#81
Dale Larsen wrote:
As I see it, accelerometers and GPS together are all that's needed. If the vectors from all 3 accelerometers are in the right direction, and the average GPS heading is not moving much- you're straight and level. Ron-Using accelerometers in 3d space will soon become inaccurate due to small errors in the accelerometers, math rounding errors and drift. How do you propose to 'erect' such a device to keep the shiny side up? Add a VG.... let's see the second integral.... OK, too complicated...keep a cat in the cockpit, periodically drop it on the floor, since cats always land feet first..... No, cats tend to get cranky when you do that..... Dan, U.S. Air Force, retired |
#82
Ron-Using accelerometers in 3d space will soon become inaccurate due to small errors in the accelerometers, math rounding errors and drift. How do you propose to 'erect' such a device to keep the shiny side up? The only constant acceleration is the acceleration of gravity. A "leaky integrator" with a 2 or 3 second Tau should work fine. If it can be done mechanically, it can be done electronically. |
#83
On Mon, 14 Mar 2005 16:50:34 -0900, "Ron Webb"
wrote: Ron-Using accelerometers in 3d space will soon become inaccurate due to small errors in the accelerometers, math rounding errors and drift. How do you propose to 'erect' such a device to keep the shiny side up? The only constant acceleration is the acceleration of gravity. A "leaky How so? the plane doesn't know if it's right side up or not. You can do a barrel roll, or loop and always keep "down" through the bottom of the seat. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com integrator" with a 2 or 3 second Tau should work fine. If it can be done mechanically, it can be done electronically. |
#84
The only constant acceleration is the acceleration of gravity. A "leaky integrator" with a 2 or 3 second Tau should work fine. How so? the plane doesn't know if it's right side up or not. You can do a barrel roll, or loop and always keep "down" through the bottom of the seat. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger That's a good question. I have run every other scenario over in my mind, and it looks to me that the proposed system should deal with them under any normal circumstances. However, I had not considered a constant acceleration "barrel roll" while maintaining the same heading. How to sense that??? My original idea had included an electronic "Gyroscpe" I had eliminated it when I discovered how hard the iMEMS ADXRS300 http://www.analog.com/en/prod/0,,764...S300%2C00.html are to get, but I may have to put it back. A homemade version is available. http://home.comcast.net/~scottxs/pie.../piezindex.htm |
| Thread Tools | |
| Display Modes | |
| ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 09:40 PM |
| Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 06:07 PM |
| Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 04:40 PM |
| Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 03:33 AM |
| An Affordable Homebrue 60 in DS machine | Grant | Soaring | 0 | August 8th 03 04:52 AM |
