Wind/Solar Electrics ???
Old December 22nd 05, 12:25 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
Default Wind/Solar Electrics ???
On Wed, 21 Dec 2005 14:09:10 -0500, Steve Spence wrote:
George Ghio wrote:
Tell us why anyone would modify a sine wave.
It's called "engineering," George.
Nick
Really... Wouldn't they rather modify a square wave to approximate a
sine wave? What would be the point of modifying a sine wave, when a sine
wave (or close approximation) is the required result?
I hope you're not serious here.
They don't make a sine wave and modify it, they make a rectangular
wave and call it a "modified sine wave" because it passes enough tests
for harmonics and crap that it will run most stuff, and they can get
away with it. ;-)
Anybody wanna do an FFT of various duty-cycle waveforms, and give us real
THD information, and how that relates to power factor, and etc, and etc,
and etc?
The one inverter I've ever had my hands on the guts of made a waveform
like this:
| | | | | etc.
And the regulator was just based on an ordinary rectifier - they didn't
care about RMS, or it was scaled to get "close enough".
But I do wonder, what does the harmonic content really do when you vary
the duty cycle?
Some years ago, in the USAF, I saw some pulses on a spectrum analyzer,
and they had some really pretty envelopes. :-)
Thanks,
Rich
  #82
Old December 22nd 05, 03:29 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
Rich Grise wrote:
On Wed, 21 Dec 2005 14:06:05 -0500, Steve Spence wrote:
philkryder wrote:
"....We have a touch lamp that will not change
state on MSW, but will on generator"
Do you know if these new smaller Inverter style generators are a close
enough approximation for things like the laser printer?
Just how good are the "sine" like waves on them?
I thought someone was going to put a 'scope on one...
I don't have one (inverter/generator) to test. If it's a SW then yes, it
will work. The HONDA EM50is claims to be a sine wave unit.
It seems pretty obvious that a mechanical generator should put out a
relatively pure sine wave - it's just this big rotating magnetic field and
a couple of coils, after all. :-)
As a matter of fact, it's a little hard for me to visualize how someone
would make anything _other than_ a plain vanilla sine wave using just
a rotating magnet and a coil.
Thanks!
Rich
Inverter units do not provide mechanically driven electrical output to
the load, they run it through an inverter for frequency and voltage control.
Steve Spence
Dir., Green Trust, http://www.green-trust.org
Contributing Editor, http://www.off-grid.net
http://www.rebelwolf.com/essn.html
  #83
Old December 22nd 05, 03:33 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
Nick
away with it. ;-)
and etc?
like this:
| | | | | etc.
the duty cycle?
Thanks,
Rich
That's my point. There are modified square wave inverters (marketed as
Modified Sine Wave), and there are "Sine Wave" inverters, which are
really MSW's with such fine steps that finicky equipment can't tell the
difference. There are a few folks on this group trying to justify the
"Modified Sine Wave" sales moniker but there is no logic to it. Folks
who should know better, but can't find it easy to "agree" with george
even for a moment. It even kills me to do it, but hey, he has a point
for once.
Steve Spence
  #84
Old December 22nd 05, 03:47 AM posted to rec.aviation.owning
On Wed, 21 Dec 2005 23:25:58 GMT, Rich Grise
Nick
I only am posting this back to RAO as it's the only NG I receive out
of the list.
away with it. ;-)
Switching supplies are very efficient. Unfortunately things making sin
waves from DC are not. The faster you can turn the transistors on and
off the less heat and more power you can get out of a still smaller,
lighter, and *cheaper* power supply, or inverter.
Without digging too deep, a square wave contains an almost infinite
frequency range on the rise and fall times. Most likely many
thousands of times higher in frequency than the fundamental square
wave.
If you poke said square wave with all it's noise into an L/C filter
it'll round it off into more of an approximation of a sin wave. You
only have to get rid of enough of the spikes/harmonics to keep from
confusing what ever you plan on running off the thing.
and etc?
You want power factor too?
Lordy, when I think of the caps we used to switch in on the power
mains at work depending on load. I doubt current and voltage were
ever in phase. Well, maybe with the exception of the time we fired
back up after doing PM on some switch gear and some one had forgotten
to remove the jumpers. Boy, but that was noisy! It actually bent the
cabinet doors into shallow U-shapes and those things were made of 1/8"
thick steel and about 7 or 8 feet tall.
like this:
| | | | | etc.
They were just after "close enough". That's why the 400 watt PS in
one computer here weighs about a pound. The 500 watt in two others are
about 4# and the 630 is still heavier. BUT the 200 watt PS for my ham
rig weighs over 30#. I have a 600 watt (12 VDC @ 50 A) PS under the
desk that must weigh about 60 or 70#, None of the computer Power
supplies cost much over $50. I think the 400 was about $35. The big
one for the ham rig was several hundred dollars.
I have seen inverters that did a pretty good job on the output wave
form, but they were expensive and not nearly as efficient as the cheap
ones as a good portion of their work went into heat.
the duty cycle?
I would *guess* they would get pretty drastic at some portions
depending on just how hard the thing is working. There's not much
power in them so I'd expect to see them round off under load, but does
the inverter use dynamic filtering or hard filtering? Which is a good
way of saying I don't really know. :-))
www.rogerhalstead.com
Thanks,
Rich
  #85
Old December 22nd 05, 03:52 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
On Wed, 21 Dec 2005 14:29:00 GMT, Matt Whiting
To vary the power delivered to a load. Chopping off part of a sine wave
cycle is a standard means of power control.
That makes three phase SCR (Silicon controlled rectifiers and not
saturable core reactors) interesting as chopping off part of the wave
form develops spikes and harmonics that tend to make the control of
one phase interact with the others.
I've built a lot of them for single phase control, but I never once
was able to build one for three phase that didn't interact. Turn one
up and maybe another would go up, Turn the second down and the other
two might go up or down. Twas interesting:-)) which is probably why
Saturable core reactors are so popular in industry. Now there is a
controller that is a tad on the weighty side.
Matt
  #86
Old December 22nd 05, 03:54 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
On 20 Dec 2005 22:50:51 -0800, "philkryder"
The quality of the wave form is directly proportional to the money you
put into it.
I've used a small generator to power just about everything in here.
I've since upped that to 9,500 watts continuous which seems to work
well. It does tend to mess with the clocks if we're on generator
power for more than a few hours.
I've never had any problems with the computers of printers though.
  #87
Old December 22nd 05, 03:55 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
On Wed, 21 Dec 2005 23:16:55 GMT, Rich Grise
Purchase a cheap one. They must try. :-))
Thanks!
Rich
  #88
Old December 22nd 05, 03:59 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
When a scope is put on the waveform the shape is a
This is not a hard concept.
"Steve Spence" wrote in
message ...
logic to it. Folks
"agree" with george
hey, he has a point
for once.
Steve Spence
  #89
Old December 22nd 05, 04:06 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
I guess you have no experience with creating digital
waveforms with a D/A converter and computer algoryths
then.
"Keith Williams" wrote in message
T...
BS. Were it unfiltered aliasing would make the CD
sound terrible.
The filter has to be in there for any sampled system.
They didn't
"all of a sudden" figure out that they needed a
filter.
Keith
  #90
Old December 22nd 05, 04:10 AM posted to rec.aviation.owning,sci.electronics.design,alt.solar.photovoltaic
The application I'm familiar with (well I was 10 years ago) was
electrically fired glass melting units. The resistive load didn't much
care about cross phase interference. :-)
Matt
Question on 172 M electrics... (1974 Skyhawk II) [email protected] Piloting 8 April 10th 04 05:52 AM
