern
airplane wing, with one that had bumps or what are called tubercles.
The bumpy flipper produced 8 percent more lift and 32 percent less
drag, and stalled at a 40 percent steeper angle. The researchers said
that as a whale moves through water, the tubercles cause swirling
vortices by disrupting the line of pressure against the leading edge
of the flippers. The water is redirected into the scalloped valleys
between the tubercles, keeping the flow attached to the upper surface
of the flipper.
The findings could be applied not only to airplane wings, but also to
the tips of helicopter rotors, airplane propellers, and ship rudders.
Old August 19th 05, 06:53 PM
Mike Rapoport
Just proves once more why you should leave the bugs on the leading edges.
Mike
MU-2
"Larry Dighera" wrote in message
Dept. of R&D
A whale of a tale
Physics of Fluids.
of the flipper.
Old August 19th 05, 06:58 PM
Seth Masia
See Scientific American, about a year ago:
http://www.sciamdigital.com/browse.c...4BC&sc=I100322
"Mike Rapoport" wrote in message
news
Mike
MU-2
Dept. of R&D
A whale of a tale
Physics of Fluids.
of the flipper.
Old September 6th 05, 09:33 AM
Hilton
The guy doing the research on a Whale is called Fish? I bet his startup
gets swallowed up by a larger company.
Hilton
"Seth Masia" wrote in message
news
edges.
Mike
MU-2
Dept. of R&D
A whale of a tale
Physics of Fluids.
of the flipper.
Old August 19th 05, 08:03 PM
Jose
vortices
Of course the physics is different, but it reminds me of an ad in
Scientific American some thirty years ago touting the benefits of the
new "rough" coating on electric cables, which allowed lower friction
when being pulled through a conduit.
Jose
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old August 19th 05, 08:21 PM
Larry Dighera
On Fri, 19 Aug 2005 18:03:36 GMT, Jose
wrote in ::
vortices
Yes. Completely.
As a union electrician for 40+ years, this is the first mention I have
heard of that. Interesting.
Old August 19th 05, 09:26 PM
Seth Masia
So the leading-edge bumps play the same role as vortex generators, but
because they work in a more viscous medium (about 100x more viscous than
air) they're a lot more effective. It will be interesting to see if anyone
has success with an RC airplane with lumpy wings; or if sailboats will
adopt lumpy rudders.
wrote in ::
vortices
Yes. Completely.
Old August 20th 05, 01:08 PM
Denny
Actually, we began to fly with bumpy wings, or tubercles, from the
Wright Brorthers onwards... Look at any ragwing and you will see the
tubercles at regular intervals......
And even the whale researchers are behn the power curve... Some guy has
a patent on tape you run along the wing at the approx. 20% of chord,
which has pits on it, like a golf ball... Makes great claims to
improved stalling speeds, etc... And of course, there are the vortex
generator folks...
What goes around comes around...
denny
Old September 7th 05, 01:02 AM
Brian
It's called Turbulator Tape or another style is called zig zag tape. It
has been used on glider wings for many years.
Brian
CFIIG/ASEL
Lift Query Avril Poisson General Aviation 8 April 21st 05 08:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 05:08 PM
New theory of flight released Sept 2004 Mark Oliver Piloting 70 October 10th 04 11:50 PM
ASW 20 SPIN CHARACTERISTICS Ventus B Soaring 79 July 21st 04 08:46 AM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 11:55 PM
