"G.R. Patterson III" wrote in message ...
"Robert M. Gary" wrote: I've checked the filter beofre and not found anything. However, I've never checked the screen. I'm not sure if my IA is doing that during annual or not. The screen should be checked every 50 tach hours. If the shop is changing the oil as part of the annual, they almost certainly are checking the screen. If they aren't I would wonder what else they're skipping. I'm sure the shop is doing it but I do most of the oil changes myself (except the one at annual). I'm not checking the screen. I'll have to schedule some time with the A&P to have him show me how to do it. The Lycoming guy said they've seen cases where a filter has come out clean because there were so many chunks of big metal plugging up the screen. -Robert |
"Robert M. Gary" wrote: I'm sure the shop is doing it but I do most of the oil changes myself (except the one at annual). I'm not checking the screen. I check mine every other oil change, whether I've run up 50 hours or not. My engine is an O-320. On that, the screen looks like a horizontal drain plug on the sump. Safety-wired, of course. George Patterson None of us is as dumb as all of us. |
"G.R. Patterson III" wrote: "Robert M. Gary" wrote: I'm sure the shop is doing it but I do most of the oil changes myself (except the one at annual). I'm not checking the screen. I check mine every other oil change, whether I've run up 50 hours or not. My engine is an O-320. On that, the screen looks like a horizontal drain plug on the sump. Safety-wired, of course. George Patterson None of us is as dumb as all of us. I check mine every oil change (25 hr) AND, I have a niobium magnet in each drain plug, to collect all ferrous metals. IMHO, the magnet asved my plane (possibly my life) a couple of years ago, when I found some flattened pieces of steel, anout .05" across. They were coming from the big roller bearing that serves as a thrust bearing -- its cage had broken and it was making some noises which I could hear at idle. The steel drain plugs are the perfect place to put one or two of these magnets, as they are self-attaching. |
Orval Fairbairn wrote: The steel drain plugs are the perfect place to put one or two of these magnets, as they are self-attaching. I replaced my drain plug with a quick-drain. That would certainly complicate using the magnets on my aircraft. George Patterson None of us is as dumb as all of us. |
| Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 08:28 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 03:46 PM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 06:23 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 04:52 AM |
| Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 07:24 AM |
