Turbine air start -- too cold?
Old January 14th 05, 01:40 AM
Juan Jimenez
Default Turbine air start -- too cold?
The engine on my homebuilt aircraft is a small French turbine, a Microturbo
022 Couguar (one version behind the TRS-18-046). It starts using good ol'
air impingement, which the manual specs out to 145 psi, 1.21 lbs volume.
Now, I always had problems motoring the engine to a high enough RPM where I
thought it would be safe to open the fuel and spark if I pressurized my tank
to 155, so I bought myself a pressure multiplier (I was worried about hot
starts). It's a simple SMC unit that mechanically multiplies air pressure by
4x, up to 280-300 psi or so. I have a converted 100# propane tank to hold
the air, which I pressurize to 280 and regulate to 145 psi. It works GREAT
though it takes a while to do its job.
However, the engine now refuses to start, even though the spark is great and
fuel atomization is also good. I'm concerned that when I dump the air into
the engine, the drop in pressure is cooling the air so much that it
interferes with the start process and the fuel mist doesn't light up like it
did in the past. The temperature drop is significant -- if I remove the air
start hose and open the valve wide open, ice will form on the outlet. Where
I live, the Caribbean, the air is also quite humid, and I'm sure that is
contributing to this even though I have a water trap in the air line.
The original docs on the engine say that the ground servicing rig had air
tanks, two pressure regulators and associated valves. How would one avoid
this problem, and is it in fact something that could interfere with the
start, or should I be looking elsewhere? Fuel pressure is fine, spark is a
whopping blue honker that looks every bit as deadly as I'm sure it is,
atomization is fine, etc.
Thoughts?
Old January 14th 05, 01:57 AM
Sean Trost
Juan,
Cooling would take one leg of the combustion triangle out of the
picture. I dare say it would take a large amount of cooling to do so.
I suspect that a more plausable reason would be the fuel air ratio being
outside the LEL.
The manual calles for 145 psi and 1.21 lbs volumn. are you getting the
volumn with the setup you are using ?
all the best.
Sean
Thoughts?
Old January 14th 05, 04:13 AM
Capt.Doug
"Juan Jimenez" wrote in message
by
With the air multiplier, you have the pressure, but do you still have the
volume (cubic feet per minute)?
it
did in the past.
APUs are designed to start at altitude where the temperature may be minus
40C.
D.
Old January 14th 05, 06:47 AM
Colibri
Thoughts?
My thought is that the air impinges on the turbine wheel, not the
compressor. So that cold air has nothing to do with lighting the mixture.
Old January 14th 05, 03:28 PM
Juan Jimenez
Yes, the volume is more than enough, as evidenced by N1 reaching close to
15%.
Juan
"Sean Trost" wrote in message
Juan,
Cooling would take one leg of the combustion triangle out of the picture.
outside the LEL.
all the best.
Sean
Old January 14th 05, 03:29 PM
Juan Jimenez
"Capt.Doug" wrote in message
news
by
GREAT
it
did in the past.
40C.
The Microturbo Couguar is not an APU. It's a turbojet engine designed to
power small aircraft or drones.
Juan
Old January 14th 05, 03:30 PM
Juan Jimenez
"Colibri" wrote in message
But the cold air goes through the engine after it hits the turbine wheel...
Old January 14th 05, 05:58 PM
Sean Trost
Juan
I believe that N1 is related to the velocity of the airstream
introduced. Which is good. But not related to the ignition problem
Now You have said that you have an excellent spark and good fuel. the
only other thing you need for start is the right airflow. or volumn.
Dont know about your engine specifically but most everything else runs
right around 14 to 1 on the ratio wise.
I can get a HIGH volume low pressure spray gun to flow 10 psi but it
still wont spray anything unless i get the volmume behind it to work
properly. Not that this has anything to do with jet engines or
cumbustion but to illustrate that velocity and volumn are not
interchangable.
Sean
15%.
Juan
Juan,
outside the LEL.
all the best.
Sean
Old January 14th 05, 10:29 PM
Vaughn
"Richard Riley" wrote in message
news
Propane tanks are normally rated for 250 LBS.
That rating is normally at 120 degrees. 280 PSI air is probably a lot
hotter than that. It's been too long since I've done ideal gas law
equations, but I seem to remember 250 psi air getting to 300 or 350 F.
At a temperature higher than it's rating, a tank is weaker than it's
rating.
You lost me here. In my experience, 250# air can be any temperature you
want it to be.
Vaughn
Old January 14th 05, 10:51 PM
Gord Beaman
news
rating.
want it to be.
Vaughn
Sure...heat is merely a byproduct of compressing it and varies
with the rate of compression.
-Gord.
(use gordon in email)
Turbine air start -- too cold? Juan Jimenez Home Built 97 March 14th 05 07:51 PM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 08:05 PM
Start receiving MONEY with this simple system. Guaranteed. Mr Anderson Aviation Marketplace 0 February 3rd 04 12:55 AM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 10:41 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
