Lift Query
Old March 31st 05, 11:44 PM
Avril Poisson
Default Lift Query
The Role of Lift Demons and Thrust Pixies in Heavier Than Air Flight
Publication Date: April 2005
Abstract: The role of Lift Demons in aeronautics was first explained in 1994
by Mary Shafer (NASA). Since then, Shafer's work has been explored and
revised. This paper summarises advances in Lift Demon technology over the
last decade.
Keywords: Lift Demons, Thrust Pixies, lemon fondant
Question: How did the secret information on Lift Demons make it into the
public domain? I've been a practising Aircraft Performance Engineer for the
past 26 years and have always tried to explain how aeroplanes fly by using
the official public explanations regarding Bernoulli, airfoils and other
such rot. Civilians just weren't ready for the truth. In fact, we generally
don't speak about the magic directly. Most of our plans and estimates
usually end with the phrase "and then a miracle happens".
Answer: The science of Lift Demons was declassified in 1994, throwing this
topic wide open for discussion and research.
According to Shafer "Lift is caused by Lift Demons. These little, invisible
demons hold on to the leading and trailing edges of the aircraft and lift it
into the air by flapping their wings (so, in a reductionist sense, lift is
actually caused by feathers). Some of the demons are a little confused and
they hold on backwards, causing drag. The reason that planes stall at high
alpha is that the leading edge demons get scared and let go when they can't
see the ground anymore. Lift demons have good taste and don't like to look
at ugly aircraft, so they hold on backwards on ugly planes. That's why
gliders have so much lift and so little drag and why F-4s have lots of
drag." This, however, did not address what gives lift to the Lift Demons'
wings. Again, according to Shafer "Feathers. The multiple filaments on
feathers trap the air molecules and they struggle to escape, which causes
the action-reaction that we call lift. Bat wings don't have feathers but
they're hairy and that works just about as well (air molecules are a little
claustrophobic)."
It was originally believed that Lift Demons got their lift from smaller Lift
Demons whose lift was, in turn, produced by even smaller Lift Demons leading
to the "Infinite Demons Theory" as proposed by the great Greek
philosopher-scientist Miasma. However, with the revival of scientific
knowledge that eventually ended the Dark Ages, it was realised that this
situation unresolvable according to Zeno's paradox. The "Infinite Demons
Theory" works in many problems of engineering significance, however, real
understanding requires that the ether be introduced into the analysis at
some point. The "Ether Concept" explains why planes fly more efficiently at
higher altitudes. This is an absolute necessity when studying orbital and
interplanetary travel where, it is believed, many of the Lift Demons are
unable to breathe.
As always the Chinese seem to have been there first. "The Genius of China",
tells of one Ko Hung. "Someone asked the Master (Ko Hung) about the
principles of mounting to dangerous heights and travelling into the vast
inane. The Master said "[...] some have made flying cars with wood from the
inner part of the jujube tree, using ox leather straps fastened to returning
blades so as to set the machine in motion. Others have the idea of making
five snakes, six dragons and three oxen to meet the 'hard wind' and ride on
it, not stopping until they have risen to a height of 40 li (about 65,000
feet). The the ch'i [emanation of the sky or perhaps wind] is extremely
hard, so much so that it can overcome the strength of human beings. [...]
Take dragons, for example; when they first rise they go up using the clouds
as steps, and after they attained a height of forty li then they rush
forward effortlessly gliding." The jujube tree device sounds like the
Osprey. Scholars believe that the term "dragon" referred to the Lift Demon
and that the Chinese had harnessed their power before the Western world had
even discovered the Lift Demons' existence.
Lift Demons operate differently on different aircraft types. They get dizzy
holding onto a spinning prop and become disorientated, thus more of them
face the wrong direction which increases the drag. Lift Demons have to be
magically bound to jet engines and an Airbus propulsion engineer explained
"It takes an average of three day's solid chanting and ritual to get one of
those 'engine' things to work. If us witches stopped our hard work, there'd
be planes dropping out of the sky all over the place. We should never have
let you lot find out about being able to fly, it's been nothing but trouble
ever since."
