Cold Starts
Old February 19th 04, 01:12 AM
Tom Sixkiller
"Dave Stadt" wrote in message
m...
Percentage wise the difference is minimal.
Granted it's engine preheater propaganda,
I believe there's some truth to the research in
http://www.tanair.com/article6.html.
or
http://www.reiffpreheat.com/index.html
I'm leaning towards a Reiff System, probably the Turbo XP system. It just
seems a better design especially with a
JPI EDM-700 installation.
  #42
Old February 19th 04, 01:48 AM
Viperdoc
It's not the oil that freezes, but condensed water vapor can freeze in an
oil breather
tube, resulting in blown seals.
"John Galban" wrote in message
om...
Newps wrote in message
news:9KKYb.351852$na.520642@attbi_s04...
Doug wrote:
Then there is the Alaska way. Drain the oil and take it inside. Then
during breakfast, heat oil to 200 degrees. Pour hot oil back into
engine. Engine nice and warm. Chase off Grizzlies. Start airplane.
Your engine isn't warm, the oil is. You are much better off heating the
oil while it is still in the plane.
The reason for the Alaskan habit is that when temps go low enough, a
chunk of frozen oil can develop in the crankcase. Even after
preheating the engine to what seems to be a suitable temp, you can
have a frozen chunk of oil surrounded by slightly warmer liquid oil.
I recall reading at least 1 accident report that was blamed on frozen
oil blocking the pickup. The engine had been preheated (but obviously
not enough).
  #44
Old February 19th 04, 05:33 AM
Dave Stadt
"G.R. Patterson III" wrote in message
Dave Stadt wrote:
I do preheat but to be honest I don't know why.
Continental will tell you that failure to preheat one of their engines
when the
temperature is below 20 degrees F may result in a snapped valve stem. Good
enough?
I have never sen that written about the O-200.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way
that
you look forward to the trip.
  #45
Old February 19th 04, 05:39 AM
Mike Rapoport
The oil will gell at some point and apparantly that point can be found in
AK.
Mike
MU-2
"Viperdoc" wrote in message
oil breather
om...
not enough).
  #46
Old February 19th 04, 01:23 PM
Ron Rosenfeld
On Wed, 18 Feb 2004 17:12:13 -0700, "Tom Sixkiller"
om...
or
I've had a TANIS system for about fifteen years, along with an Insight GEM.
The "cylinder" heating is taken care of by heated intake bolts, so no
interference with anything else. The oil heating is via a heated oil
screen (the upper one).
I have no experience with the Reiff system.
With a cover, my cylinders are usually around 100°F and the oil around 80°F
with OAT's down to -5°F or so.
  #47
Old February 19th 04, 03:08 PM
Tom Sixkiller
"Ron Rosenfeld" wrote in message
om...
or
GEM.
Isn't the GEM a single cylinder monitor? The EDM-700 has six and I think
that precludes using the Tanis.
80°F
Gets the cabin heater going more quickly, too, I surmise.
  #48
Old February 19th 04, 03:27 PM
Rich
"Heated intake bolts"???
Please tell me more about that!
The Tanis heaters that I've seen use the CHT probe hole, thus precluding
the use of these holes for CHT guages (or dual adapters).
Rich
  #49
Old February 19th 04, 05:11 PM
Rosspilot
I still use the Red Dragon I bought from you, Mike, about 4 years ago (I
think). It works well and I am careful about moving the duct outlet around . .
.. mostly I keep the warm air coming from under the cowling at the nosegear
(warms the oil filter, sump and battery) and then move it to the air intakes
next to the prop to warm the cylinders. It seems to do a great job.
www.Rosspilot.com
  #50
Old February 20th 04, 03:31 AM
Ron Rosenfeld
Rich
Just another one of the available options for heat. The heated bolt
replaces an existing one on the intake manifold -- one for each cylinder.
I didn't want to use dual probes in the CHT wells, having them all plugged
with GEM CHT probes.
Turbine air start -- too cold? Juan Jimenez Home Built 97 March 14th 05 07:51 PM
Turbine air start -- too cold? Juan Jimenez General Aviation 54 February 2nd 05 05:14 AM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 08:05 PM
Soviet Spy Planes over the West during the Cold War Rusty B Military Aviation 6 February 19th 04 05:53 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 03:38 PM
