Cobra Brake Parts or Axle
Old October 10th 04, 10:44 PM
WDM
Default Cobra Brake Parts or Axle
Missing Brake Parts on Cobra Trailer
My brakes have not worked on my Cobra trailer since I purchased it. It is
probably 10 years old. I finally pulled the drums off and found all the
internal parts missing. I assume that a previous owner went joy riding with
the brake lever on. The brakes were probably burned up and then removed. I
have no brake parts and corroded drums. I am looking for recommendations. Do
I purchase parts and new drums or consider hanging a new axle with brakes
under the trailer. Does anyone in the US still make axles with mechanical
brakes? Should I convert the whole thing (axle and tongue) to hydraulic?
Anyone every tackled this successfully?
Thanks
** remove 55 to respond to email address directly **
Old October 11th 04, 06:09 AM
Rudy Allemann
"WDM" wrote in message k.net...
Thanks
Well, you could write to Spindelberger and give details of your
trailer and they would probably be able to supply you with new wheel
brake parts.
On my Cobra trailer Spindelberger used Al-Ko (Kober) running gear, so
you might also buy the parts from an Al-Ko dealer.
Rudy Allemann
molding plexiglas websites? [email protected] Owning 44 February 17th 05 10:33 PM
Cleveland Parking Brake Parts Jeff Home Built 2 October 11th 04 11:38 PM
Building the Po' Boy Bending Brake Veeduber Home Built 14 March 1st 04 07:15 PM
COBRA TALON, COBRA SPOT Allen Thomson Military Aviation 0 December 9th 03 07:44 PM
Brake caliper flange Stealth Pilot Home Built 5 July 7th 03 05:19 PM