Recognition of Lift Demons has also solved one of aviation's oldest puzzles:
Gremlins. There appears to be a connection between Gremlins and Lift Demons.
Gremlins may be Lift Demons that have, in some way, turned against the
pilot. Instead of assisting him in his task of keeping the machine in the
air, they do the opposite. The reason may be that, after reading about the
Bernoulli/Newton dichotomy, they have become confused. Much has been written
about Gremlins, dating back to WWII. Gremlins have been known to run towards
the nose of an aircraft, causing it to dive into the sea, showing that they
have at least some knowledge of the principles of flight. These days, most
planes carry a full complement of In-Flight Gremlins; although they must be
carefully managed, their presence generally inhibits the transformation of
rogue Lift Demons into Gremlins.
Further study of Lift Demons was carried out by an aero-industry weights
engineer who submitted the following scientific paper in 2004 to celebrate
the anniversary of Shafer's ground-breaking article:
"There are still people in this company who think we weigh aircraft to find
out how much they weigh, not to calculate stresses. Of course we need to
know how much the thing weighs. How are we ever going to know how many
Thrust Pixies we need to get the thing off the ground if we don't know the
weight? Or should that be "Lift Demons"? Pixies have largely fallen into
disrepute - something about Bernoulli not being representative in unbounded
conditions and cause and effect being transposed in the Newtonian model.
In fact the use of Lift Demons on civil aircraft programmes is generally not
that good an idea. The Demon binding contract tends to specify payment in
blood or souls. This is readily achievable with aircraft of military
function, but frowned upon in civilian circles as they may attempt to
acquire payment outside of the terms of their binding contract. Lift Demons
are not used on Elf bombers. We don't talk about Lift [Thrust] Pixies too
often as it seems to upset the self-loading cargo [passengers]. Pixies
require payment in cakes, flowers or nice thoughts. These are readily
sourced either from the in-flight catering, or provided cost-free by the
passengers. Clearly this would not work well within an operational military
environment. Air force cooking is not renowned for the "light and fluffy
texture" that Thrust Pixies demand, the availability of flowers might be
problematic in desert operations, and nice thoughts may also be hard to find
during times of active operations.
There is also a scalability issue. While one rampant Lift Demon would have
few problems supporting a fighter aircraft (particularly if there is an
immediate prospect of blood), it'll struggle to achieve level controlled
flight of a 560 tonne Airbus A380. Use of more than one Lift Demon on the
same flight vehicle is contra-indicated (they squabble and eat each other).
Communities of Thrust Pixies can be encouraged to work together on the same
aircraft by the provision of advanced technologies such as Lemon fondant
icing, variegated tulips or in-flight romantic comedies. Ryanair once
requested Leprachauns be installed in place of Lift [Thrust] Pixies, but
Leprechauns have a mission statement which indicates their desire for
monetary gain, and their willingness to search all over the world for it.
This makes Lift Leprechauns expensive to keep (gold vs. lemon fondant
icing), and makes it difficult to establish a regular route network as the
Lift Leprechauns don't like to continuously visit the same locations. By
law, aircraft also have to have a full complement of In-Flight Gremlins, but
these are generally not a problem unless you feed the Wingtip Vortex Faeries
after midnight."
His article shows that we've moved on a great deal since 1994. It has been
known for some time that Lift Demons are best suited to military uses. In
spite of suggestions that Pixies have fallen into disrepute, outside of
military aviation it is Lift Demons that are considered passé - they have
notoriously short attention spans and the ones used on Harriers have
problems discriminating between air and water. Inbreeding in pursuit of the
ultimate high performance Lift Demon may have been the cause. In civil
aviation, the way ahead still lies with Thrust Pixies, large amounts of
lemon fondant icing and in-flight Hugh Grant movies. Many instances of civil
planes mysteriously falling out of the sky can be traced to (a) cessation of
happy thoughts/lack of lemon fondant for the pixies (resulting in "Pixie
Fatigue" or even "catastrophic pixie failure") or to (b) a large amount of
happy thoughts/gateau mountain at ground level distracting the pixies from
their task. Thrust Pixies dislike Marmite/Vegemite (yeast extract) and
since such spreads can cause unhappy thoughts in some passengers, airline
caterers are careful to avoid these.
