wing levelers
Old February 25th 05, 01:12 AM
Dick
Default wing levelers
Sitting around the hanger and discussing the possibility of somehow using
off-the-shelf electronic/computer components or gadgits for semi-automatic
wing leveling on lightly loaded, short wingspans.
Not being computer guys, the current thought is that something should be out
there that is available cheaply and modifiable to use a simple wing
leveler.
Having heard someplace that automotive computers, as an example, sense data
millions of times leads us to believe that sensing the wing tip initial
movement and counteracting very very quickly would be a good thing.
As an example: One fellow pictured a rolling ball bearing inside a tube
somehow activating a magnetic switch which in turn pulses a dc linear motor
to operate the aileron minutely.
We are not sure how to detect the very earliest initial wing tip movement or
drive the small trim type motor and would appreciate some thoughts or site
recommendations to investigate.
Thanks, Dick
Old February 25th 05, 02:10 AM
Morgans
motor
or
site
Hmmmm. No free (or even cheap) lunch, here.
The idea of a ball bearing in a tube is not even close. Ever hear of the
graveyard spiral? It is what killed Kennedy. (not the president) In such
a spiral, you experience several 360 degree turns, diving steeply enough
that vertical descent rates of 10,000 feet per minute (if the plane holds
together) are possible. Still, the ball in the tube would stay right in the
middle. One G all the way.
You need a gyroscope, or an electronic equivalent. Some have played using
very sensitive GPS antennae in the wingtips.
Best advice? Trim the plane, stay awake and fly it, or BUY an autopilot, or
wing leveler. Or google wing leveler.
Old February 25th 05, 05:51 AM
Montblack
("Morgans" wrote)
snips
or drive the small trim type motor and would appreciate some thoughts or
site recommendations to investigate.
such
or
Automotive world is using electronic stability-control (ESC) systems with
documented success. The article says the system used a decade ago wasn't
very good, but they've come a long way since then.
http://www.detnews.com/2005/autoscon.../F01-91164.htm
http://www.caranddriver.com/idealbb/...?topicID=60884
I'm guessing some variant of this is what you'll eventually cobble together
in your garage.
Montblack
Old February 25th 05, 07:16 AM
Morgans
documented success.
together
in your garage.
More than likely, they are using piezzo electric rate sensors for the
direction information. They are relatively cheap, and do well at sensing
rapid changes. They have been used for a while in the RC airplane world, as
a stability aid, with good success, also. Any really stable electronic gyro
system in the commercial auto-pilots world, are much more expensive, and as
far as I know, not available to the public.
Problem is, piezzo sensors have a fairly fast "drift." which makes the
leveling ability good only for a few seconds. If you handed over control to
one of these units, within 30 seconds, you would be upside down, and the
unit would think everything is still OK.
In the RC world, if the plane makes a sudden move to go upside down, it
senses the sudden move and if the sticks have not commanded the sudden move,
it will move the control surfaces to stay right side up. It counts on you
keeping it somewhat upright, and recalibrates itself often - based on your
MarkII eyeballs telling the plane to fly level.
Same thing with the car unit in the links. It knows that you are going
straight, or following curves. (still reasonably slow changes compared to
sudden loss of control) It continually reminds itself that it is going
straight, and re-sets itself. Only when a real sudden move is made, does it
correctly sense that it is not going straight and the steering wheel wants
the car to go straight. The computer then makes corrections to keep the car
straight.
If a plane wing leveler were based only on these units, and the plane
started banking very slowly, the sensor would not realize it. That is the
drift. It would re-set as level, then the plane banks another slow degree,
and the unit re-sets, and the plane banks...you get the picture.
I believe the concoction that had some success, was a GPS wingtip
differential altitude sensor. It used these rate sensors in unison to help
backup the control movements and make the controls smooth. The units
re-set using the GPS info as the reality of what was level. You have to use
something (MarkII eyeballs or GPS) doing this.
