Question on 172 M electrics... (1974 Skyhawk II)
Old April 9th 04, 02:57 AM
Default Question on 172 M electrics... (1974 Skyhawk II)
Hi All!
We do not have a wiring diagram (yet) for our plane.
The Cigar Lighter socket is dead, and we need to fix it to
power our new portable GPS. (or have a poower cable installed....)
Which 12V point (bus) should it be wired to? (dont want to
unwrap the harness to check out the wiring. )
Inline fuse or one of the panel breakers?
Would it have been disconnected for some reason?
(I have heard there was an AD on some aircraft to disco it)
TY!
Dave
Old April 9th 04, 05:14 AM
Found it! discoed in 1983...
Looks like it can be reconnected if we install a fuse or
breaker in line...
Can anybody confirm this?
Dave
On Fri, 09 Apr 2004 01:07:13 GMT, "G.R. Patterson III"
Yep. As you've heard, there was an AD (at least in the U.S.) to either put it on its
own circuit breaker or fuse or to disconnect it. Most owners opted to disconnect it.
I don't know Canadian practice, but in the States there would be an AD log in the
back of the airframe logbook. Check the text of all those shown as complied with
until you find that one. I've been told that you can reactivate the outlet by adding
a breaker, but you'd need to check the AD text to be sure.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 9th 04, 08:24 AM
C J Campbell
breaker in line...
Sure. Just install a fuse or breaker. The fuse is probably easier.
Old April 9th 04, 07:03 PM
Newps
Bill Zaleski wrote:
You must have a mechanic perform the work in accordance with the AD
and sign off the compliance.
Anybody can do the work, the mechanic must sign it off.
Old April 10th 04, 02:19 AM
Bill Zaleski
Yes, correct to the extent that you describe, but not only must the
mechanic sign it off, but he must personally observe the work being
done before it is signed off. After the fact maintenence sign-offs,
though common, are illegal. Guess you want the reference? FAR 43.3
(d)
I should have used the word "inspect" instead of perform. Sorry.
Old April 10th 04, 03:14 AM
Jim Weir
Ah, grasshopper, you must read the WHOLE paragraph, not just those parts that
you personally believe. You, of course, are mistaken once again.
See the "to the extent necessary" clause? If I tell an owner to remove a wheel,
clean and lube the wheel bearings, and reinstall the wheel, and if I've seen the
owner do this perfectly a half-dozen times, how many "personal observations" do
you think I'm going to make?
After the fact maintenance sign-offs are NOT illegal if the signer was in on the
deal from the getgo and told the owner exactly what to do and when any
inspections (if any) were necessary.
(BTW, I don't mind disagreement with my holdings. However, you need to post
your qualifications for making the statements before I will give you one gram of
credence. A&P? IA? Private pilot with 43 hours?)
Bill Zaleski
-Yes, correct to the extent that you describe, but not only must the
-mechanic sign it off, but he must personally observe the work being
-done before it is signed off. After the fact maintenence sign-offs,
-though common, are illegal. Guess you want the reference? FAR 43.3
-(d)
http://www.rst-engr.com
Old April 10th 04, 05:52 AM
Bill Zaleski
A&P, I.A., FAA Aviation Maintenance Safety Counselor, 11,000+ hours,
holder of all category and class ratings except airship, 4X ATP, 4X
commercial, if you must ask, but what does that matter?
Are you really going to try and sell the idea that observing an
operation being done once on an aircraft automatically covers
repeated occurences of the same operation of multiple instances? That
sure doesn't fly in the Airlines. If you watch a few engine overhauls
from one non mechanic, are you going to sign off on one you didn't
supervise? "To the extent necessary" does not mean "no extent". The
reg requires you to be personally present to "observe the work BEING
done", not BEEN done, to ensure that it is being done properly.
As a Master Parachute Rigger, I can not simply fall back on the
premise that my supervision is valid just because I watched my trainee
pack correctly in the past. Every operation has to be observed, each
time. Same idea, Jim. Maybe things are different in Grass Valley.
Bill Zaleski
-(d)
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
ICom A-5 Question - Battery Level Indicator Harry Gordon Piloting 22 December 5th 03 01:07 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 10:40 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 07:05 PM