A note on Catastrophic Pixie Failu Temporary pixie problems resulting in
turbulence or sudden loss of altitude causes unhappy thoughts in the
passengers (which is why cabin staff and pilots always play down such
occurrences). The resulting loss of happy thoughts causes further Pixie
failure, worsening the situation. This makes passengers have even more
unhappy thoughts and the Pixies become more fatigued; some may even leave
the aircraft. Unless counter-acted by large lemon fondant reserves, Pixie
Failure reaches catastrophic proportions and the aircraft is doomed.
Modern aircraft designers use Lift Fairies and avoid the whole controversy
regarding the used of Lift Demons on civil aircraft programmes. Coming from
a less benevolent cast, Lift Fairies are less dependent on nice thoughts or
cakes. Fairies tend to less concerned with good and evil and hence make
better dual use aircraft. Another major headache today is how to get 707
Lift Fairies at a reasonable price. Many of the older aircraft-specific
fairies have become rare, if not unavailable. Aircraft numbering relates to
the type and quantity of Lift Demons or Lift Fairies needed. For example a
C-130 requires 130 "C class" Lift Demons while an Airbus A380 uses 380 "A"
class Thrust Pixies. Aero engineers have a scale of values (proprietary
information, not available in the public domain) allowing them to substitute
different numbers of Pixies and Demons with different lifting abilities,
thus making best use of the available surfaces.
There was short-lived interest in breeding a generic, or at least dual-use,
"Thrust Demon" but the blood-loving Lift Demons ate the gateau-loving Thrust
Pixies. In vitro techniques failed because their genietic [sic] material is
incompatible so there are no hybrid Thrust Demons. DNA sequencing has
allowed us to distinguish between many castes of Lift Demon, Thrust Fairy
etc. For example due credit should be given to the inelegantly named Fart
Fairies without whose bean eating and gas production, no machine could power
itself from the earth's surface. The shy Turbine Winder-Rounder Gnomes hide
inside those so-called engine nacelles from the public and indulge their
serious kerosene drinking problems. Why else would the engines be called
Gnome engines? Leading-Edge Leeries give the extra little push that keeps
the nose up. The unfortunate tendency for RAF Harriers to crash into the sea
has led to speculation that Harriers are equipped with Sirens or that the
crashes resulted from an ill-advised experiment in using Water Nymphs (these
are better suited to submarine propulsion). In any case, only export
versions of the Harrier are likely to use Sirens, while those for the
British domestic market use Banshees leased from the Irish.
Thrust Pixies are adequate for civil aircraft, while Lift Demons were good
in military applications in years past, but modern Naval Aviation is
currently all Angel-powered. The very best ones are, of course, Blue Angels.
This is why they report their altitude as "angels twenty" or such. In
addition, many Navy pilots claim that black air has no lift, which means
they can get all night in to supplement their daytime naps between meals.
This shows that Angels and Naval Lift Demons are strictly diurnal.
Genetically engineered, military-tolerant Thrust Pixies may be what is
needed. Thrust Demons might also have applications in getting Air Force
maritime patrol aircraft to stop reaching "prudent limit of endurance" by 2
p.m. (local time) every Friday just after reporting a "possible intruder"
submarine in the exercise area, and not be restored to flying status until 9
a.m. Monday, thus leaving the ships to stay out over the weekend looking for
the "intruder".
There are no Anti-Gravity Demons so a different approach has to be taken in
this field of research. Current research into inertia-free propulsion has
shown great promise through the use of properly modified felines. Butter is
spread evenly over the felines back. When the creature is tossed lightly
into the air, the third law of universal fate dictates that it must land
butter side down. However this does not occur due to the intervention of the
feline landing axiom (feet first). The above conflicting forces result in a
stable hover. The subject felines have demonstrated the ability to control
their own velocity at will. The only loose ends delaying the full
commercialisation of this process is the matter of persuading the felines to
(a) work in teams; (b) not lick off the butter and (c) follow a flight plan.
