Brake adjustment on the 2-33
Old April 16th 05, 12:25 AM
Jim Beckman
At 01:30 15 April 2005, Gm wrote:
Does anybody know of a wrecked 2-33 that is being parted
out and may
have a good wheel assembly?
Last summer I had the brake assembly out of our club's
2-33. The brake is a Cleveland item, and you can get
new brake drums for it. I got a new drum from Wickes
Aircraft Supply, and it was fairly cheap. Haven't
installed
it yet, though.
Jim Beckman
Old April 19th 05, 08:05 PM
Ian Forbes
GM wrote:
I guess it all comes down to the drum diameter. I have the sneaky
suspicion that someone in the past bored them out way too big.
If the drum has been machined over diameter, a brake specialist should
be able to measure the drum and fit overthick linings on the shoes to
match.
(That may explain why you have "worn" shoes with plenty of wear lining
left on them).
Ian
SZD-55 Wheel Brake Adjustment WDM Soaring 2 January 20th 11 10:25 AM
BRAKE FLUID Ventus B Soaring 9 October 17th 04 08:25 PM
Cobra Brake Parts or Axle WDM Soaring 1 October 11th 04 06:09 AM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 07:15 PM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 05:19 PM
