slightly high aluminum in an IO-360
Old May 25th 04, 01:54 AM
Robert M. Gary
Default slightly high aluminum in an IO-360
I've had slightly high aluminum for the last year. I'm not happy about
it but everyone says its not high enough to spend real money pulling
cylinders or boroscoping. I'm curious what the group thinks...
IO-360-A3B6
SFNEW 682
At each 50 hours change I've had...
7, 10, 25, 13 (short sample), 24, 23 ppm
I don't think I have an alumimum dip stick (at least my A&P says I
don't). I'm not finding anything in the filter.
I'm in California so everything is pretty pricey. Should I spend a
grand or so having the cylinders boroscoped?
-Robert
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 08:28 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 06:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