As there seems to be a deficiency in feline herding instincts, any
suggestions would be appreciated by the researchers involved.
Old April 1st 05, 06:23 AM
Brian Whatcott
Ah, it has been years - about 14 - since I first saw Mary ..er..
Avril posting on an aviation group.
Just can't get enough of the lady.
Brian Whatcott Altus OK
On Thu, 31 Mar 2005 22:44:24 +0100, "Avril Poisson"
last decade.
claustrophobic)."
unable to breathe.
ever since."
after midnight."
the "intruder".
Old April 1st 05, 01:38 PM
Jack Linthicum
in 1994
and
last decade.
for the
using
other
generally
this
invisible
lift it
lift is
confused and
high
can't
look
why
of
Demons'
on
causes
but
little
claustrophobic)."
smaller Lift
leading
this
Demons
real
at
efficiently at
and
are
unable to breathe.
China",
vast
from the
returning
making
ride on
65,000
extremely
[=2E..]
clouds
Demon
world had
dizzy
them
to be
explained
one of
there'd
have
trouble
ever since."
puzzles:
Demons.
about the
written
towards
that they
most
must be
transformation of
weights
celebrate
to find
to
many
know the
into
unbounded
model.
generally not
payment in
Demons
too
Pixies
military
fluffy
be
to find
have
an
controlled
other).
the same
fondant
but
it.
as the
By
Gremlins, but
Faeries
after midnight."
been
uses. In
of
military aviation it is Lift Demons that are considered pass=E9 - they
have
of the
civil
of
of civil
cessation of
"Pixie
amount of
from
and
airline
resulting in
Pixie
more
leave
Pixie
controversy
Coming from
thoughts or
make
707
aircraft-specific
relates to
example a
380 "A"
(proprietary
substitute
abilities,
dual-use,
Thrust
material is
Fairy
Fart
could power
Gnomes hide
their
called
keeps
the sea
(these
good
Angels.
means
meals.
is
Force
endurance" by 2
intruder"
until 9
looking for
the "intruder".
taken in
has
Butter is
lightly
land
of the
result in a
control
felines to
flight plan.
Then the explanation I got in 1959 that it involves mass hypnotism
isn't true?
Old April 1st 05, 06:46 PM
Gord Beaman
Ahah!...the lady who adamantly denies the existence
of 'Pilot Error'...she's still around is she?...
-Gord.
(use gordon in email)
Old April 1st 05, 07:41 PM
Peter Stickney
In article .com,
"Jack Linthicum" writes:
in 1994
and
last decade.
isn't true?
That's part of the Special Rotorcraft supplement:
"Optical Illusions with Sound Effects", Sikorsky, Piasecki, Kamen,
Hiller, Bell, Ceirva, Focke and Breguet, 1940, the FM Press.
Pete Stickney
Without data, all you have are opinions
Old April 1st 05, 10:24 PM
John Szalay
"Avril Poisson" wrote in
in 1994 by Mary Shafer (NASA). Since then, Shafer's work has been
explored and revised. This paper summarises advances in Lift Demon
technology over the last decade.
I love this day, each year, it just gets better...
Old April 1st 05, 10:32 PM
Jack Linthicum
Peter Stickney wrote:
In article .com,
Flight
explained
in 1994
and
over
last decade.
isn't true?
Pete Stickney
We had been in Tokyo and seemed to be in another place called Hong
Kong. It was a very expensive hypnotic trance.
Without opinions, all you have is data
Old April 3rd 05, 08:11 AM
Skip Schipper
For John Szalay
Do you know a Frank Szalay that was a Naval Aviator during WW11. If you
do please contact me as I flew with him.
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 05:08 PM
Four States and the Grand Canyon Mary Daniel or David Grah Soaring 6 December 6th 04 11:36 AM
New theory of flight released Sept 2004 Mark Oliver Piloting 70 October 10th 04 11:50 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 11:55 PM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 09:52 PM