Good luck to the OP, figuring out a homemade wing leveler. It is a tough
problem.
Old February 25th 05, 02:27 PM
Dick
Thanks for everyones input.
Our group was discussing flying in VFR only (no IMC or IFR) and wing leveler
only with respect to roll sensitivity of lightly wing loaded, short wing
spanned experimentals.
Trying to make summer flying in chop somewhat easier. We didn't plan on
turning over controls to the device and would still keep a light grip on the
stick; just wouldn't have to constantly play the stick.
Although we had the impression that a heavier plane would be more stable in
chop and require less than continual input by stick, that wasn't much of an
option G.
Although not discussed among us, I wonder if
an increased dihedral result is possible without actually increasing it
physically..
Still would appreciate a little discussion that I can pass on for the next
non-flying day.
Thanks, Dick
"Morgans" wrote in message
documented success.
together
in your garage.
as
gyro
as
to
move,
it
car
straight.
degree,
help
use
problem.
Old February 25th 05, 02:35 PM
Jan Carlsson
Dick,
I think that winglets would improve roll stability, and L/D, climb
performance and high alt. performance.
Jan Carlsson
www.jcpropellerdesign.com
"Dick" skrev i meddelandet
m...
leveler
in
an
option G.
physically..
non-flying day.
Thanks, Dick
with
documented success.
together
in your garage.
sensing
world,
as
gyro
as
control
to
move,
you
your
to
does
it
wants
car
straight.
degree,
help
use
tough
problem.
Old February 25th 05, 03:03 PM
COLIN LAMB
Very difficult to thermal with wing levelers.
Wing leveler suggestion:
Take neighbor kid along. Show him how to move stick to keep wings level.
Give him stick and tell him you will give him a quarter (whoops, $5 in
today's market) to keep wings level. Show him how to keed airspeed with
fore and aft movement of stick and tell him to wake you when ground is near.
Then take a nap.
Take Walkman along so you will not be bothered with the rushing of the wind
noise.
Good god, why would you want to put a wing leveler in the last bastion of
flight where the pilot is still a requirement?
Colin
Old February 25th 05, 06:10 PM
Peter Dohm
In an effort not to go too far beyond my own knowledge, I'll avoid detail.
My best recollection, being about twenty years from being current as either
a pilot or a technician, is that "wing leveler" is a very missleading term
applied
to a single axis auto-pilot. Typically, the single axis would be yaw
(heading)
and would have been accomplished be slaving to either a rate gyro (such as
a turn coordinator or turn and slip) and a potentiometer, or a system of an
air jet and heated resistors, to provide a correction signal with
considerable
integration (a/k/a damping or low pass filtering). Although it would seem
intuitive to have the wing leveler steer the plane with the rudder and have
the dihedral roll the wings, the only systems that I have seen used the
ailerons and depended on the vertical stabilizer to keep the resulting yaw
within reason.
If you are still interested in learning more about how autopilots work, I
would
suggest trying to obtain some of the factory trianing manuals for the
technicians who will work on them. Try Bendix/King, S-Tech, and others.
Some books may also be available at college bookstores on booksellers
like Borders or Barnes & Noble.
"Dick" wrote in message
om...
out
leveler.
data
motor
or
site
Thanks, Dick
Old February 25th 05, 07:17 PM
Morgans
"Jan Carlsson" wrote in message
Dick,
Jan Carlsson
At the speeds we fly, winglets do little to nothing. They only become
useful at higher speeds.
Old February 25th 05, 08:25 PM
Jim,
I disagree. Winglet are most effective at high angles of attack. They
significantly improve roll rate and control at low speeds. Their use on
several models of sailplanes solved the problem of the wing dropping during
the initial takeoff roll. They also decrease the speed at which the wing
stalls.
Here is a good article that may, for some, be worth reading.
http://www.soaridaho.com/Schreder/Te...lets/Masak.htm
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 09:40 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 06:07 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 04:52 AM
